查看: 2733|回复: 0
用ADC0808做的模数转换电压表
代码:#include<reg51.h>#include<intrins.h>
sbit ST=P2^0;
sbit OE=P2^2;
sbit ALE=P2^3;
sbit EOC=P2^1;
sbit CLK=P2^4;
long int datas,bai,she,ge;
uchar duan;
uchar code num[]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f};
uchar code num_dot[]={0xbf,0x86,0xdb,0xcf,0xe6,0xed};
uchar code wei[]={0x0d,0x0b,0x07};
void delay(uint z)
uchar i;
while(z--)
for(i=0;i<120;i++);
void display()
uchar i=0;
bai=(datas*500/255)/100;
she=(datas*500/255)/10 % 10;
ge=(datas*500/255) % 10;
for(i=0;i<3;i++)
P3=wei[i];
if(i==0){duan=num_dot[bai];}
else if(i==1){duan=num[she];}
else if(i==2){duan=num[ge];}
P0=duan;
delay(2);
TMOD=0x02;
TH0=0x216;
TL0=0x216;
EA=1;
ET0=1;
TR0=1;
ST=OE=0;
ALE=1;
ST=1;
ALE=0;
ST=0;
while(!EOC);
OE=1;
datas=P1;
display();
void inter_1() interrupt 1
CLK=~CLK;
仿真图
仿真图
