查看: 2572|回复: 0
(15系列单片机pwm模块)在1602上显示占空比,并调节占空比
ID:480680 发表于 2019-7-27 09:25 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
#include"15.h"
#define  uint  unsigned int
#define  uchar  unsigned char
sbit lcden=P2^7;
sbit lcdrw=P2^6;
sbit lcdrs=P2^5;
#define CCP_S0 0x10                         //P_SW1.4
#define CCP_S1 0x20                         //P_SW1.5
sbit s1=P2^0;
sbit s2=P2^1;
float zhankongbi=0x80;
uchar code table1[]="zkb";
void display1();
void pwminit();
void keyscan();
void delay(uint z)
  uint i,j;
   for(i=z;i>0;i--)
    for(j=110;j>0;j--);
void pwminit()
                CMOD=0x02;
//                               CCON=0X00;
                CL=0x00;
                CH=0x00;
//                            PCA_PWM0=0x00;
                CCAPM0=0x42;
                CCAP0H=0xff;
                CCAP0L=0xff;
                CR=1;
void pwmshe(uchar t)//这是占空比调节函数
                CCAP0H=t;
                CCAP0L=t;
void write_com(uchar com)//        液晶写命令函数
      lcdrs=0;
      lcdrw=0;
      P0=com;
      delay(5);
      lcden=1;
      delay(5);
      lcden=0;
void write_date(uchar date)//液晶写数据函数
     lcdrs=1;
     lcdrw=0;
     P0=date;
     delay(5);
     lcden=1;
     delay(5);
     lcden=0;
void init()        //初始化函数
        uchar num;
        write_com(0x38);
        write_com(0x0c);
        write_com(0x06);
        write_com(0x01);
        write_com(0x80);//设置显示初始坐标
        for(num=0;num<3;num++)
                        write_date(table1[num]);
                        delay(5);
        P0M0 = 0x00;
    P0M1 = 0x00;
    P1M0 = 0x00;
    P1M1 = 0x00;
    P2M0 = 0x00;
    P2M1 = 0x00;
    P3M0 = 0x00;
    P3M1 = 0x00;
    P4M0 = 0x00;
    P4M1 = 0x00;
    P5M0 = 0x00;
    P5M1 = 0x00;
        P6M0 = 0x00;
    P6M1 = 0x00;
        P7M0 = 0x00;
    P7M1 = 0x00;
        ACC = P_SW1;
    ACC &= ~(CCP_S0 | CCP_S1);              //CCP_S0=0 CCP_S1=0
    P_SW1 = ACC;                            //(P1.2/ECI, P1.1/CCP0, P1.0/CCP1, P3.7/CCP2)
//  ACC = P_SW1;
//  ACC &= ~(CCP_S0 | CCP_S1);              //CCP_S0=1 CCP_S1=0
//  ACC |= CCP_S0;                          //(P3.4/ECI_2, P3.5/CCP0_2, P3.6/CCP1_2, P3.7/CCP2_2)
//  P_SW1 = ACC;
//  ACC = P_SW1;
//  ACC &= ~(CCP_S0 | CCP_S1);              //CCP_S0=0 CCP_S1=1
//  ACC |= CCP_S1;                          //(P2.4/ECI_3, P2.5/CCP0_3, P2.6/CCP1_3, P2.7/CCP2_3)
//  P_SW1 = ACC;
        init();
        pwminit();
    display1();
        while(1) //进入主程序大循环
                  keyscan();
                          display1();
                  pwmshe(zhankongbi);
void keyscan()
                if(s1==0)
                delay(60);
                if(s1==0)
                          while(!s1);
                    zhankongbi=zhankongbi-10;
                if(s2==0)
             delay(60);
                if(s2==0)
                                while(!s2);
                    zhankongbi=zhankongbi+10;
                        if(zhankongbi>256)
                        zhankongbi=0x80;
void display1(float m)
                float a=0,c=0;
             uchar        b=0;
                          m=zhankongbi;
         m=(float)m*100/256;
             a=m/100;
             b=(uchar)m%100/10;
             c=(uchar)m%10;
        write_com(0x84);
        write_date(a+0x30);
        write_com(0x85);
        write_date(b+0x30);
        write_com(0x86);
        write_date(c+0x30);
        write_com(0x87);
        write_date('%');
        write_com(0x83);
        write_date(':');
