查看: 3290|回复: 1
51单片机和Proteus仿真的RTX51交通灯操作系统代码
基于51单片机和Proteus仿真的RTX51交通灯操作系统,包含C语言源程序及Proteus仿真电路图,亲测完全可用
#include <reg52.h>                   /* special function register 8052       */
#include <rtx51tny.h>                 /* RTX-51 tiny functions & defines      */
#define  OLEN  8                      /* size of serial transmission buffer   */
unsigned char  ostart;                /* transmission buffer start index      */
unsigned char  oend;                  /* transmission buffer end index        */
idata    char  outbuf[OLEN];          /* storage for transmission buffer      */
unsigned char  otask = 0xff;          /* task number of output task           */
#define  ILEN  8                      /* size of serial receiving buffer      */
unsigned char  istart;                /* receiving buffer start index         */
unsigned char  iend;                  /* receiving buffer end index           */
idata    char  inbuf[ILEN];           /* storage for receiving buffer         */
unsigned char  itask = 0xff;          /* task number of output task           */
#define   CTRL_Q  0x11                /* Control+Q character code             */
#define   CTRL_S  0x13                /* Control+S character code             */
static bit   sendfull;                /* flag: marks transmit buffer full     */
static bit   sendactive;              /* flag: marks transmitter active       */
static bit   sendstop;                /* flag: marks XOFF character           */
/*       putbuf:  write a character to SBUF or transmission buffer            */
static void putbuf (char c)  {
  if (!sendfull)  {                   /* transmit only if buffer not full     */
    ES = 0;                           /* disable serial interrupt             */
    if (!sendactive && !sendstop)  {  /* if transmitter not active:           */
      sendactive = 1;                 /* transfer the first character direct  */
      SBUF = c;                       /* to SBUF to start transmission        */
    else  {                           /* otherwize:                           */
      outbuf[oend++ & (OLEN-1)] = c;  /* transfer char to transmission buffer */
      if (((oend ^ ostart) & (OLEN-1)) == 0)  sendfull = 1;
    }                                 /* set flag if buffer is full           */
        ES = 1;                           /* enable serial interrupt              */
/*       putchar:  interrupt controlled putchar function                      */
char putchar (char c)  {
  if (c == '\n')  {                   /* expand new line character:           */
    while (sendfull)  {               /* wait for transmission buffer empty   */
      otask = os_running_task_id ();  /* set output task number               */
      os_wait (K_SIG, 0, 0);          /* RTX-51 call: wait for signal         */
      otask = 0xff;                   /* clear output task number             */
    putbuf (0x0D);                    /* send CR before LF for <new line>     */
  putbuf (c);                         /* send character                       */
  return (c);                         /* return character: ANSI requirement   */
/*       _getkey:  interrupt controlled _getkey                               */
char _getkey (void)  {
  while  (iend == istart)  {
    itask = os_running_task_id ();    /* set input task number                */
    itask = 0xff;                     /* clear input task number              */
  return (inbuf[istart++ & (ILEN-1)]);
/*       serial:  serial receiver / transmitter interrupt                     */
void serial (void) interrupt 4 using 2  { /* use registerbank 2 for interrupt */
  unsigned char c;
  bit   start_trans = 0;
  if (RI)  {                         /* if receiver interrupt                 */
    c = SBUF;                        /* read character                        */
    RI = 0;                          /* clear interrupt request flag          */
    switch (c)  {                    /* process character                     */
      case CTRL_S:
        sendstop = 1;                /* if Control+S stop transmission        */
        break;
      case CTRL_Q:
        start_trans = sendstop;      /* if Control+Q start transmission       */
        sendstop = 0;
        break;
      default:                       /* read all other characters into inbuf  */
        if (istart + ILEN != iend)  {
          inbuf[iend++ & (ILEN-1)] = c;
                                     /* if task waiting: signal ready         */
        if (itask != 0xFF) isr_send_signal (itask);
        break;
  if (TI || start_trans)  {          /* if transmitter interrupt              */
    TI = 0;                          /* clear interrupt request flag          */
    if (ostart != oend)  {           /* if characters in buffer and           */
      if (!sendstop)  {              /* if not Control+S received             */
        SBUF = outbuf[ostart++ & (OLEN-1)];      /* transmit character        */
        sendfull = 0;                /* clear 'sendfull' flag                 */
        if (otask != 0xFF)  isr_send_signal (otask);
    else sendactive = 0;             /* if all transmitted clear 'sendactive' */
/*       serial_init: initialize serial interface                             */
void serial_init (void)  {
//  P1M1 = 0xFE;                   // Configure P1.0 (TxD) as Output
//  SCON   = 0x52;                 /* initialize UART                            */
//  BRGR0  = 0xF0;                 /* 9600 baud, 8 bit, no parity, 1 stop bit    */
//  BRGR1  = 0x02;
//  BRGCON = 0x03;
//SCON = 0x50;
//TMOD = 0x20;
//PCON = 0x00;
//TH1 = TL1 = 0xFD;
//EA = 1;
//ES = 1;
//TR1 = 1;
        TMOD |= 0x20;                //定时器T1工作在方式2(即自动重装初值),定时状态由TR1控制
        TL1 = TH1 = 0xFD;        //波特率为:9600
        ET1 = 0;                //T1用作波特率发生器,禁止T1中断
        TR1 = 1;                //启动定时器T1
        SCON = 0x50;                //方式1,8位UART,允许接收
        PCON &= 0x7F;                //波特率不倍增
        ES = 0;
全部资料51hei下载地址:
基于51单片机和Proteus仿真的RTX51操作系统.zip (100.44 KB, 下载次数: 43)
参与人数 1黑币 +100 收起 理由
admin + 100 共享资料的黑币奖励!
收藏收藏3 分享淘帖 顶 踩
ID:617003 发表于 2019-10-12 16:21 | 只看该作者
问一下这个是不是在TARGET选择RTX后写程序正常烧录单片机运行就行了啊
