查看: 1153|回复: 0
五一单片机 点阵滚动程序
ID:537204 发表于 2019-5-13 17:39 | 显示全部楼层 |阅读模式
   #include<reg51.h>
#include<math.h>
#include<intrins.h>
#define data1 P0
#define data2 P2
sbit s1=P3^6;
sbit s2=P3^7;
bit fangxiang;
uint alt=0,net=0,sl=8*7;
bit mode;
uchar code tab[]={
// 天(0)  大(1) 仁(2) 爱(3) 电(4) 1(5) 电(6)  2(7)
0x10,0x52,0x54,0x78,0x58,0x54,0x12,0x10,/*"0",天*/
0x01,0x12,0x14,0x18,0xF8,0x14,0x12,0x01,/*"1",大*/
0x10,0x20,0x7F,0x84,0x14,0x14,0x14,0x04,/*"2",仁*/
0x10,0x28,0x44,0x22,0x22,0x44,0x28,0x10,/*"3"爱(心形)*/
0x00,0x7C,0x54,0xFF,0x55,0x7D,0x03,0x00,/*"4",电*/
0x00,0x00,0x21,0x41,0xFF,0x01,0x00,0x00,/*"5",1*/
0x00,0x7C,0x54,0xFF,0x55,0x7D,0x03,0x00,/*"6",电*/
0x00,0x22,0x46,0x4A,0x52,0x22,0x00,0x00,/*"7",2*/
void delay(uint z)           //延时子函数
   uchar x;
   for(;z>0;z--)
   for(x=110;x>0;x--);
void xianshi()                        //显示
        uchar aa,i,num=2;
        for(i=0;i<16;i++)
                switch(i){
                        case 0:
                                num=1;
                                break;
                        case 1:
                                num=2;
                                break;
                        case 2:
                                num=4;
                                break;
                        case 3:
                                num=8;
                                break;
                        case 4:
                                num=16;
                                break;
                        case 5:
                                num=32;
                                break;
                        case 6:
                                num=64;
                                break;
                        case 7:
                                num=128;
                                break;
                        default :
                                num=0;
                                break;
                P2=0xff-num; //列扫描
                data1=tab[net+aa]; //取出上8行数据输出
                aa++;
                delay(5);        //延时
                data1=0;  //清屏
                P1=0x00;  //消除余辉
                if(aa>15) aa=0;  //字模地址
void main()         //主函数
   ET1=1;         //使能定时器0
   EA=1;         //开启总中断
   TR1=1;        //开始计数
   while(1)         //无限循环
           xianshi();  //显示
           if(s1==0)   //检测按键
              delay(30);  //延时消抖
                  TR1=~TR1;          //按下暂停  ,暂按继续
                  while(!s1)xianshi();
                  delay(30);
           if(s2==0)        //检测按键
               delay(30);                        //延时消抖
                   fangxiang=~fangxiang;  //方向取反
                   while(!s2)xianshi();
                   delay(30);
void timer1() interrupt 3
   alt++;
   if(alt==30)                   //到一定的时间加以实现左移
     alt=0;
         if(fangxiang==0)         //如果是正向 正向移动
                 net=net+2;
             if(net>sl)  //字移动数量
             net=0;
         else                           //否则反向移动
             net=net-2;
                 if(net<2)
                 net=sl;          //字移动数量
