查看: 3145|回复: 5
求大佬给看看怎么修改,程序仿真的话,主程序总是只运行到while(1)
200黑币
#include<reg51.h>
#include<intrins.h>
#define Enable();EA=1;
#define Disable();EA=0;
#define ZhengZhuan();PIN_Motor_A=0;PIN_Motor_B=1;
#define Stop();PIN_Motor_A=1;PIN_Motor_B=1;
#define FanZhuan();PIN_Motor_A=1;PIN_Motor_B=0;
sbit E=P2^7;                //1602使能引脚
sbit RW=P2^6;                //1602读写引脚
sbit RS=P2^5;//1602数据/命令选择引脚
sbit RELAY=P3^0;
int n;
n=100;
char *p1;
uchar flag;
uchar code tab1[]="Zhuangtai *p1";  //要显示什么就在这儿改
uchar code tab2[]="n=100cm";  //[size=15.5555562973022px]要显示什么就在这儿改
void delay(uint del)   //延时1ms
     uint i,j;
   for(i=0;i<del;i++)
   for(j=0;j<=168;j++);
void writecmd(uchar com)  //写指令
   E=0;
   RS=0;
   RW=0;
   P0=com;
   delay(2);
   E=1;
   delay(2);
   E=0;
void writedata(uchar dat)//写数据
  E=0;
  RS=1;
  RW=0;
  P0=dat;
  delay(2);
  E=1;
  delay(2);
  E=0;
void init(void)               //初始化
delay(15);
writecmd(0x38);
delay(5);
writecmd(0x38);
delay(5);
writecmd(0x38);
writecmd(0x38);
writecmd(0x08);
writecmd(0x01);
writecmd(0x06);
writecmd(0x0c);
void Display()
  uchar j;
  init();
  writecmd(0x80);    //告诉液晶在哪个地方显示 (设置地址指针)//80H+00
  for(j=0;j<16;j++)  //有16个字符,要循环16次
   writedata(tab1[j]);
        delay(2);
  writecmd(0x80+0x40); //再设置第二行的起始位置80H+40H
  { writedata(tab2[j]);
         delay(2);
         while(1);
sbit s1 = P1^0;
sbit s2 = P1^1;
sbit s3 = P1^2;//按键定义,s1启动,s2加1,s3减1
sbit a = P2^0;sbit b = P2^1;sbit c = P2^2;sbit d = P2^3;//脉冲信号输入端定义
#define Coil_a {a=1;b=0;c=0;d=0;}//A相通电,其他相断电
#define Coil_b {a=0;b=1;c=0;d=0;}//B相通电,其他相断电
#define Coil_c {a=0;b=0;c=1;d=0;}//C相通电,其他相断电
#define Coil_d {a=0;b=0;c=0;d=1;}//D相通电,其他相断电
//================================定时器0/1初始化函数================================
void T0_T1_init()
TMOD = 0x11;//定时器0/1均工作于方式1,16位计时方式
TR1 = 0;
ET1= 1;//开定时器中断
EA = 1;//开总中断
//================================ms级延时函数=======================================
void delay1m(uint x)
    uint i,j;
    for(i=0;i<x;i++)      //连数x次,约 x ms
      for(j=0;j<120;j++);   //数120 次,约1 ms
//=================按键函数=================================
void keyscan()
     if(s1==0)
      delay(5);
   if(s1==0)
       while(!s1);
    flag=!flag;
       while(!s1);
    flag=0;
     if(flag==0)
         if(s2==0)
     delay(5);
     if(s2==0)
           while(!s2);
     n++;
     if(n>199)n=199;
    if(s3==0)
     delay(5);
     if(s3==0)
           while(!s3);
     n--;
     if(n<=0)
     n=0;
//================================主函数=============================================
uchar j;
Display();
  if(s1==0)
   delay1m(3);
   if(flag==1&&n>0)
    for(j=0;j<n;j++)
       a=1;
       a=0;
       delay(3);
                   RELAY=0;
                delay(500);
                RELAY=1;
最佳答案
查看完整内容
楼主的显示程序里多了个死循环while(1),程序怎么运行下去?main程序的主循环没有调用按键程序和显示程序,你怎么操作和显示?
ID:213173 发表于 2019-6-21 18:07 | 只看该作者
ID:568698 发表于 2019-6-22 08:21 来自触屏版 | 只看该作者
去搜索看一下while的用法,要知道程序是不可能无线次数运行下去的
ID:207421 发表于 2019-6-22 11:35 | 只看该作者
先把 void Display() 函数里面的 while(1); 删除,然后修改  main() 里面的代码:
        uchar j;
        //Display();
                if(s1==0)
                        delay1m(3);
                        if(flag==1&&n>0)
                                for(j=0;j<n;j++)
                                        a=1;
                                a=0;
                                delay(3);
                                RELAY=0;
                                delay(500);
                                RELAY=1;
                Display();  //显示函数放在这里
ID:567356 发表于 2019-6-23 14:22 | 只看该作者
wulin 发表于 2019-6-21 18:07
楼主的显示程序里多了个死循环while(1),程序怎么运行下去?main程序的主循环没有调用按键程序和显示程序 ...
大佬,关于步进电机运转和LCD1602能够根据按键改变某些显示,需要用到哪些指令啊??
ID:213173 发表于 2019-6-24 11:12 | 只看该作者
示例程序+仿真.zip (60.12 KB, 下载次数: 5)
