查看: 4118|回复: 0
dht11 arduino例程
ID:553104 发表于 2019-6-2 17:41 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
#include "DHT.h"
//#define DHTPIN 6     // Digital pin connected to the DHT sensor
#define DHTTYPE DHT11   // DHT 11
DHT dht(6, DHTTYPE);
int led2=7;
int led3=4;
unsigned char hexdata[8] = {0x5A,0xA5,0x05,0x82,0x00,0x01,0x00,0x00};
unsigned char hexdata2[8] = {0x5A,0xA5,0x05,0x82,0x00,0x02,0x00,0x00};
unsigned char hexdata3[8] = {0x5A,0xA5,0x05,0x82,0x00,0x04,0x00,0x00};
void setup() {
  Serial.begin(115200);  //
  Serial.println("测试开始");
  pinMode(led2,OUTPUT);
  pinMode(led3,OUTPUT);
  dht.begin();
void loop() {
  delay(500);     // 等一段时间给传感器检测,一般温度和湿度各需要250毫秒
  float h = dht.readHumidity();    //读湿度        int
  float t = dht.readTemperature();    //读温度
  int t1=t*100;
  int t2=t1/256;
// hexdata[6] = t2;
// hexdata[7] = t1-t2*256;
hexdata[7]=t2;
Serial.write(hexdata,8);
delay(100);
  int h1=h*100;
  int h2=h1/256;
// hexdata2[6] = h2;
// hexdata2[7] = h1-h2*256;
hexdata2[7]=h2;
Serial.write(hexdata2,8);
//5A A5 05 82 00 02 00 66
//  Serial.print("温度:");
// Serial.print(t);                        // 输出温度
// Serial.print("°C  湿度: ");
//Serial.println(h);                        // 输出湿度
//  Serial.println("% ");
  if (h > 50) {
   hexdata3[7]=50;
  Serial.write(hexdata3,8);
  if (h < 80) {
  digitalWrite(led2,LOW);
  if (t > 23)  {
       digitalWrite(led3,HIGH);
  if (t < 23) {
  digitalWrite(led3,LOW);
Temperature_and_Humidity.rar
5.26 KB, 下载次数: 42, 下载积分: 黑币 -5
