查看: 6370|回复: 4
51单片机+DAC0832波形发生器(PCB文件+仿真源程序)波形选择增加和减少频率按钮
基于51单片机的波形发生器,里面包含了仿真文件和源程序,pcb文件。
Altium Designer画的波形发生器原理图和PCB图如下:(51hei附件中可下载工程文件)
  1.                  #include<reg52.h>
  2. #define  uchar unsigned char
  3. #define  uint  unsigned int
  4. #define DAdata  P0        //DA数据端口
  5. sbit DA_S1= P2^0;   // 控制DAC0832的8位输入寄存器,仅当都为0时,可以输出数据(处于直通状态),否则,输出将被锁存
  6. sbit DA_S2= P2^1;   // 控制DAC0832的8位DAC寄存器,仅当都为0时,可以输出数据(处于直通状态),否则,输出将被锁存
  7. sbit key=   P3^2;
  8. uchar wavecount;    //'抽点'计数
  9. uchar THtemp,TLtemp;//传递频率的中间变量
  10. uchar judge=1;      //在方波输出函数中用于简单判别作用
  11. uchar waveform;            //当其为0、1、2时,分别代表三种波
  12. uchar code freq_unit[3]={10,50,200}; //三种波的频率单位
  13. uchar idata wavefreq[3]={1,1,1};           //给每种波定义一个数组单元,用于存放单位频率的个数
  14. uchar code  lcd_hang1[]={"Sine Wave       " "Triangle Wave   " "Square Wave     " "Select Wave:    " "press No.1 key! "};
  15. uchar idata lcd_hang2[16]={"f=    Hz        "};
  16. uchar code waveTH[]={
  17.     0xfd,0xfe,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,
  18. 0xfd,0xfe,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,
  19. 0xec,0xf6,0xf9,0xfb,0xfc,0xfc,0xfd,0xfd,0xfd,0xfe};
  20. uchar code waveTL[]={
  21.     0x06,0x8a,0x10,0x4e,0x78,0x93,0xa8,0xb3,0xbe,0xc6, //正弦波频率调整中间值
  22. 0xac,0xde,0x48,0x7a,0x99,0xaf,0xbb,0xc8,0xd0,0xde,        //三角波频率调整中间值
  23. 0x88,0x50,0x90,0x32,0x34,0xbe,0x4a,0xa3,0xe5,0x2c};
  24. /*************************************************************************************************/
  25. uchar code triangle_tab[]={         //每隔数字8,采取一次
  26. 0x00,0x08,0x10,0x18,0x20,0x28,0x30,0x38,0x40,0x48,0x50,0x58,0x60,0x68,0x70,0x78,
  27. 0x80,0x88,0x90,0x98,0xa0,0xa8,0xb0,0xb8,0xc0,0xc8,0xd0,0xd8,0xe0,0xe8,0xf0,0xf8,0xff,
  28. 0xf8,0xf0,0xe8,0xe0,0xd8,0xd0,0xc8,0xc0,0xb8,0xb0,0xa8,0xa0,0x98,0x90,0x88,0x80,
  29. 0x78,0x70,0x68,0x60,0x58,0x50,0x48,0x40,0x38,0x30,0x28,0x20,0x18,0x10,0x08,0x00};
  30. uchar code sine_tab[256]={
  31. //输出电压从0到最大值(正弦波1/4部分)
  32. 0x80,0x83,0x86,0x89,0x8d,0x90,0x93,0x96,0x99,0x9c,0x9f,0xa2,0xa5,0xa8,0xab,0xae,0xb1,0xb4,0xb7,0xba,0xbc,
  33. 0xbf,0xc2,0xc5,0xc7,0xca,0xcc,0xcf,0xd1,0xd4,0xd6,0xd8,0xda,0xdd,0xdf,0xe1,0xe3,0xe5,0xe7,0xe9,0xea,0xec,
  34. 0xee,0xef,0xf1,0xf2,0xf4,0xf5,0xf6,0xf7,0xf8,0xf9,0xfa,0xfb,0xfc,0xfd,0xfd,0xfe,0xff,0xff,0xff,0xff,0xff,0xff,
  35. //输出电压从最大值到0(正弦波1/4部分)
  36. 0xff,0xff,0xff,0xff,0xff,0xff,0xfe,0xfd,0xfd,0xfc,0xfb,0xfa,0xf9,0xf8,0xf7,0xf6,0xf5,0xf4,0xf2,0xf1,0xef,
  37. 0xee,0xec,0xea,0xe9,0xe7,0xe5,0xe3,0xe1,0xde,0xdd,0xda,0xd8,0xd6,0xd4,0xd1,0xcf,0xcc,0xca,0xc7,0xc5,0xc2,
  38. 0xbf,0xbc,0xba,0xb7,0xb4,0xb1,0xae,0xab,0xa8,0xa5,0xa2,0x9f,0x9c,0x99 ,0x96,0x93,0x90,0x8d,0x89,0x86,0x83,0x80,
  39. //输出电压从0到最小值(正弦波1/4部分)
  40. 0x80,0x7c,0x79,0x76,0x72,0x6f,0x6c,0x69,0x66,0x63,0x60,0x5d,0x5a,0x57,0x55,0x51,0x4e,0x4c,0x48,0x45,0x43,
  41. 0x40,0x3d,0x3a,0x38,0x35,0x33,0x30,0x2e,0x2b,0x29,0x27,0x25,0x22,0x20,0x1e,0x1c,0x1a,0x18,0x16 ,0x15,0x13,
  42. 0x11,0x10,0x0e,0x0d,0x0b,0x0a,0x09,0x08,0x07,0x06,0x05,0x04,0x03,0x02,0x02,0x01,0x00,0x00,0x00,0x00,0x00,0x00,
  43. //输出电压从最小值到0(正弦波1/4部分)
  44. 0x00,0x00,0x00,0x00,0x00,0x00,0x01,0x02 ,0x02,0x03,0x04,0x05,0x06,0x07,0x08,0x09,0x0a,0x0b,0x0d,0x0e,0x10,
  45. 0x11,0x13,0x15 ,0x16,0x18,0x1a,0x1c,0x1e,0x20,0x22,0x25,0x27,0x29,0x2b,0x2e,0x30,0x33,0x35,0x38,0x3a,0x3d,
  46. 0x40,0x43,0x45,0x48,0x4c,0x4e,0x51,0x55,0x57,0x5a,0x5d,0x60,0x63,0x66 ,0x69,0x6c,0x6f,0x72,0x76,0x79,0x7c,0x80};
  47. void delay(uchar z)
  48. {
  49.     uint x,y;
  50. for(x=z;x>0;x--)
  51. for(y=110;y>0;y--);
  52. }
  53. void triangle_out()        //三角波输出
  54. {
  55.     DAdata=triangle_tab[wavecount++];
  56. if(wavecount>64) wavecount=0;
  57. DA_S1=0;  //打开8位输入寄存器
  58. DA_S1=1;  //关闭8位输入寄存器
  59. }
  60. void sine_out()         //正弦波输出
  61. {
  62.     DAdata=sine_tab[wavecount++];
  63. DA_S1=0;  //打开8位输入寄存器
  64. DA_S1=1;  //关闭8位输入寄存器
  65. }
  66. void square_out()  //方波输出
  67. {
  68.     judge=~judge;
  69.     if(judge==1) DAdata=0xff;
  70. else  DAdata=0x00;
  71. DA_S1=0;  //打开8位输入寄存器
  72. DA_S1=1;  //关闭8位输入寄存器
  73. }
  74. /************1602液晶的相关函数*************/
  75. #define lcd_ports P1
  76. sbit rs=P2^2;
  77. sbit rw=P2^3;
  78. sbit lcden=P2^4;
  79. void write_com(uchar com)
  80. {
  81. rs=0;        //置零,表示写指令
  82. lcden=0;
  83. lcd_ports=com;
  84. delay(5);
  85. lcden=1;
  86. delay(5);
  87. lcden=0;
  88. }
  89. void write_date(uchar date)
  90. {
  91. rs=1;        //置1,表示写数据(在指令所指的地方写数据)
  92. lcden=0;
  93. lcd_ports=date;
  94. delay(5);
  95. lcden=1;
  96. delay(5);
  97. lcden=0;
  98. }
  99. void disp_lcd(uchar addr,uchar *temp1)
  100. {
  101. uchar num;
  102. write_com(addr);
  103. delay(1);   //延时一会儿???
  104. for(num=0;num<16;num++)
  105. {
  106. write_date(temp1[num]);//或者这样写write_date(*(temp1+num));
  107. delay(1);
  108. }
  109. }
  110. void init_lcd()
  111. {
  112. //uchar num;
  113. lcden=0;  //可有可无???
  114. rw=0;  //初始化一定要设置为零,表示写数据
  115. write_com(0x38);  //使液晶显示点阵,为下面做准备
  116. write_com(0x0c);  //初始设置
  117. write_com(0x06);  //初始设置
  118. write_com(0x01);  //清零
  119. write_com(0x80);  //使指针指向第一行第一格
  120.     disp_lcd(0x80,&lcd_hang1[3*16]);  //在第一行显示
  121.     disp_lcd(0xc0,&lcd_hang1[4*16]);  //在第二行显示
  122. }
  123. /********************1602液晶函数声明结束*********************/
  124. void main()
  125. {
  126.     uchar i=0;
  127. DA_S2=0;    //使DAC寄存器处于直通状态
  128. DAdata=0;
  129. DA_S1=1;    //关闭8位输入寄存器
  130. init_lcd();
  131.     waveform=0;
  132. TMOD=0x01;  //设置定时器0为16位工作方式
  133. IT0=1;      //设置外部中断0为下降沿触发
  134. ET0=1;      //开定时器中断
  135. EX0=1;
  136. EA=1;
  137. while(1)
  138. {
  139. //DAout(0xff);           //可输出TTL波形
  140. //DAout(0x80);
  141. //T_temp=32;
  142. }
  143. }
  144. void timer0() interrupt 1
  145. {
  146. TH0=THtemp;
  147. TL0=TLtemp;
  148. if(waveform==0)      sine_out();
  149. else if(waveform==1) triangle_out();
  150. else if(waveform==2) square_out();
  151. }
  152. void key_int0() interrupt 0
  153. {
  154.     uchar keytemp;
  155. uint total_freq; //总频率
  156. EA=0; TR0=0;     //关总中断与定时器
  157. delay(5);       //延时够吗???
  158. if(key==0)       //确实有按键按下而引发中断
  159. {
  160. keytemp=P3&0xf0; //获取P3口高四位的值
  161. switch(keytemp)
  162. {
  163.     case 0xe0:        //选择波形
  164.      waveform++;
  165. if(waveform>2) waveform=0;
  166. break;
  167.     case 0xd0:  //频率按规定单位依次增加
  168.      wavefreq[waveform]++;
  169. if(wavefreq[waveform]>10) wavefreq[waveform]=1; // /*这边要用“>10”,因为它比“=11”可靠
  170. break;         //   性更高,使加数有个上限,不会一直加下去*/
  171. ……………………
  172. …………限于本文篇幅 余下代码请从51黑下载附件…………
风之彩+波形发生器.rar (1.84 MB, 下载次数: 168)
收藏收藏4 分享淘帖 顶顶1 踩踩
ID:513931 发表于 2019-6-25 08:31 | 只看该作者
你好,如果想让他可以同时输出两个波形要怎么修改呀?
ID:530089 发表于 2019-6-25 17:19 | 只看该作者
信号频率是多少?
ID:579696 发表于 2019-7-9 09:02 来自触屏版 | 只看该作者
兄弟,这个问题你现在解决了吗
ID:642962 发表于 2019-11-17 22:21
仿真的和画的PCB不一样,哭了
ID:1140366 发表于 2024-12-19 11:02 | 只看该作者
是有pcb的源文件吗?
