查看: 2220|回复: 0
51单片机DS18B20 四位共阳数码管
#include <reg51.h>
sbit DQ=P3^7;
sbit DIAN = P1^7;
sbit C1 = P2^0;
sbit C2 = P2^1;
sbit C3 = P2^2;
sbit C4 = P2^3;
uchar x=0;
signed char m;
uchar n;
uint z;
uint c;
uchar num[4]={0};
uchar code  LEDData[]={0xc0,0xf9,0xa4,0xb0,0x99,0x92,0x82,0xf8,0x80,0x90};
void display(unsigned char k);
void delay( int o)
while(o--);
void init_DS18b20 (void)
unsigned char x=0;
DQ = 1;
delay(8);
DQ = 0;
delay(100);
DQ = 1;
delay(20);
x = DQ;
delay(20);
uchar Read_One_Byte(void)
uchar i=0;
uchar dat=0;
for(i=8;i>0;i--)
DQ=0;
dat>>=1;
DQ=1;
if(DQ)
dat|=0x80;
delay(4);
return(dat);
void Write_One_Byte(uchar dat)
uchar i=0;
for(i=8;i>>0;i--)
DQ=0;
DQ=dat&0x01;
delay(5);
DQ=1;
dat>>=1;
unsigned int ReadTemperature(void)
unsigned char a=0;
unsigned char b=0;
unsigned int t=0;
float tt=0;
init_DS18B20();
Write_One_Byte(0xCC);
Write_One_Byte(0x44);
init_DS18B20();
Write_One_Byte(0xBE);
a=Read_One_Byte();
b=Read_One_Byte();
t=b;
t<<=8;
t=t|a;
tt=t*0.0625;
t=tt*10+0.5;
return(t);
void check_wendu(void)
uint a,b;
c=ReadTemperature();
a=c/100;
b=c/10-a*10;
m=c/10;
if(m<=0)
  m=0;
n=c-a*100-b*10;
void Disp_init(void)
P1 =0x7f;
P2 = 0xf8;
delay(200);
P2 = 0xf4;
delay(200);
P2 = 0xf2;
delay(200);
P2 = 0xf1;
delay(200);
P2 = 0xFF;
void Disp_Temperature(void)
int i=0;
for(i=0;i<4;i++)
display(i);//0,1
delay(1000);
    P1 = 0XFF; }
{//s=0 dat=1
//unsigned char n = 0x01;
switch(k)
case 0:
C1=1;C2=0;C3=0;C4=0;
P1 =LEDData[m/10];//P1=Seg[h/10];
break;
case 1:
C1=0;C2=1;C3=0;C4=0;
  P1 =LEDData[m%10];
  //P1=Seg[h%10];
break;
case 2:
C1=0;C2=0;C3=1;C4=0;
P1 =0x9c;//P1=0xbf;
break;
case 3:
C1=0;C2=0;C3=0;C4=1;
  P1 =0xc6;//P1=Seg[m/10] ;
break;
void main(void)
  unsigned int ReadTemperature();
  check_wendu();
  Disp_init();
  display();
  Disp_Temperature();
收藏收藏1 分享淘帖 顶 踩
