查看: 7577|回复: 3
Arduino HX711模块库文件下载
ID:557243 发表于 2019-6-10 00:05 | 显示全部楼层 |阅读模式
有些乱,不过能看
Arduino源程序如下:
  1. #include "hx711.h"
  2. long HX711_Buffer = 0;
  3. long Weight_Maopi = 0,Weight_Shiwu = 0;
  4. #define GapValue 430
  5. //****************************************************
  6. //初始化HX711
  7. //****************************************************
  8. void Init_Hx711()
  9. {
  10.         pinMode(HX711_SCK, OUTPUT);
  11.         pinMode(HX711_DT, INPUT);
  12. }
  13. //****************************************************
  14. //获取毛皮重量
  15. //****************************************************
  16. void Get_Maopi()
  17. {
  18.         Weight_Maopi = HX711_Read();
  19. }
  20. //****************************************************
  21. //称重
  22. //****************************************************
  23. long Get_Weight()
  24. {
  25.         HX711_Buffer = HX711_Read();
  26.         Weight_Shiwu = HX711_Buffer;
  27.         Weight_Shiwu = Weight_Shiwu - Weight_Maopi;                                //获取实物的AD采样数值。
  28.         Weight_Shiwu = (long)((float)Weight_Shiwu/GapValue);
  29.         return Weight_Shiwu;
  30. }
  31. //****************************************************
  32. //读取HX711
  33. //****************************************************
  34. unsigned long HX711_Read(void)        //增益128
  35. {
  36.         unsigned long count;
  37.         unsigned char i;
  38.         bool Flag = 0;
  39.         digitalWrite(HX711_DT, HIGH);
  40.         delayMicroseconds(1);
  41.         digitalWrite(HX711_SCK, LOW);
  42.         delayMicroseconds(1);
  43.           count=0;
  44.           while(digitalRead(HX711_DT));
  45.           for(i=0;i<24;i++)
  46.         {
  47.                   digitalWrite(HX711_SCK, HIGH);
  48.                 delayMicroseconds(1);
  49.                   count=count<<1;
  50.                 digitalWrite(HX711_SCK, LOW);
  51.                 delayMicroseconds(1);
  52.                   if(digitalRead(HX711_DT))
  53.                         count++;
  54.         }
  55.         digitalWrite(HX711_SCK, HIGH);
  56.         count ^= 0x800000;
  57.         delayMicroseconds(1);
  58.         digitalWrite(HX711_SCK, LOW);
  59.         delayMicroseconds(1);
  60.
  61.         return(count);
  62. }
HX711_AD.zip (1.59 KB, 下载次数: 103)
ID:560595 发表于 2019-6-28 11:34 | 显示全部楼层
感谢
ID:894213 发表于 2021-3-20 11:00 | 显示全部楼层
thanks all
ID:1009293 发表于 2022-3-21 22:11 | 显示全部楼层
这个能用吗
