查看: 4117|回复: 0
模8计数器verilog程序
ID:576309 发表于 2019-7-2 12:27 来自触屏版 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
模8计数器的功能模块如下:
module counter_8(clock,clear,q);
input clock,clear;
output[2:0] q;
reg[2:0] q;
always @(posedge clock or negedge clear)
begin
   if(!clear)
     q<=0;
     q <= q +1;
   end
endmodule
测试激励如下:
module test_counter8;
reg clk,clr;
wire[2:0] q;
counter_8 counter(.clock(clk),.clear(clr),.q(q));
initial
   clk = 0;
always
   #100 clk = ~clk;
initial
begin
   clr = 0;
   #50 clr = 1;
   #200 clr = 0;
   #50 clr = 1;
end
initial
   $monitor($time,"clear= %b,clock= %b,q= %b",clr,clk,q);
endmodule
