查看: 3771|回复: 4
单片机+16*80点阵屏仿真失败.求找错误
请高手帮忙看看哪里错了,16*80点阵屏的问题。
  1. <blockquote>#include <reg51.h>
1680.rar (92.76 KB, 下载次数: 11)
ID:328014 发表于 2019-7-28 17:52 | 只看该作者
你的程序不完整 应该是你程序有问题
ID:431364 发表于 2019-7-28 22:36 | 只看该作者
void yiwei (int i,int j,int k)
   char n;
   int di;
    for (n=8;n>0;n--)
                   { CLK=0;
                delay(1);
                di=LEDZK [i][j][k];
         DI=(di&0x01);
                  CLK=1;
                 di>>=1 ;
void xschs (int s)
                   if(s>7)
                  { P2=0x00;
                   P0=xscsj[s-8];}
                         {P2=xscsj[s];
                           P0=0x00;}
void main() /*主函数*/
{   int  i=0,j=0,k=0;
     int s;
     s=0;
         LEDEA=0;
      LE=0;
     CLK=0;
             for(i=0;i<4;i++)
                     yiwei(i,0,k),
                   yiwei(i,1,k);
                    LE=1;
                 k++;
                 if(k>15)
                 k=0;
                   xschs(s);
                        s++;
                     if(s>15) s=0;
                         LE=0;
ID:431364 发表于 2019-7-29 21:39 | 只看该作者
可以了
#include <reg52.h>
sbit  DI = P3^7;            //HC595第14脚,串行数据
sbit   CLK = P3^1;           // HC595第11脚 ,数据时钟
sbit   LE = P3^2;           //                  HC595第12脚 ,锁存时钟
sbit     LEDEA = P3^3;   //HC595第13脚 ,输出控制
char code  xscsj[] =
           // {0x01,0x02,0x04,0x08,0x10,0x20,0x40,0x80};
        { 0xfe,0xfd,0xfb,0xf7,0xef,0xdf,0xbf,0x7f};
char code zk [5][2][16] =
          {{ 0x08,0x04,0x02,0x1F,0x10,0x10,0x1F,0x10,0x10,0x1F,0x00,0x00,0x7F,0x00,0x00,0x00,
                0x08,0x10,0x20,0xFC,0x84,0x84,0xFC,0x84,0x84,0xFC,0x80,0x80,0xFF,0x80,0x80,0x80,
       }},        /*--  文字:  单  --*/
         {{           /*--  文字:  片  --*/
/*--  宋体12;  此字体下对应的点阵为:宽x高=16x16   --*/
             0x00,0x10,0x10,0x10,0x10,0x1F,0x10,0x10,0x10,0x1F,0x10,0x10,0x10,0x20,0x20,0x40,
                                0x40,0x40,0x40,0x40,0x40,0xFC,0x00,0x00,0x00,0xE0,0x20,0x20,0x20,0x20,0x20,0x20,
                           /*--  文字:  机  --*/
                                         0x10,0x11,0x11,0x11,0xFD,0x11,0x31,0x39,0x55,0x55,0x91,0x11,0x11,0x12,0x12,0x14,
                                         0x00,0xF0,0x10,0x10,0x10,0x10,0x10,0x10,0x10,0x10,0x10,0x12,0x12,0x12,0x0E,0x00,
                   /*--  文字:  学  --*/
                                 0x22,0x11,0x11,0x00,0x7F,0x40,0x80,0x1F,0x00,0x01,0xFF,0x01,0x01,0x01,0x05,0x02,
                                 0x08,0x08,0x10,0x20,0xFE,0x02,0x04,0xE0,0x40,0x80,0xFE,0x00,0x00,0x00,0x00,0x00,
                                 /*--  文字:  习  --*/
                                  0x00,0x7F,0x00,0x00,0x08,0x04,0x02,0x02,0x00,0x01,0x0E,0x70,0x20,0x00,0x00,0x00,
                                  0x00,0xF8,0x08,0x08,0x08,0x08,0x08,0x08,0x68,0x88,0x08,0x08,0x08,0x08,0x50,0x20,
void delay(int z)         //延时函数
                int x;
                for (x=0; x<z; x++);
void yiwei (char i, char j,char k)
   char n;
  char di;
    di=zk  [i] [j][k];
    for (n=0;n<8;n++)
                   { CLK=0;
                   DI=(di&0x01)        ;
                    // if(di&0x01)
                         // DI=1;
                        // else
                        // DI=0;
                  CLK=1;
                 di>>=1 ;
void xschs (int s)
                   if(s>7)
                  { P2=0xff;
                   P0=xscsj[s-8];}
                         {P2=xscsj[s];
                           P0=0xff;}
void main() /*主函数*/
{   char  i=0,j=0,k=0;
     int s;
     s=0;
         LEDEA=0;
      LE=0;
     CLK=0;
              for(i=5;i>0;i--)
                     yiwei((i-1),1,k),
                   yiwei((i-1),0,k);
                    LE=1;
                 delay(10) ;
                 k++;
                 if(k>15)
                 k=0;
                   xschs(s);
                        s++;
                     if(s>15) s=0;
                         LE=0;
                          delay(10) ;
1680.rar
92.59 KB, 下载次数: 17
ID:431364 发表于 2019-7-31 23:04 | 只看该作者
                     yiwei((i-1),1,k),
                   yiwei((i-1),0,k);
                       xschs(s);
                    LE=1;
                 delay(10) ;
                 k++;
                 if(k>15)
                 k=0;
                        s++;
                     if(s>15) s=0;
