查看: 3778|回复: 3
单片机小小调度器源程序 操作系统相关
一个简易的调度器
  1. #include <stc89c51.h>
  2. /****小小调度器开始**********************************************/
  3. #define MAXTASKS 3
  4. volatile unsigned char timers[MAXTASKS];
  5. #define _SS static unsigned char _lc=0; switch(_lc){default:
  6. #define _EE ;}; _lc=0; return 255;
  7. #define WaitX(tickets)??do {_lc=(__LINE__+((__LINE__%256)==0))%256; return tickets ;} while(0); case (__LINE__+((__LINE__%256)==0))%256:
  8. #define RunTask(TaskName,TaskID) do { if (timers[TaskID]==0) timers[TaskID]=TaskName(); }??while(0);
  9. #define RunTaskA(TaskName,TaskID) { if (timers[TaskID]==0) {timers[TaskID]=TaskName(); continue;} }? ?//前面的任务优先保证执行
  10. #define CallSub(SubTaskName) do {unsigned char currdt; _lc=(__LINE__+((__LINE__%256)==0))%256; return 0; case (__LINE__+((__LINE__%256)==0))%256:??currdt=SubTaskName(); if(currdt!=255) return currdt;} while(0);
  11. #define InitTasks() {unsigned char i; for(i=MAXTASKS;i>0 ;i--) timers[i]=0; }
  12. #define UpdateTimers() {unsigned char i; for(i=MAXTASKS;i>0 ;i--){if((timers[i-1]!=0)&&(timers[i-1]!=255)) timers[i-1]--;}}
  13. #define SEM unsigned int
  14. //初始化信号量
  15. #define InitSem(sem) sem=0;
  16. //等待信号量
  17. #define WaitSem(sem) do{ sem=1; WaitX(0); if (sem>0) return 1;} while(0);
  18. //等待信号量或定时器溢出, 定时器tickets 最大为0xFFFE
  19. #define WaitSemX(sem,tickets)??do { sem=tickets+1; WaitX(0); if(sem>1){ sem--;??return 1;} } while(0);
  20. //发送信号量
  21. #define SendSem(sem)??do {sem=0;} while(0);
  22. /*****小小调度器结束*******************************************************/
  23. sbit LED1 = P2^1;
  24. sbit LED2 = P2^2;
  25. sbit LED0 = P2^5;
  26. unsigned char task0(){
  27.         _SS
  28.         while(1){
  29.                 WaitX(50);
  30.                 LED0=!LED0;
  31.         }
  32.         _EE
  33. }
  34. unsigned char??task1(){
  35.         _SS
  36.         while(1){
  37.                 WaitX(100);
  38.                 LED1=!LED1;
  39.         }
  40.         _EE
  41. }
  42. unsigned char??task2(){
  43.         _SS
  44.         while(1){
  45.                 WaitX(100);
  46.                 LED2=!LED2;
  47.         }
  48.         _EE
  49. }
  50. void InitT0()
  51. {
  52.         TMOD = 0x21;
  53.         IE |= 0x82;??// 12t
  54.         TL0=0Xff;
  55.         TH0=0XDB;
  56.         TR0 = 1;
  57. }
  58. void INTT0(void) interrupt 1 using 1
  59. {
  60.         TL0=0Xff;? ? //10ms 重装
  61.         TH0=0XDB;//b7;
  62.         UpdateTimers();
  63.         RunTask(task0,0);//任务0具有精确按时获得执行的权限,要求:task0每次执行消耗时间<0.5个 ticket
  64. }
  65. void main()
  66. {
  67.         InitT0();
  68.         InitTasks(); //初始化任务,实际上是给timers清零
  69.         while(1){
  70.                 //? ?? ?? ???RunTask(task0,0);
  71.                 RunTaskA(task1,1);//任务1具有比任务2高的运行权限
  72.                 RunTaskA(task2,2);//任务2具有低的运行权限
  73.         }
  74. }
小小调度器.zip (11.96 KB, 下载次数: 40)
收藏收藏3 分享淘帖 顶顶 踩踩
ID:328014 发表于 2019-5-17 06:25 | 只看该作者
好资料,51黑有你更精彩!!!
ID:105845 发表于 2022-12-7 14:21 | 只看该作者
编译后出现test.c(99): warning C294: unreachable code。这个怎么消除呢?
ID:335252 发表于 2022-12-7 19:38 | 只看该作者
楼主棒棒的
