查看: 4089|回复: 0
基于51的LCD12864字符显示代码
ID:550820 发表于 2019-5-30 10:13 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
基于51单片机的LCD12864串行显示。/******************************************************************************
        LCD12864显示,
#include<reg51.h>
sbit LCD12864_RS=P2^3;
sbit LCD12864_RW=P2^4;
sbit LCD12864_EN=P2^5;
sbit LCD12864_PSB=P3^2;
unsigned char num;
unsigned char code table[]="滕王阁序";
unsigned char code table1[]="——王勃";
unsigned char code table2[]="落霞与孤鹜齐飞";
unsigned char code table3[]="秋水共长天一色";
void delay(unsigned int z)
   unsigned char x,y;
   for(;z>0;z--)
      for(x=38;x>0;x--)
              for(y=130;y>0;y--);
void write_com(unsigned char com)
  LCD12864_RW=0;
  LCD12864_RS=0;
  P0=com;
  delay(5);
  LCD12864_EN=1;
  delay(5);
  LCD12864_EN=0;
void write_data(unsigned char dat)
  LCD12864_RW=0;
  LCD12864_RS=1;
  P0=dat;
  delay(5);
  LCD12864_EN=1;
  delay(5);
  LCD12864_EN=0;
void init()
  LCD12864_PSB=1;
  LCD12864_RW=0;
  LCD12864_RS=0;
  write_com(0x30);                         //功能设定.RE=0:基本指令操作
  delay(5);
  write_com(0x0c);                   // 1DCB
  delay(5);
  write_com(0x01);                  //清屏
  write_com(0x80);            //设置数据起点
  while(1)                                          //把动态显示的数据在while里不断循环,对数据进行不断地刷新.
     init();
         write_com(0x82);                                   // 设置显示字符位置
     num=0;
          while(table[num]!='\0')
                    write_data(table[num]);
                  num++;
                  delay(5);
          write_com(0x93);
          num=0;                                                   //num每次都清零
          while(table1[num]!='\0')
                    write_data(table1[num]);
                  num++;
                  delay(5);
          write_com(0x88);
          num=0;
          while(table2[num]!='\0')
                    write_data(table2[num]);
                  num++;
                  delay(5);
          write_com(0x99);
          num=0;
          while(table3[num]!='\0')
                    write_data(table3[num]);
                  num++;
                  delay(5);
收藏收藏1 分享淘帖 顶 踩
