查看: 2973|回复: 0
单片机智能循迹小车电路设计图 仿真图 程序代码Demo
  1. #include<reg52.h>
  3. #define uint unsigned int
  4. uchar temp,signal,tt1;
  5. void delay_1ms(uint d)
  6. {
  7.         uint i;
  8.         while(d--)
  9.                 for(i=0;i<75;i++);
  10. }
  11. void motor_run()                   //电机起动
  12. {
  13.           P1=0x35;
  14.         delay_1ms(150);
  15.         P1=0x00;
  16.         delay_1ms(20);
  17. /*        ENA=1;
  18.         OUT1=0;
  19.         OUT2=1;
  20.         delay_1ms(800);
  21.         OUT2=0;
  22.         delay_1ms(200);
  23.
  24.         ENB=1;
  25.         OUT4=0;
  26.         OUT3=1;
  27.         delay_1ms(800);
  28.         OUT3=0;
  29.         delay_1ms(200);
  30. */
  31. }
  32. void motor_left()                         //左进
  33. {
  34.         P1=0x30;
  35.         delay_1ms(150);
  36.         P1=0x00;
  37.         delay_1ms(20);
  38. }
  39. void motor_right()                   //右进
  40. {
  41.         P1=0x05;
  42.         delay_1ms(150);
  43.         P1=0x00;
  44.         delay_1ms(20);
  45. }
  46. void motor_big_right()                         //粗右进
  47. {
  48.         P1=0x55;
  49.         delay_1ms(150);
  50.         P1=0x00;
  51.         delay_1ms(20);
  52. }
  53. void motor_big_left()
  54. {
  55.         P1=0x33;
  56.         delay_1ms(150);
  57.         P1=0x00;
  58.         delay_1ms(20);
  59. }
  60. void motor_stop()                                        //电机停止
  61. {
  62.          P1=0x00;
  63. }
  64. void motor_back()
  65. {
  66.         P1=0x53;
  67. }
  68. void main()
  69. {
  70.         tt1=0;
  71.         EA=1;
  72.         ET1=1;
  73.         TR1=1;
  74.         TMOD=0x01;
  75.         TH1=-(1000/256);
  76.         TL1=-(1000%256);
  77.         while(1)
  78.         {
  79.                  temp=P2;
  80.                 signal=temp&0xff;                   //得到红外反向信号
  81.                 switch(signal)
  82.                 {
  83.                         case 0xff:           //无偏差
  84.                                 motor_run();
  85.                                 break;
  86.                         case 0xfd:           //1轮右偏
  87.                                 motor_left();
  88.                                 break;
  89.                         case 0xef:            //4轮左偏
  90.                                 motor_right();
  91.                                 break;
  92.                         case 0xfb:     //2轮右偏出轨
  93.                         case 0xf9:           //1、2轮右偏
  94.                                 motor_big_left();
  95. //                                delay_1ms(10);
  96.                                 break;
  97.                         case 0xdf:           //5左偏出轨
  98.                         case 0xcf:      //4、5轮左偏
  99.                                 motor_big_right();
  100. //                                delay_1ms(10);
  101.                                 break;
  102.                         case 0xfe:           //0最右偏出轨
  103.                         case 0xfa:
  104.                                 motor_big_left();
  105. //                                delay_1ms(10);
  106.                                 break;
  107.                         case 0xbf:     //6最左偏出轨
  108.                         case 0x9f:
  109.                                 motor_big_right();
  110. //                                delay_1ms(10);
  111.                                 break;
  112.
  113.                         case 0xeb:         //前两传感器压在黑线上
  114.                         case 0xdb:         //后两传感器压在黑线上
  115.                         case 0xbe:         //中间两传感器压在黑线上
  116.                         case 0xac:                 //前四传感器压在黑线上
  117.                         case 0x9a:                //后四传感器压在黑线上
  118.                                 motor_back();
  119.                                 delay_1ms(200);
  120.                                 motor_stop();
  121.
  122. //                                delay_1ms(1000);
  123.                         default:
  124.                                 break;
  125.                 }
  126.         }
  127.
  128. }
  129. void time1() interrupt 3
  130. {
  131.         TH1=-(1000/256);
  132.         TL1=-(1000%256);
  133.         tt1++;
  134.         if(tt1==300)
  135.         {
  136.                 motor_back();
  137.         //        delay_1ms(1);
  138.                 tt1=0;
  139.         }
  140. }
智能循迹小车电路图和程序及仿真图.rar (600.6 KB, 下载次数: 26)
