查看: 5692|回复: 0
51单片机ADC0808数据采集
#include <reg52.h>
#define DATE P0
sbit rs=P1^0;
sbit rw=P1^1;
sbit e=P1^2;
sbit oe=P1^3;
sbit eoc=P1^4;
sbit clk=P1^5;
sbit st=P1^6;
uint getdata=0;
uint dot=0;
uint bai,shi,ge;
uchar code table1[]="0123456789.v";
void initdingshi();     //初始化定时器0
void adc0809();         //启动0809转换,并得到转换A/D
void initdingshi();     //初始化LCD1602
/********************延时函数*************************/
void delay_us(unsigned int n)
   if(n==0)
           return;
   while(--n);
void delay_ms(uint i)
    unsigned char a,b;
        for(a=1;a<i;a++)
         for(b=1;b;b++);
void delay(uint z)
    uint x,y;
        for(x=110;x>0;x--)
             for(y=z;y>0;y--);
/**************************控制LCD1602的函数*******************/
void write_command(uchar come)   //写指令
    rs=0;
        e=1;
        DATE=come;
        delay_us(5);
        e=0;
        rs=1;
void write_date(uchar date)
    rs=1;
        e=1;
        DATE=date;
        delay_us(5);
        e=0;
        rs=0;
/*****************液晶初始化****************/
void inityejing()        //液晶初始化
    rw=0;
        e=0;
        write_command(0x38);
        delay_ms(5);
        write_command(0x01);
        delay_ms(5);
        write_command(0x06);
    delay_ms(5);
        write_command(0x0c);
    delay_ms(5);
void chufa()
    bai=(getdata)/100;
        shi=(getdata)%100/10;
    ge=(getdata)%10;
        write_command(0x80);
        write_date(table1[bai]);
        write_date(table1[10]);
    write_date(table1[shi]);
    write_date(table1[ge]);
    write_date(table1[11]);
        delay(100);
/********************ADC0809的使用*************************/
void adc0809()
    st=0;
        st=1;
        st=0;
        while(!eoc);
        oe=1;
        dot=P2;
        oe=0;
        getdata=dot*1.0/255*500;
/********************配置定时器产生时钟***********************/
void initdingshi()       //初始化定时器0工作方式2    为0809提供时钟
    TMOD=0X02;
        TH0=0XFB;                       //500KHZ  2微秒
        TL0=0XFB;
        TR0=1;
        ET0=1;
        EA=1;
        inityejing();
    initdingshi();
            adc0809();
                chufa();
void time0()  interrupt 1
  TH0=0XFB;
  TL0=0XFB;
  clk=~clk;
ADC0809程序.zip (30.33 KB, 下载次数: 32)
