查看: 5365|回复: 3
直流电机正反转,PWM占空比调速,测速,数码管显示实时速度
直流电机正反转,pwm占空比调速,测速,数码管显示当前的速度
#include <reg52.h>
sbit jiasu=P1^0;          //占空比加
sbit jiansu=P1^1;          //占空比减
sbit zhengz=P1^2;          //正传
sbit fanz=P1^3;              //反转
sbit tingz=P1^4;          //停止
sbit IN1=P3^0;                        //用于正传
sbit IN2=P3^1;                        //用于反转
sbit pwm=P1^7;                        //调速
uint zhuansu,count,flag,r=25;
uchar code duanma[]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f,0x77,0x7c,0x39,0x5e,0x79,0x71};//共阴管
void delay(uint z)   //延时1ms函数
uint x,y;
for(x=0;x<z;x++)
for(y=0;y<110;y++);
/*void  pwm(uint t)    //调速
        ENA=0;
        delay(95);
        ENA=1;
        delay(t);
void  zz()
        IN1=1;
        IN2=0;
void  fz()
        IN1=0;
        IN2=1;
void  stop()
        IN1=0;
        IN2=0;
void init()//初始化函数
  TMOD=0x51;               //定时器,1计数,T0,T1方式1  G,C/t,M0,M1
  TH0=(65535-10000)/256;
  TL0=(65535-10000)%256;   //定时器0装入初值
  EA=1;                    //开总中断
  ET0=1;                   //定时器0开中断
  TR0=1;
  TH1=0x00;
  TL1=0x00;                //定时1计数初值
  ET1=1;                   //定时器1开中断
  TR1=1;
  //EX0=1;
  //IT0=1;
  //count=0;
// flag=0;
void  t11()
  TH1=0x00;
  TL1=0x00;                //定时1计数初值
  ET1=1;                   //定时器1开中断
  TR1=1;
void keyscan()  //控制函数
        if(jiasu==0)
                while(jiasu==0)
                r++;
        if(jiansu==0)
                while(jiansu==0)
                r--;
void display(uint x)                   //速度显示
  if(x>10000)
          P2=0xfd;
          P0=duanma[x/10000];         //wan
          delay(5);
          P2=0xfb;
          P0=duanma[x%10000/1000]; //qian
          delay(5);
          P2=0xf7;
          P0=duanma[x%1000/100]; //bai
          delay(5);
          P2=0xef;
          P0=duanma[x%100/10]; //shi
          delay(5);
          P2=0xdf;
          P0=duanma[x%10]; //ge
          delay(5);
          else if(x>1000)
          P2=0xfb;
          delay(5);
          P2=0xf7;
          delay(5);
          P2=0xef;
          delay(5);
          P2=0xdf;
          delay(5);
        else if(x>100)
          P2=0xf7;
          delay(5);
          P2=0xef;
          delay(5);
          P2=0xdf;
          delay(5);
        else if(x>10)
          P2=0xef;
          delay(5);
          P2=0xdf;
          delay(5);
          P2=0xdf;
          delay(5);
    init();              //初始化
        if(tingz==0)
                stop();
        else if(fanz==0)
                fz();
        else zz();
            keyscan();                        //调速程序
         display(zhuansu);        //显示转速
/*void  t1()interrupt 0   using 1        //外部中断0脉冲技术记录电机的转速 电机转一圈count加一
  count++  ;
void  t0()interrupt 1   using 2                                  //定时器0显示转速
         count++;
     flag++;
         if(count>50)
         count=0;
         if(count<r)
         pwm=1;
         else pwm=0;
  if(flag==100)                                   //计时到达1s
        zhuansu=(TH1*256+TL1);
        t11();
        flag=0;
     TL0=(65535-10000)%256;//定时10ms  12
电机proteus仿真图
电机proteus仿真图
收藏收藏3 分享淘帖 顶1 踩
ID:475783 发表于 2019-7-14 10:15 | 只看该作者
谢谢楼主的分享,回头我自个儿也试试
ID:580629 发表于 2019-7-19 15:44 | 只看该作者
我就凶猛 发表于 2019-7-14 10:15
谢谢楼主的分享,回头我自个儿也试试
我用PROTEUS调试,加减速没有用,数码管乱码的???
ID:680763 发表于 2020-3-23 14:52 | 只看该作者
这个我也试验了,等完全解决,再来分享
