查看: 3050|回复: 0
单片机+DS1302时钟带可调闹钟显示程序设计
ID:517871 发表于 2019-5-9 19:24 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
#include<reg52.h> //包含单片机寄存器的头文件
sbit led1=P1^0;
sbit led2=P1^2;
sbit led5=P1^5;
sbit du=P2^6;//段选
sbit we=P2^7;//位选
sbit s1=P3^4;
sbit s2=P3^5;
sbit s3=P3^6;
sbit s4=P3^7;
sbit beep=P2^3;
sbit dot=P0^7;
unsigned char shi,fen,miao,unit,keyv,key,av,ashi,afen,amiao;
void delay()   //1ms
      unsigned char a,b;
        for(b=102;b>0;b--)
          for(a=3;a>0;a--);
void delay5(void)   //误差 5ms
    unsigned char a,b;
    for(b=15;b>0;b--)
        for(a=152;a>0;a--);
void delayhalf (void)   //误差 0.5s
    unsigned char a,b,c;
    for(c=23;c>0;c--)
        for(b=152;b>0;b--)
            for(a=70;a>0;a--);
void display( unsigned char h,f,s)
unsigned char code duma[]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f,0x77,0x38};
unsigned char code mawei[]={0xfe,0xfd,0xfb,0xf7,0xef,0xdf,0xbf,0x7f};
unsigned char shiwan,wan,qian,bai,shi,ge;
shiwan=h/10;
wan=h%10;
qian=f/10;
bai=f%10;
shi=s/10;
ge=s%10;
P0=duma[shiwan];
  du=1;
  du=0;
  P0=mawei[0];
  we=1;
  we=0;
delay();
  P0=duma[wan];
  dot=1;
  du=1;
  du=0;
  dot=0;
P0=mawei[1];
  we=1;
  we=0;
delay();
  P0=duma[qian];
  du=1;
  du=0;
  P0=mawei[2];
  we=1;
  we=0;
delay();
P0=duma[bai];
  dot=1;
  du=1;
  du=0;
  dot=0;
P0=mawei[3];
  we=1;
  we=0;
delay();
if(key!=1&&key!=2)
P0=duma[shi];
  du=1;
  du=0;
  P0=mawei[4];
  we=1;
  we=0;
delay();
P0=duma[ge];
  du=1;
  du=0;
  P0=mawei[5];
  we=1;
  we=0;
  delay();
if(key==1||key==2)//
P0=duma[10];
  du=1;
  du=0;
  P0=mawei[4];
  we=1;
  we=0;
delay();
P0=duma[11];
  du=1;
  du=0;
  P0=mawei[5];
  we=1;
  we=0;
delay();
  P0=0xff;
  we=1;
  we=0;
passtime()
if(unit==100)
miao++;
unit=0;
led1=!led1;
led2=!led2;
if(miao==60)
fen++;
miao=0;
if(fen==60)
shi++;
fen=0;
if(shi==24)
shi=0;
void InitTimer0(void)//10ms
    TMOD = 0x01;
    TH0 = 0x0DC;
    TL0 = 0x00;
    EA = 1;
    ET0 = 1;
    TR0 = 1;
    unit=0;
void Timer0Interrupt(void) interrupt 1
    TH0 = 0x0DC;
    TL0 = 0x00;
   unit++ ;//add your code here!
passtime();
void adjustment(void)
if(s1==0)
  delay5();
  if(s1==0)
   while(!s1);
    amiao=0;
    key++;
    led5=0;
    if(key==5)
       key=0;
       TR0=1;
       led5=1;
   }//////s1 count
if(s2==0)
      delay5();
      if(s2==0)
         while(!s2);
         if(key==1)//alram
           ashi++;
           if(ashi==24)
              ashi=0;
           if(key==2)
           afen++;
           if(afen==60)
              afen=0;
           }//alram
         if(key==4)/////
           miao=0;
           TR0=0;
           fen++;
           if(fen==60)
              fen=0;
       if(key==3)///
           miao=0;
           TR0=0;
           shi++;
           if(shi==24)
              shi=0;
     }//adj +
///////////////////adj-
if(s3==0)
      delay5();
      if(s3==0)
         while(!s3);
         if(key==1)//alram
           ashi--;
           if(ashi==-1)
              ashi=23;
           if(key==2)
           afen--;
           if(afen==-1)
              afen=59;
           }//alram
         if(key==4)//
           miao=0;
           TR0=0;
           fen--;
           if(fen==-1)
              fen=59;
       if(key==3)///
           miao=0;
           TR0=0;
           shi--;
           if(shi==-1)
              shi=23;
     }//adj -
void alarm(void)
if(fen!=afen)
      av=0;
if(av==0)
  if(shi==ashi&&fen==afen)
   beep=0;
   delayhalf();
   beep=1;
   delayhalf();
   beep=0;
   delayhalf();
   beep=1;
  delayhalf();
}//av==0
主函数        编程: 火星人  qq:1170675125  学习板HL-1用
void main(void)
{ashi=7;afen=0;
InitTimer0();
led2=0;
if(keyv==0)//close display
if(s4==0)
  delay5();
  if(s4==0)
   while(!s4);
   keyv=1;
   av=1;
if(keyv==1)
if(s4==0)
   delay5();
   if(s4==0)
   while(!s4);
   keyv=0;
}//close display
if(keyv==0)
adjustment();
   if(key!=1&&key!=2)
    display(shi,fen,miao);
     if(key==1||key==2)
        display(ashi,afen,amiao);
if(key==0||key==3||key==4)
alarm();
}//while
基于51单片机的DS1302时钟带可调闹钟显示设计.zip
24.3 KB, 下载次数: 31, 下载积分: 黑币 -5
