查看: 2089|回复: 0
单片机温度报警器的LCD不显示 求帮助
ID:530740 发表于 2019-5-14 19:13 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
仿真时候,报警器和蜂鸣器正常响,但是LCD不显示温度。
代码如下:#include <reg52.h>//头文件,52单片机改为52
#include <intrins.h>
#define LCD_DATA P0
sbit LCD_RS = P2^0;
sbit LCD_RW = P2^1;
sbit LCD_EN = P2^2;
unsigned char dispBuff0[16]={'T','E','M',
'P',':',' ',' ',' ',' ',' ',' ','C',' ',' ',' ',};//LCD第一行显示
sbit DQ=P2^3;  //DS18B20数据端
unsigned int temperature=0;//温度
unsigned char fuhao=0;//温度的正负符号
//LED报警指示的IO口以及变量定义
sbit LED1=P2^4;//温度报警指示
#define off  1                   //高电平时灯为关闭状态
#define on 0                   //低电平时灯为开启状态
sbit speaker=P3^1;//蜂鸣器
void    Delay20ms() ;
void         LCD_WriteDat(unsigned char lcd_dat);
void         LCD_WriteCmd(unsigned char lcd_cmd);
unsigned char         LCD_ReadStatus(void);
void         LCD_Goto(unsigned char x,unsigned char y);
void    LCD_Display(unsigned char row,unsigned char *str);
void delay(unsigned int x)//延时公用程序
unsigned char j;
while(x--)
    for(j=0;j<125;j++);
/*1、LCD模块子函数*/
  void         LCD_Init(void)
        Delay20ms();
  LCD_WriteCmd(0x38);        //8位机接口、双行显示、5×7字符点阵;
        LCD_WriteCmd(0x0c);        //显示开启、光标不显示也不闪烁;
        LCD_WriteCmd(0x01);        //清屏;
     LCD_WriteCmd(0x06);        //光标右移一位、整屏不移动;
  LCD_Goto(0,0);
        unsigned char tmp;
        tmp = LCD_ReadStatus();                //读状态;
        while((tmp & 0x80))                        //是否忙 ?
        LCD_RS = 1;
        LCD_RW = 0;
        LCD_DATA = lcd_dat;
        _nop_();
        LCD_EN = 0;
        _nop_();
        _nop_();
        LCD_EN = 1;
        unsigned char tmp;
        while((tmp & 0x80))
        LCD_RS = 0;
        LCD_RW = 0;
        LCD_DATA = lcd_cmd;
        _nop_();
        LCD_EN = 0;
        _nop_();
        _nop_();
        LCD_EN = 1;
        unsigned char tmp;
        #if 0
        LCD_RS = 0;
        LCD_RW = 1;
        LCD_EN = 1;
        tmp = LCD_DATA;
        LCD_EN = 0;
        #endif
        LCD_DATA = 0xff;
        LCD_RS = 0;
        LCD_RW = 1;
        LCD_EN = 0;
        _nop_();
        _nop_();
        LCD_EN = 1;
        tmp = LCD_DATA;
        return tmp;
        unsigned char tmp;
        if(y)                                //若是第二行;
                        tmp = 0xc0 + x;
                        LCD_WriteCmd(tmp);
                        tmp = 0x80 + x;
                        LCD_WriteCmd(tmp);
        if(row)
                        LCD_Goto(0,1);
                  LCD_Goto(0,0);
  while(*str != '\0')
          LCD_WriteDat(*str++);
void Delay20ms()   //粗略延时;
  unsigned int tmp = 50000;
  while(tmp--);
/*2、DS18B2模块*/
void delay_18B20(unsigned int i)
while(i--);
/**********ds18b20初始化函数**********************/
void Init_DS18B20(void)
unsigned char x=0;
DQ = 1;          //DQ复位
delay_18B20(2); //稍做延时
DQ = 0;          //单片机将DQ拉低
delay_18B20(60); //精确延时 大于 480us
DQ = 1;          //拉高总线
delay_18B20(2);
x=DQ;            //稍做延时后 如果x=0则初始化成功 x=1则初始化失败
delay_18B20(15);
/***********ds18b20读一个字节**************/
unsigned char ReadOneChar(void)
unsigned char i=0;
unsigned char dat = 0;
for (i=8;i>0;i--)
    DQ = 0; // 给脉冲信号
    dat>>=1;
    DQ = 1; // 给脉冲信号
    if(DQ)
    dat |=0x80;
    delay_18B20(4);
   return(dat);
/*************ds18b20写一个字节****************/
void WriteOneChar(unsigned char dat)
   unsigned char i=0;
   for (i=8; i>0; i--)
    DQ = 0;
    DQ = dat&0x01;
    delay_18B20(2);
    DQ = 1;
    dat>>=1;
void ReadTemperature(void)
{unsigned char readdata[2]={0,0};
fuhao=0;
temperature=0;
delay_18B20(40);       // this message is very important
Init_DS18B20();
WriteOneChar(0xCC);    // 跳过读序号列号的操作
WriteOneChar(0x44); // 启动温度转换
delay_18B20(40);       // this message is wery important
Init_DS18B20();
WriteOneChar(0xCC); //跳过读序号列号的操作
WriteOneChar(0xBE); //读取温度寄存器等(共可读9个寄存器) 前两个就是温度
delay_18B20(40);
readdata[0]=ReadOneChar();    //读取温度值低位
readdata[1]=ReadOneChar();      //读取温度值高位
if (readdata[1]>127)
       {readdata[0]^=0xff;//求补码
        readdata[1]^=0xff;
        fuhao=1;//符号为“-”
temperature =readdata[1]*256+readdata[0] ;
temperature =temperature*0.625+0.5 ;//放大了10倍
void timer0() interrupt 1 //这里输出蜂鸣器信号
{TH0=254;//频率为1600hz时计时器初值
TL0=200;
speaker=!speaker;
{unsigned char DEN=0;
LCD_Init();//初始化LCD
/*计时器0设置*/
TMOD=0x11;//定时器1、2工作于方式1
TL0=200;
ET0=1;
EA=1;
speaker=1;
      /*LCD第一行显示温度*/
      ReadTemperature();//读取温度值
      if (fuhao)
         {dispBuff0[5]='-';}
             {dispBuff0[5]='+';}
          dispBuff0[6]=(temperature/1000)%10+'0';//温度值百位
          dispBuff0[7]=(temperature/100)%10+'0';//温度值十位
          dispBuff0[8]=(temperature/10)%10+'0';//温度值个位
          dispBuff0[9]='.';
          dispBuff0[10]=(temperature)%10+'0';//温度值小数点后一位;
          /*报警程序*/
          if (temperature>=330 && !fuhao)//温度大于40摄氏度
             {LED1=on;}
                {LED1=off;}
          if (temperature>=330 && !fuhao)//响蜂鸣器
             {TR0=1;}
                {TR0=0;}
       }//while
}//main
收藏收藏 分享淘帖 顶1 踩
