查看: 2084|回复: 1
第五届蓝桥杯决赛—门禁系统源程序
ID:432876 发表于 2019-5-11 16:53 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
#include <stc15f2k60s2.h>
#include <iic.h>
#include <ds18b20.h>
#include <ds1302.h>
#include <STDIO.H>
uchar code tab[]={0XC0,0XF9,0XA4,0XB0,0X99,0X92,0X82,0XF8,0X80,0X90,0XBF,0XFF,0xc6,0x89};
uchar yi,er,san,si,wu,liu,qi,ba;
uchar miao,fen,shi,sec_last;
uchar wendu,shidu,liang;
uchar receive_num,receive;
uchar tx_bufi[]="{20-20%} {23-59-50} {0}\r\n";
bit kaishi,moshi;
uchar jiemian,jiejin;
uchar time,tt,jilu;
uchar ci;
uchar wen_du[5],shi_du[5],shi_[5],fen_[5],miao_[5],time_[5];
void delayms(uint i)
uint a;
for(i;i>0;i--)
  for(a=845;a>0;a--);
void smg(uchar yi,er,san,si,wu,liu,qi,ba)
P2=0XC0;P0=0X01;P2=0XFF;P0=tab[yi];delayms(1);
P2=0XC0;P0=0X02;P2=0XFF;P0=tab[er];delayms(1);
P2=0XC0;P0=0X04;P2=0XFF;P0=tab[san];delayms(1);
P2=0XC0;P0=0X08;P2=0XFF;P0=tab[si];delayms(1);
P2=0XC0;P0=0X10;P2=0XFF;P0=tab[wu];delayms(1);
P2=0XC0;P0=0X20;P2=0XFF;P0=tab[liu];delayms(1);
P2=0XC0;P0=0X40;P2=0XFF;P0=tab[qi];delayms(1);
P2=0XC0;P0=0X80;P2=0XFF;P0=tab[ba];delayms(1);
P2=0XC0;P0=0XFF;P2=0XFF;P0=0XFF;
void key()
bit s5,s4;
if(P32==0)
  delayms(5);
  if(P32==0)
   s5=1;
else if(P33==0)
  delayms(5);
  if(P33==0)
   s4=1;
if((s4==1)&&(P33==1))
  s4=0;
  moshi=~moshi;
else if((s5==1)&&(P32==1))
  s5=0;
  jiemian++;
  if(jiemian==3)jiemian=0;
void UartInit(void)  //1200bps@11.0592MHz
SCON = 0x50;  //8位数据,可变波特率
AUXR |= 0x40;  //定时器1时钟为Fosc,即1T
AUXR &= 0xFE;  //串口1选择定时器1为波特率发生器
TMOD &= 0x0F;  //设定定时器1为16位自动重装方式
TL1 = 0x00;  //设定定时初值
TH1 = 0xF7;  //设定定时初值
ET1 = 0;  //禁止定时器1中断
TR1 = 1;  //启动定时器1
EA=1;ES=1;
void Timer0Init(void)  //5毫秒@11.0592MHz
AUXR |= 0x80;  //定时器时钟1T模式
TMOD &= 0xF0;  //设置定时器模式
TL0 = 0x00;  //设置定时初值
TH0 = 0x28;  //设置定时初值
TF0 = 0;  //清除TF0标志
TR0 = 1;  //定时器0开始计时
EA=1;ET0=1;
void send (uchar *p)
uchar index=0;
do
  SBUF=p[index++];
  while(TI==0);
  TI=0;
while(p[index]!=0);
void smgxianshi()
if(jiemian==0)
  yi=wendu/10;er=wendu%10;san=12;si=11;wu=11;liu=shidu/10;qi=shidu%10;ba=13;
else if(jiemian==1)
  yi=shi/10;er=shi%10;
  si=fen/10;wu=fen%10;
  qi=miao/10;ba=miao%10;
  if(miao%2==0){san=10;liu=10;}
  else {san=11;liu=11;}
else if(jiemian==2)
  yi=11;er=11;san=11;si=10;
  wu=11;liu=11;qi=11;ba=11;
P2=0XA0;P0=0X00;P2=0X80;P0=0XFF;
yi=11;er=11;san=11;si=11;wu=11;liu=11;qi=11;ba=11;
UartInit();
Timer0Init();
Write_Ds1302(0x8e,0x00);
Write_Ds1302(0x84,0x23);
Write_Ds1302(0x82,0x59);
Write_Ds1302(0x80,0x55);
  shidu=ad_du(0x01);
  miao=Read_Ds1302(0x81);
  fen=Read_Ds1302(0x83);
  shi=Read_Ds1302(0x85);
  shi=(shi/16)*10+shi%16;
  fen=(fen/16)*10+fen%16;
  miao=(miao/16)*10+miao%16;
  wendu=ds18b20();
  liang=ad_du(0x03);
  smgxianshi();
  if(moshi==0)
   if(liang>30)
    P2=0X80;P0=0XFE;
    jiejin=0;
   else  //1111 1010
    P2=0X80;P0=0XFA;
    jiejin=1;
//   if(kaishi==1)
//    if(sec_last!=miao)
//     sec_last=miao;
//     sprintf((char*)tx_bufi,"{%bd-%bd%%} {%0.2bd-%0.2bd-%0.2bd} {%bd}\r\n",wendu,shidu,shi,fen,miao,jiejin);
//     send(tx_bufi);
  else if(moshi==1)
   kaishi=0;
   if(liang>30)
    P2=0X80;P0=0XFD;
    if(jiejin==1) //保存数据
     jiejin=0;
     if(ci==0)
      at24c02_xie(20,wendu);delayms(2);
      at24c02_xie(21,shidu);delayms(2);
      at24c02_xie(22,shi);delayms(2);
      at24c02_xie(23,fen);delayms(2);
      at24c02_xie(24,miao);delayms(2);
      at24c02_xie(25,time);delayms(2);
      ci=1;
     else if(ci==1)
      at24c02_xie(30,wendu);delayms(2);
      at24c02_xie(31,shidu);delayms(2);
      at24c02_xie(32,shi);delayms(2);
      at24c02_xie(33,fen);delayms(2);
      at24c02_xie(34,miao);delayms(2);
      at24c02_xie(35,time);delayms(2);
      ci=2;
     else if(ci==2)
      at24c02_xie(40,wendu);delayms(2);
      at24c02_xie(41,shidu);delayms(2);
      at24c02_xie(42,shi);delayms(2);
      at24c02_xie(43,fen);delayms(2);
      at24c02_xie(44,miao);delayms(2);
      at24c02_xie(45,time);delayms(2);
      ci=3;
     else if(ci==3)
      at24c02_xie(50,wendu);delayms(2);
      at24c02_xie(51,shidu);delayms(2);
      at24c02_xie(52,shi);delayms(2);
      at24c02_xie(53,fen);delayms(2);
      at24c02_xie(54,miao);delayms(2);
      at24c02_xie(55,time);delayms(2);
      ci=4;
     else if(ci==4)
      at24c02_xie(60,wendu);delayms(2);
      at24c02_xie(61,shidu);delayms(2);
      at24c02_xie(62,shi);delayms(2);
      at24c02_xie(63,fen);delayms(2);
      at24c02_xie(64,miao);delayms(2);
      at24c02_xie(65,time);delayms(2);
      ci=0;
   else  //1111 1001 接近时间
    P2=0X80;P0=0XF9;
    jiejin=1;
   if(kaishi==1)
//    if(moshi==0)
//      sec_last=miao;
//      send(tx_bufi);
    for(ci=0;ci<5;ci++)
     wen_du[ci]=at24c02_du(20+ci*10);
    send(tx_bufi);
  key();
  smg(yi,er,san,si,wu,liu,qi,ba);
void time0() interrupt 1
if(jiejin==1)
  tt++;
  if(tt==200)
   tt=0;
   time++;
void ser() interrupt 4
RI=0;
receive=SBUF;
if(receive_num==0)
  if(receive=='A')receive_num=1;
  else receive_num=0;
else if(receive_num==1)
  if(receive=='A')receive_num=2;
  else receive_num=0;
else if(receive_num==2)
  if(receive=='A')receive_num=3;
  else receive_num=0;
else if(receive_num==3)
  if(receive=='S')receive_num=4;
  else receive_num=0;
else if(receive_num==4)
  if(receive=='S')receive_num=5;
  else receive_num=0;
else if(receive_num==5)
  if(receive=='S')
   receive_num=0;
   kaishi=1;
  else receive_num=0;
  程序说明: IIC总线驱动程序
  软件环境: Keil uVision 4.10
  硬件环境: CT107单片机综合实训平台 8051,12MHz
  日    期: 2011-8-9
#include "reg52.h"
#include "intrins.h"
#define somenop {_nop_();_nop_();_nop_();_nop_();_nop_();_nop_();_nop_();_nop_();_nop_();_nop_();_nop_();_nop_();_nop_();_nop_();_nop_();_nop_();_nop_();_nop_();_nop_();_nop_();_nop_();_nop_();_nop_();_nop_();_nop_();_nop_();_nop_();_nop_();_nop_();_nop_();_nop_();_nop_();_nop_();_nop_();_nop_();_nop_();_nop_();_nop_();_nop_();_nop_();_nop_();_nop_();_nop_();_nop_();_nop_();_nop_();_nop_();_nop_();_nop_();_nop_();_nop_();_nop_();_nop_();_nop_();}
#define SlaveAddrW 0xA0
#define SlaveAddrR 0xA1
//总线引脚定义
sbit SDA = P2^1;  /* 数据线 */
sbit SCL = P2^0;  /* 时钟线 */
//总线启动条件
void IIC_Start(void)
SDA = 1;
SCL = 1;
somenop;
SDA = 0;
somenop;
SCL = 0;
//总线停止条件
void IIC_Stop(void)
SDA = 0;
SCL = 1;
somenop;
SDA = 1;
//应答位控制
void IIC_Ack(bit ackbit)
if(ackbit)
  SDA = 0;
  SDA = 1;
somenop;
SCL = 1;
somenop;
SCL = 0;
SDA = 1;
somenop;
//等待应答
bit IIC_WaitAck(void)
SDA = 1;
somenop;
SCL = 1;
somenop;
if(SDA)
  SCL = 0;
  IIC_Stop();
  return 0;
  SCL = 0;
  return 1;
//通过I2C总线发送数据
void IIC_SendByte(unsigned char byt)
unsigned char i;
for(i=0;i<8;i++)
  if(byt&0x80)
   SDA = 1;
   SDA = 0;
  somenop;
  SCL = 1;
  byt <<= 1;
  somenop;
  SCL = 0;
//从I2C总线上接收数据
unsigned char IIC_RecByte(void)
unsigned char da;
unsigned char i;
for(i=0;i<8;i++)
  SCL = 1;
  somenop;
  da <<= 1;
  if(SDA)
  da |= 0x01;
  SCL = 0;
  somenop;
return da;
unsigned char iic_du(unsigned char add)
unsigned char num;
IIC_Start();
IIC_SendByte(0xa0);
IIC_WaitAck();
IIC_SendByte(add);
IIC_WaitAck();
IIC_Start();
IIC_SendByte(0xa1);
IIC_WaitAck();
num=IIC_RecByte();
IIC_WaitAck();
IIC_Stop();
return num;
void iic_xie(unsigned add,dat)
IIC_Start();
IIC_SendByte(0xa0);
IIC_WaitAck();
IIC_SendByte(add);
IIC_WaitAck();
IIC_SendByte(dat);
IIC_WaitAck();
IIC_Stop();
  程序说明: DS1302驱动程序
  日    期: 2011-8-9
#include <reg52.h>
#include <intrins.h>
sbit SCK=P1^7;
sbit SDA=P2^3;
sbit RST = P1^3;   // DS1302复位
void Write_Ds1302_Byte(unsigned  char temp)
unsigned char i;
for (i=0;i<8;i++)
  SCK=0;
  SDA=temp&0x01;
  temp>>=1;
  SCK=1;
void Write_Ds1302( unsigned char address,unsigned char dat )
  RST=0;
  SCK=0;
  RST=1;
  Write_Ds1302_Byte(address);
  Write_Ds1302_Byte(dat);
  RST=0;
unsigned char Read_Ds1302 ( unsigned char address )
  unsigned char i,temp=0x00;
  RST=0;
  SCK=0;
  RST=1;
  for (i=0;i<8;i++)
  SCK=0;
  temp>>=1;
   if(SDA)
   temp|=0x80;
   SCK=1;
  RST=0;
  RST=0;
SCK=0;
SCK=1;
SDA=0;
SDA=1;
return (temp);
第三节,门禁系统.zip
57.21 KB, 下载次数: 17, 下载积分: 黑币 -5
参与人数 2黑币 +60 收起 理由
zkele + 10 共享资料的黑币奖励!
收藏收藏2 分享淘帖 顶顶 踩踩
ID:432876 发表于 2019-5-11 17:12 | 只看该作者
发错啦,,程序 是第五届的
