查看: 1243|回复: 0
这个原来是15个发光二极管 然后我的是9个 下面的单片机程序要改哪里?
#include<reg51.h>
#include<intrins.h>
sbit wela1=P3^0;
sbit wela2=P3^1;
sbit beep=P3^7;
sbit key=P3^4;
sbit key1=P3^2;
sbit key2=P3^3;
uchar n,m,temp1,temp2,a,b,num;
uint n1=0,n2=0;
void key_init();
uchar code table[]={0xc0,0xf9,0xa4,0xb0,0x99,0x92,0x82,0xf8,0x80,0x90};
void delay(uchar z)
uchar x,y;
for(x=z;x>0;x--)
for(y=120;y>0;y--);
void di(void)
beep=0;
delay(10);
beep=1;
void disp(uchar shi,uchar ge)
wela1=0;
P1=table[shi];
delay(10);
wela1=1;
wela2=0;
P1=table[ge];
delay(10);
wela2=1;
void key_init()
if(key==0)
delay(5);
if(key==0)
  while(!key);
  temp1=0x7f;
  temp2=0xff;
  di();
  P0=temp1;
  P2=temp2;
  num++;
  if(num==3)
   num=0;
if(num==2)
if(key1==0)
delay(5);
if(key1==0)
  while(!key1);
  if(temp1==0xff)
    if(temp2==0xfe)
      temp2=0xff;
      P2=temp2;
      temp1=0x7f;
      P0=temp1;
    if(temp2!=0xff)
      temp2=_cror_(temp2,1);
      P2=temp2;
temp1=_cror_(temp1,1);
P0=temp1;
a=1;
  if(key2==0)
     delay(5);
          if(key2==0)
      while(!key2);
       if(temp2=0xff)
           if(P0==0x7f)
             temp1=0xff;
             P0=temp1;
             temp2=0xfe;
             P2=temp2;
           if(temp1!=0xff)
             P0=temp1;
  temp2=_crol_(temp2,1);
  P2=temp2;
  b=1;
if(P0==0xfe&&a==1)
num=0;
n+=1;
a=0;
if(P2==0xbf&&b==1)
num=0;
m+=1;
b=0;
void init()
P0=0x7f;
n1=0;
n2=0;
num=0;
n=0;
m=0;
init();
disp(n,m);
disp(n,m);
key_init();
