查看: 2502|回复: 1
STM32驱动FDC2214源程序
ID:571380 发表于 2019-6-25 08:51 | 显示全部楼层 |阅读模式
是基于32的一款源程序代码,根据不同显示屏自己调节显示
  1. #include "led.h"
  2. #include "delay.h"
  3. #include "key.h"
  4. #include "sys.h"
  5. #include "lcd.h"
  6. #include "usart.h"
  7. #include "usmart.h"
  8. #include "24cxx.h"
  9. #include "myiic.h"
  10. #include "FDC2X2X_CMD.h"
  11. #include "FDC2214.h"
  12. //**特别注意:使用时SDA、SCL要接4.7K上拉电阻**//
  13. //**寄存器值的读取及电容的计算具体在 FDC2214_read_CHx() 中**//
  14. //要写入到24c02的字符串数组
  15. const u8 TEXT_Buffer[]={"WarShipSTM32 IIC TEST"};
  16. #define SIZE sizeof(TEXT_Buffer)
  17. int main(void)
  18. {
  19.         delay_init();                     //延时函数初始化
  20.         NVIC_Configuration();          //设置NVIC中断分组2:2位抢占优先级,2位响应优先级
  21.         uart_init(9600);                 //串口初始化为9600
  22.         KEY_Init();
  23.         LED_Init();                             //LED端口初始化
  24.         LCD_Init();
  25.         usmart_dev.init(72);        //初始化USMART
  26.         AT24CXX_Init();                        //IIC初始化
  27.         FDC2214_Init();
  28.         while(1)
  29.         {
  30. //   FDC2214_read_CHx(0);
  31.          printf("%f    pf\r\n",FDC2214_read_CHx(0));
  32.          delay_ms(1000);
  33.         }
  34. }
  2. #include "myiic.h"
  3. #include "delay.h"
  4. #include "FDC2X2X_CMD.h"
  5. #include "usart.h"
  6. u32 data_Fdc2214_H;
  7. u32 data_Fdc2214_L;
  8. float FDC2214_read_CHx(u8 CHx)        //读Channel x Conversion Result
  9. {
  10.         u8 reg_addr1 = 0;        //MSB地址
  11.         u8 reg_addr = 0;        //LSB地址
  12.         u32 data_H = 0;                        //接收到的数据
  13.         u32 data1_L = 0;
  14.         float   conver = 0;   //最终的转换的结果
  15. //        static u32 data_H_last = 0;
  16.         switch(CHx)
  17.         {
  18.                 case 0:
  19.                 {
  20.                         reg_addr1 = LDC13xx16xx_CMD_DATA_MSB_CH0;
  21.                         reg_addr         = LDC13xx16xx_CMD_DATA_LSB_CH0;        //不知道LSB寄存器有什么用,手册也没见有
  22.                 }break;
  23.                 case 1:
  24.                 {
  25.                         reg_addr1 = LDC13xx16xx_CMD_DATA_MSB_CH1;
  26.                         reg_addr         = LDC13xx16xx_CMD_DATA_LSB_CH1;
  27.                 }break;
  28.                 case 2:
  29.                 {
  30.                         reg_addr1 = LDC13xx16xx_CMD_DATA_MSB_CH2;
  31.                         reg_addr         = LDC13xx16xx_CMD_DATA_LSB_CH2;
  32.                 }break;
  33.                 case 3:
  34.                 {
  35.                         reg_addr1 = LDC13xx16xx_CMD_DATA_MSB_CH3;
  36.                         reg_addr         = LDC13xx16xx_CMD_DATA_LSB_CH3;
  37.                 }break;
  38.                 default: return 0;        //输入错误
  39.
  40.         }
  41.
  42.         //printf("%d \r\n",LCD_read_16bit(reg_addr1));
  43.         //printf("%d \r\n",LCD_read_16bit(reg_addr));
  44.         data_H = FDC_read_16bit(reg_addr1);        //读取寄存器值  读高位
  45.         data1_L = FDC_read_16bit(reg_addr);        //读取寄存器值   读低位
  46. //        printf("%X \r\n",data_H);
  47. //        printf("%X \r\n",data1_L);
  48.
  49. //**加入此判断大电容无法使用**//
  50. //        if(data_H>400)
  51. //        {
  52. //        data_H_last = data_H;
  53. //        conver = ( ((data_H & 0x0FFF)<<16)|(data1_L) );         //融合结果
  54.
  55. //        }
  56. //        else
  57. //        {
  58. //        conver = ( ((data_H_last & 0x0FFF)<<16)|(data1_L) );         //融合结果
  59. //
  60. //        }
  61.
  62.         conver = ( ((data_H & 0x0FFF)<<16)|(data1_L) );         //融合结果
  63.
  64.         data_Fdc2214_H = data_H;
  65.         data_Fdc2214_L = data1_L;
  66.
  67. //***注意Init中各通道寄存器0x10-0x17的时钟分频***//
  68. //*******以下四步计算根据datasheet P19公式*******//
  69.         conver = (conver * 40000000.0F)/268435456.0F;//得到F(sensorx)
  70.
  71.         conver = conver * 2.0F *3.1515926F;
  72.         conver = 1.0F/((conver * conver) * 0.000018F);
  73.         conver = conver - 0.000000000033F;
  74.
  75.
  76.         conver = conver * 1000000000000.0F;//F转换pF;
  77.
  78.
  79.         return conver;
  80.
  81. }
  82. void FDC2214_Init(void)        //初始化LDC1314和I2C
  83. {
  84.         IIC_Init();                                                        //IIC初始化
  85.         LDC_ADDR = 0;        //LDC的7bit地址为0X2A,注意是7bit 即 0101 010_  最低位为读写位
  86.         LDC_SD = 0;                //退出Shutdown Mode
  87.         delay_ms(500);        //延时500ms
  88.
  89.                 //根据时间要求(100 SPS)计算的参考计数分辨率要求
  90.         FDC_write_16bit(LDC13xx16xx_CMD_REF_COUNT_CH0,0Xffff);
  91.         FDC_write_16bit(LDC13xx16xx_CMD_REF_COUNT_CH1,0Xffff);
  92.         FDC_write_16bit(LDC13xx16xx_CMD_REF_COUNT_CH2,0Xffff);
  93.         FDC_write_16bit(LDC13xx16xx_CMD_REF_COUNT_CH3,0Xffff);
  94.
  95.         FDC_write_16bit(LDC13xx16xx_CMD_SETTLE_COUNT_CH0,0X0400);
  96.         FDC_write_16bit(LDC13xx16xx_CMD_SETTLE_COUNT_CH1,0X0400);
  97.         FDC_write_16bit(LDC13xx16xx_CMD_SETTLE_COUNT_CH2,0X0400);
  98.         FDC_write_16bit(LDC13xx16xx_CMD_SETTLE_COUNT_CH3,0X0400);
  99.
  100.         FDC_write_16bit(LDC13xx16xx_CMD_CLOCK_DIVIDERS_CH0,0X1001);
  101.         FDC_write_16bit(LDC13xx16xx_CMD_CLOCK_DIVIDERS_CH1,0X1001);
  102.         FDC_write_16bit(LDC13xx16xx_CMD_CLOCK_DIVIDERS_CH2,0X1001);
  103.         FDC_write_16bit(LDC13xx16xx_CMD_CLOCK_DIVIDERS_CH3,0X1001);
  104.
  105.         FDC_write_16bit(LDC13xx16xx_CMD_ERROR_CONFIG,0X0001);
  106.
  107.         FDC_write_16bit(LDC13xx16xx_CMD_MUX_CONFIG,0x820D);
  108.
  109.         FDC_write_16bit(LDC13xx16xx_CMD_DRIVE_CURRENT_CH0,0x8c40);
  110.         FDC_write_16bit(LDC13xx16xx_CMD_DRIVE_CURRENT_CH1,0x8c40);
  111.         FDC_write_16bit(LDC13xx16xx_CMD_DRIVE_CURRENT_CH2,0x8c40);
  112.         FDC_write_16bit(LDC13xx16xx_CMD_DRIVE_CURRENT_CH3,0x8c40);
  113.         FDC_write_16bit(LDC13xx16xx_CMD_CONFIG,0x1e01);                //bit13 清零 退出睡眠模式
  114.
  115. }
FDC2214.7z (243.82 KB, 下载次数: 31)
ID:267330 发表于 2019-7-15 17:09 | 显示全部楼层
要学习啊
