查看: 1761|回复: 1
单片机避障小车程序
ID:562725 发表于 2019-6-16 18:46 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
main.c
#include<reg52.h>
#include<funcation.h>     //多功能头文件
#include<bizhang.h>          //避障头文件
uchar flag,tt=0,a;
void delay2();
int i=10;
              init();
                     if(flag==1)
                            ES=0;
                            flag=0;
                            switch(a)
                                   case0x2f:                //后退
                                   back();
                                   break;
                                   case0x1f:             //·前进
                                   go();
                                   break;
                                   case0x3f:                     //左转
                                   left();
                                   break;
                                   case0x4f:                     //右转
                                   right();
                                   break;
                                   case0xa0:                    //避障模式
                                   bizhang();
                                   break;
                                   case0xb0:                    //旋转模式
                                   spin();
                                   break;
                                   case0xc0:                    //走8字模式
                                   bazizou();
                                   case0xd0:                    //跟随模式
                                   gensui();
                     ES=1;
void ser() interrupt 4
       RI=0;
       a=SBUF;
       flag=1;
funcation.h
#include<reg52.h>
sbit A0 = P1^0;
sbit A1 = P1^1;
sbit A2 = P1^2;
sbit A3 = P1^3;
uchar spinstop;
uchar bazizoustop;
//uchar fangi;
//uchar qii;
void delay3()
       uinti=20000;
       while(--i);
void init()              //初始化
       TMOD=0x21;
       TH1=0xfd;
       TL1=0xfd;
       TR1=1;
       REN=1;
       SM0=0;
       SM1=1;
       EA=1;
       ES=1;
       EX0=1;
void delay()           //延时函数
       uinti=2000;
       while(--i);
void go()
                                    A0 = 1;
                                    A1 = 0;
                                    A2 = 1;
                                    A3 = 0;
                                    delay();
                                    P1=0;
void back()
                                    A0 = 0;
                                    A1 = 1;
                                    A2 = 0;
                                    A3 = 1;
                                     delay();
                                    P1=0;
void left()
                                    A0 = 0;
                                    A1 = 1;
                                    A2 = 1;
                                    A3 = 0;
                                     delay();
                                    P1=0;
void right()
                                    A0 = 1;
                                    A1 = 0;
                                    A2 = 0;
                                    A3 = 1;
                                     delay();
                                    P1=0;
void spin()
       while(1){
                                          right();
                                          RI=0;
                                          spinstop=SBUF;
                                          if(spinstop==0xa0)
                                                 RI=0;
                                                 break;
void go3()
                                    A0 = 1;
                                    A1 = 0;
                                    A2 = 1;
                                    A3 = 0;
                                    delay3();
                                    P1=0;
void left3()
                                    A0 = 0;
                                    A1 = 1;
                                    A2 = 1;
                                    A3 = 0;
                                     delay3();
                                    P1=0;
void right3()
                                    A0 = 1;
                                    A1 = 0;
                                    A2 = 0;
                                    A3 = 1;
                                     delay3();
                                    P1=0;
void stop3()
       P1=0;
       delay3();
void bazizou()
       while(1){
                                          go3();go3();stop3();
                                          left3();left3();left3();stop3();
                                          go3();go3();go3();go3();stop3();
                                          right3();right3();right3();stop3();
                                          RI=0;
                                          bazizoustop=SBUF;
                                          if(bazizoustop==0xd0)
                                                 RI=0;
                                                 break;
bizhang.h
#include<reg52.h>
#include <intrins.h>
sbit trig=P2^4;
sbit Echo=P2^5;
unsigned int duration,distance;  //测距时间,距离
uchar bizhangstop;             //避障模式停止标志
uchar gensuistop;               //跟随模式停止标志
void delay2()
       uinti=20000;
       while(--i);
void trigger()    //超声波启动脉冲
       trig= 0;
       trig= 1;
       _nop_();_nop_();_nop_();_nop_();
       trig=0;
void calc()     //计算距离
       duration=TH0*256+TL0;
       duration*=12/11.0592;
       distance=duration*0.017;
       TH0=0;
       TL0=0;
void loop()      //启动脉冲后等待接受时间与计算距离
       trigger();
       while(!Echo);
       TR0=1;
       while(Echo);
       TR0=0;
       calc();
void setup()
       TH0=0;
       TL0=0;
void go2()
                                    A0 = 1;
                                    A1 = 0;
                                    A2 = 1;
                                    A3 = 0;
                                    delay();
                                    P1=0;
void back2()
                                    A0 = 0;
                                    A1 = 1;
                                    A2 = 0;
                                    A3 = 1;
                                     delay2();
                                          delay2();
                                          delay2();
                                          delay2();
                                    P1=0;
void left2()
                                    A0 = 0;
                                    A1 = 1;
                                    A2 = 1;
                                    A3 = 0;
                                    delay2();
                                    P1=0;
/*void right2()
                                    A0 = 1;
                                    A1 = 0;
                                    A2 = 0;
                                    A3 = 1;
                                     delay2();
                                    P1=0;
void stop2()
                                    P1=0;
                                   delay2();
void bizhang()
                     setup();
                                          RI=0;
                                          bizhangstop=SBUF;
                                          if(bizhangstop==0xb0)  //停止标志
                                                 RI=0;
                                                 break;
                                          loop();
                                          if(distance>=25)  //当障碍物距离大于25cm,前进
                                                        go();
                                          if(distance<25)    //当障碍物距离小于25cm,迂回
                                                        stop2();back2();delay2();left2();
                                                               delay2();go2();delay2();
void gensui()
                     setup();
                                          RI=0;
                                          gensuistop=SBUF;
                                          if(gensuistop==0xc0)
                                                 RI=0;
                                                 break;
                                          loop();
                                          if(distance>=15&&distance<=30)
                                          {go();}else{stop2();}
收藏收藏1 分享淘帖 顶 踩
ID:1 发表于 2019-6-17 13:00 | 只看该作者
本帖需要重新编辑补全电路原理图,源码,详细说明与图片即可获得100+黑币(帖子下方有编辑按钮)
