查看: 35803|回复: 55
T12白光洛铁PCB原理图开源 Arduino源程序
ID:576039 发表于 2019-7-28 21:13 | 显示全部楼层 |阅读模式
给需要的的人,指证,点评。
2019-07-28_020343.png 2019-07-28_020314.png 2019-07-28_020103.png 0.png 0.png
Arduino源程序如下:
  1. // SolderingStation v0.6
  2. //
  3. // ATmega168/328-controlled Soldering Station for Hakko T12 Tips.
  4. // This version of the code implements:
  5. // - PID control of the heater
  6. // - Temperature measurement of the tip
  7. // - Temperature control via rotary encoder
  8. // - Boost mode by pressing rotary encoder switch
  9. // - Time driven sleep/power off mode according to handle movement
  10. // - Information display on OLED
  11. //
  12. // Future versions may implement:
  13. // - Measurement of input voltage and vcc
  14. // - Buzzer
  15. // - Setup menu
  16. // - Storing default values into the EEPROM
  17. // - Check if iron is connected
  18. //
  19. //
  20. // Clockspeed 16 MHz external.
  21. //
  22. // 2019 by Stefan Wagner
  23. //
  24. // based on the work of Jurgis Bal?iūnas (http://jurgis.me)
  25. // Libraries
  26. #include <PID_v1.h>
  27. #include <U8glib.h>
  28. // Pins
  29. #define SENSOR_PIN    A0        // temperature sense
  30. #define VIN_PIN       A1        // input voltage sense
  31. #define BUZZER_PIN     5        // buzzer
  32. #define BUTTON_PIN     6        // rotary encoder switch
  33. #define ROTARY_1_PIN   7        // rotary encoder 1
  34. #define ROTARY_2_PIN   8        // rotary encoder 2
  35. #define CONTROL_PIN    9        // heater MOSFET PWM control
  36. #define SWITCH_PIN    10        // handle vibration switch
  37. // Temperature control values
  38. #define TEMP_MIN      150       // min selectable temperature
  39. #define TEMP_MAX      400       // max selectable temperature
  40. #define TEMP_DEFAULT  320       // default start setpoint
  41. #define TEMP_SLEEP    150       // temperature in sleep mode
  42. #define TEMP_BOOST     50       // temperature increase in boost mode
  43. #define TEMP_STEP      10       // rotary encoder temp change steps
  44. // Timer values (0 = disabled)
  45. #define TIME2SLEEP     5        // time to enter sleep mode in minutes
  46. #define TIME2OFF      15        // time to shut off heater in minutes
  47. #define TIMEOFBOOST   30        // time of boost mode in seconds
  48. // Define the aggressive and conservative PID tuning parameters
  49. double aggKp=20, aggKi=0, aggKd=1;
  50. double consKp=20, consKi=1, consKd=1;
  51. // Variables for pin change interrupt
  52. volatile uint8_t a0, b0, c0, d0;
  53. volatile int count = TEMP_DEFAULT;
  54. volatile bool handleMoved;
  55. // Variables for temperature control
  56. double Setpoint = TEMP_DEFAULT;
  57. double Input, Output, CurrentTemp, ShowTemp;
  58. // Other variables
  59. bool inSleepMode = false;
  60. bool inOffMode   = false;
  61. bool inBoostMode = false;
  62. uint32_t sleepmillis;
  63. uint32_t boostmillis;
  64. uint8_t  goneMinutes;
  65. uint8_t  goneSeconds;
  66. // Specify the links and initial PID tuning parameters
  67. PID ctrl(&Input, &Output, &Setpoint, aggKp, aggKi, aggKd, REVERSE);
  68. // Setup u8g object (OLED 128x64, Fast I2C)
  69. U8GLIB_SSD1306_128X64 u8g(U8G_I2C_OPT_DEV_0|U8G_I2C_OPT_NO_ACK|U8G_I2C_OPT_FAST);
  70. void setup() {
  71.   // set the pin modes
  72.   pinMode(SENSOR_PIN,   INPUT);
  73.   pinMode(CONTROL_PIN,  OUTPUT);
  74.   pinMode(ROTARY_1_PIN, INPUT_PULLUP);
  75.   pinMode(ROTARY_2_PIN, INPUT_PULLUP);
  76.   pinMode(BUTTON_PIN,   INPUT_PULLUP);
  77.   pinMode(SWITCH_PIN,   INPUT_PULLUP);
  78.   // setup pin change interrupt for rotary encoder
  79.   PCMSK0 = bit (PCINT0);                // Configure pin change interrupt on Pin8
  80.   PCICR  = bit (PCIE0);                 // Enable pin change interrupt
  81.   PCIFR  = bit (PCIF0);                 // Clear interrupt flag
  82.   // prepare and start OLED
  83.   if      ( u8g.getMode() == U8G_MODE_R3G3B2 )   u8g.setColorIndex(255);
  84.   else if ( u8g.getMode() == U8G_MODE_GRAY2BIT ) u8g.setColorIndex(3);
  85.   else if ( u8g.getMode() == U8G_MODE_BW )       u8g.setColorIndex(1);
  86.   else if ( u8g.getMode() == U8G_MODE_HICOLOR )  u8g.setHiColorByRGB(255,255,255);
  87.   // tell the PID to range between 0 and the full window size
  88.   ctrl.SetOutputLimits(0, 255);
  89.   // start PID
  90.   ctrl.SetMode(AUTOMATIC);
  91.   // set initial temperature to default value and clear rotary encoder values
  92.   count = TEMP_DEFAULT;
  93.   a0 = PINB & 1;
  94.   b0 = PIND>>7 & 1;
  95.   // reset sleep timer
  96.   sleepmillis = millis();
  97. }
  98. void loop() {
  99.   BOOSTCheck();       // check and activate/deactivate boost mode
  100.   SLEEPCheck();       // check and activate/deactivate sleep modes
  101.   ADCSample();        // reads temperature and vibration switch of the iron
  102.   PIDUpdate();        // updates the PID and sets the PWM duty cycle for the heater
  103.   OLEDRedraw();       // updates the OLED
  104. }
  105. // check and activate/deactivate boost mode
  106. void BOOSTCheck() {
  107.   // check rotary encoder switch
  108.   uint8_t c = digitalRead(BUTTON_PIN);
  109.   if ( !c && c0 ) {
  110.     inBoostMode = !inBoostMode;
  111.     if (inBoostMode) boostmillis = millis();
  112.     handleMoved = true;
  113.   }
  114.   c0 = c;
  115.   // check timer when in boost mode
  116.   if (inBoostMode) {
  117.     goneSeconds = (millis() - boostmillis) / 1000;
  118.     if (goneSeconds >= TIMEOFBOOST) inBoostMode = false;
  119.   }
  120. }
  121. // check and activate/deactivate sleep modes
  122. void SLEEPCheck() {
  123.   if (handleMoved) {                    // if handle was moved
  124.     handleMoved = false;                // reset handleMoved flag
  125.     inSleepMode = false;                // reset sleep flag
  126.     inOffMode   = false;                // reset off flag
  127.     sleepmillis = millis();             // reset sleep timer
  128.   }
  129.   // check time passed since the handle was moved
  130.   goneMinutes = (millis() - sleepmillis) / 60000;
  131.   if ( (TIME2SLEEP > 0) && (goneMinutes >= TIME2SLEEP) ) inSleepMode = true;
  132.   if ( (TIME2OFF   > 0) && (goneMinutes >= TIME2OFF  ) ) inOffMode   = true;
  133. }
  134. // reads temperature and vibration switch of the iron
  135. void ADCSample() {
  136.   // shut off heater in order to measure temperature and vibration switch
  137.   // this also allows the bootstrap capacitor to recharge
  138.   analogWrite(CONTROL_PIN, 255);
  139.   delayMicroseconds(300);
  140.
  141.   // read temperature and filter ADC by multisampling
  142.   uint16_t adc = 0;
  143.   for (uint8_t i = 0; i < 32; i++)
  144.     adc += analogRead(SENSOR_PIN);
  145.   adc >>= 5;
  146.   // check handle vibration switch
  147.   uint8_t d = digitalRead(SWITCH_PIN);
  148.   if (d != d0) {
  149.     handleMoved = true;
  150.     d0 = d;
  151.   }
  152.
  153.   // turn on again heater
  154.   analogWrite(CONTROL_PIN, Output);
  155.   // apply quadratic equation to get temperature
  156.   double temp = -0.0013*adc*adc + 1.696*adc - 59.284;
  157.
  158.   // additional temperature filtering
  159.   CurrentTemp += (temp-CurrentTemp)*0.05;
  160. }
  161. // updates the PID and sets the PWM duty cycle for the heater
  162. void PIDUpdate() {
  163.   if      (inOffMode)   Setpoint = 0;
  164.   else if (inSleepMode) Setpoint = TEMP_SLEEP;
  165.   else if (inBoostMode) Setpoint = count + TEMP_BOOST;
  166.   else                  Setpoint = count;
  167.
  168.   Input = CurrentTemp;
  169.   double gap = abs(Setpoint-Input); //distance away from setpoint
  170.   if (gap < 20) ctrl.SetTunings(consKp, consKi, consKd);
  171.   else ctrl.SetTunings(aggKp, aggKi, aggKd);
  172.   ctrl.Compute();
  173.   analogWrite(CONTROL_PIN, Output);
  174. }
  175. // updates the OLED
  176. void OLEDRedraw() {
  177.   u8g.firstPage();
  178.   do {
  179.     // draw setpoint temperature
  180.     u8g.setFont(u8g_font_9x15);
  181.     u8g.setFontPosTop();
  182.     u8g.drawStr( 0, 0,  "SET:");
  183.     u8g.setPrintPos(40,0);
  184.     u8g.print(Setpoint, 0);
  185.     // draw status of heater
  186.     u8g.setPrintPos(82,0);
  187.     if      (inOffMode)    u8g.print("  OFF");
  188.     else if (inSleepMode)  u8g.print("SLEEP");
  189.     else if (inBoostMode)  u8g.print("BOOST");
  190.     else if (Output < 180) u8g.print(" HEAT");
  191.     else                   u8g.print(" HOLD");
  192.     // draw current temperature in big figures
  193.     u8g.setFont(u8g_font_fub42n);
  194.     u8g.setFontPosTop();
  195.     u8g.setPrintPos(15,20);
  196.     u8g.print(CurrentTemp, 0);
  197.   } while(u8g.nextPage());
  198. }
  199. // Pin change interrupt service routine for rotary encoder
  200. ISR (PCINT0_vect) {
  201.   uint8_t a = PINB & 1;
  202.   uint8_t b = PIND>>7 & 1;
  203.   if (a != a0) {              // A changed
  204.     a0 = a;
  205.     if (b != b0) {            // B changed
  206.       b0 = b;
  207.       count = constrain(count + ((a == b) ? TEMP_STEP : -TEMP_STEP), TEMP_MIN, TEMP_MAX);
  208.       handleMoved = true;
  209.     }
  210.   }
  211. }
T12 文件夹.zip (1.15 MB, 下载次数: 556)
ID:272625 发表于 2019-8-6 20:00 | 显示全部楼层
好资料,希望楼主能上传些成品图片看看。
ID:598522 发表于 2019-8-9 18:43 | 显示全部楼层
很好,好资料,51黑有你更精彩!!!
ID:598522 发表于 2019-8-16 18:13 | 显示全部楼层
好资料,终于有黑币可以用了
ID:590584 发表于 2019-8-17 20:33 | 显示全部楼层
  谢谢分享。
ID:297381 发表于 2019-8-20 09:40 来自触屏版 | 显示全部楼层
谢谢分享
ID:600360 发表于 2019-8-22 12:38 来自触屏版 | 显示全部楼层
谢谢分享
ID:198286 发表于 2019-9-7 18:01 | 显示全部楼层
很好,吧你做好的图片发来欣赏下
ID:609112 发表于 2019-9-15 14:14 | 显示全部楼层
谢谢分享,这个真牛逼
ID:432073 发表于 2019-9-15 18:16 | 显示全部楼层
很好,好资料,51黑有你更精彩!!!
ID:436736 发表于 2019-9-23 22:03 | 显示全部楼层
做的很好,开元很彻底。
ID:609801 发表于 2019-10-10 10:06 来自触屏版 | 显示全部楼层
谢谢分享
ID:599349 发表于 2019-10-14 15:44 | 显示全部楼层
感谢楼主的分享,学习中
ID:79544 发表于 2019-10-16 08:04 | 显示全部楼层
感谢分享!赞。
ID:622823 发表于 2019-10-31 13:44 | 显示全部楼层
感谢分享,非常不错的资料。
ID:622823 发表于 2019-10-31 16:27 | 显示全部楼层
不错 的资料  这个版本 的少见
ID:436736 发表于 2019-11-4 16:25 | 显示全部楼层
很实用的例子 多谢分享。
ID:638374 发表于 2019-11-9 09:33 | 显示全部楼层
谢谢分享。
ID:347654 发表于 2019-11-12 15:51 | 显示全部楼层
感谢分享,抽空试制,如成功也会分享给大家
ID:649577 发表于 2019-11-30 01:53 | 显示全部楼层
感谢分享,非常不错的资料
ID:651779 发表于 2019-12-1 00:16 来自触屏版 | 显示全部楼层
摩拜大神,根本看不懂[em19
ID:607710 发表于 2019-12-4 15:35 | 显示全部楼层
肯定有些伸手党傻眼了
ID:279787 发表于 2019-12-13 11:17 | 显示全部楼层
这个图用的MP2307,输入24V很危险啊
ID:477892 发表于 2019-12-19 21:12 来自触屏版 | 显示全部楼层
感谢楼主分享!
ID:642926 发表于 2019-12-20 08:32 | 显示全部楼层
谢谢分享
ID:150151 发表于 2019-12-22 19:34 | 显示全部楼层
我打了五块板。。
ID:150151 发表于 2019-12-24 09:40 来自触屏版 | 显示全部楼层
打板5块
ID:677234 发表于 2019-12-30 10:43 | 显示全部楼层
感谢,感谢。
ID:407499 发表于 2020-1-18 20:40 | 显示全部楼层
感谢分享
ID:76671 发表于 2020-1-27 11:16 | 显示全部楼层
谢谢分享,改一下可以用esp8266
ID:150151 发表于 2020-2-19 15:28 | 显示全部楼层
51hei图片_20200219152830.jpg 51hei图片_202002191528301.jpg 51hei图片_202002191528302.jpg 我做了,屏不显示,是什么问题?有谁做成功过的说一下。
ID:471632 发表于 2020-2-19 17:11 | 显示全部楼层
Arduino在哪里呢?怎么上传程序?
ID:150151 发表于 2020-2-21 09:09 | 显示全部楼层
tigerzq 发表于 2020-2-19 17:11
Arduino在哪里呢?怎么上传程序?
ICSP接口。
ID:430492 发表于 2020-3-10 13:00 | 显示全部楼层
这款确实有点创新,很少有人用Arduino写T12的控制。
ID:705985 发表于 2020-3-10 19:37 来自触屏版 | 显示全部楼层
谢谢,好资料!开源的很好
ID:702957 发表于 2020-3-13 18:20 | 显示全部楼层
下载看一下 谢谢
ID:150151 发表于 2020-3-15 01:35 | 显示全部楼层
链接:https://pan.baidu.com/s/1lC2Y5Sn7U_L-oxWhTOjhNA
提取码:gxat改成中文了的文件,原程序已经加了注释,打包有需要的自己下载,附上u8g2自定义字库的相关文件和工具。20200305已备份
原版英文界面
原版英文界面
原版英文界面
原版英文界面
原版英文界面
原版英文界面
原版英文界面
原版英文界面
新版中文界面
新版中文界面
原版英文界面
原版英文界面
原版英文界面
原版英文界面
原版英文界面
原版英文界面
ID:230374 发表于 2020-3-29 20:40 | 显示全部楼层
谢谢分享
ID:230374 发表于 2020-4-7 17:58 | 显示全部楼层
我参考此列有制作成,其中一项楼主不太明白,X4  KP-301  2P  EARTH看了图纸是空脚位,没有找到和那个脚位连接,手柄自动没有成功,忘赐教;
ID:725307 发表于 2020-4-9 09:27 | 显示全部楼层
楼主厉害
