查看: 6996|回复: 4
快速入门msp430fr6989之lcd功能篇
【注】德州仪器的官网上的msp430fr6989单片机上有一块lcd,其有40个引脚,分别两边各有20个引脚排布。学过stm32的能很快掌握lcd的寄存器模式下写成的代码,但是新手最好入门库函数一类,如果时间很紧迫的情况下。板上是0-7的行,分为上半屏和下半屏。列有LCDM1-LCDM20,总共有8*20=160个segment。在前面的帖子中,对引脚的定义是通过寄存器进行定义的,而如果我要让流水灯亮起来就可以把寄存器及地址写在一个函数内,包装起来,直接在官网上找的代码,很丰富,学这个很快。比如以下:
  1. <p>//定义输出引脚
  2. void GPIO_setAsOutputPin(uint8_t selectedPort,
  3.                          uint16_t selectedPins) {
  4.     uint16_t baseAddress = GPIO_PORT_TO_BASE[selectedPort];</p><p>    #ifndef NDEBUG
  5.     if(baseAddress == 0xFFFF)
  6.     {
  7.         return;
  8.     }
  9.     #endif</p><p>    // Shift by 8 if port is even (upper 8-bits)
  10.     if((selectedPort & 1) ^ 1)
  11.     {
  12.         selectedPins <<= 8;
  13.     }</p><p>    HWREG16(baseAddress + OFS_PASEL0) &= ~selectedPins;
  14.     HWREG16(baseAddress + OFS_PASEL1) &= ~selectedPins;
  15.     HWREG16(baseAddress + OFS_PADIR) |= selectedPins;</p><p>    return;
  16. }</p><p>
  17. </p><p>
  18. </p><p>Init_GPIO();
  19.
  20. GPIO_clearInterrupt(GPIO_PORT_P1, GPIO_PIN1);
  21. GPIO_clearInterrupt(GPIO_PORT_P1, GPIO_PIN2);</p><font size="5"><p>void Init_GPIO(void)
  22. {
  23.   // Set all GPIO pins to output low to prevent floating input and reduce power consumption
  24.   GPIO_setOutputLowOnPin(GPIO_PORT_P1, GPIO_PIN0|GPIO_PIN1|GPIO_PIN2|GPIO_PIN3|GPIO_PIN4|GPIO_PIN5|GPIO_PIN6|GPIO_PIN7);
  25.   GPIO_setOutputLowOnPin(GPIO_PORT_P2, GPIO_PIN0|GPIO_PIN1|GPIO_PIN2|GPIO_PIN3|GPIO_PIN4|GPIO_PIN5|GPIO_PIN6|GPIO_PIN7);
  26.   GPIO_setOutputLowOnPin(GPIO_PORT_P3, GPIO_PIN0|GPIO_PIN1|GPIO_PIN2|GPIO_PIN3|GPIO_PIN4|GPIO_PIN5|GPIO_PIN6|GPIO_PIN7);
  27.   GPIO_setOutputLowOnPin(GPIO_PORT_P4, GPIO_PIN0|GPIO_PIN1|GPIO_PIN2|GPIO_PIN3|GPIO_PIN4|GPIO_PIN5|GPIO_PIN6|GPIO_PIN7);
  28.   GPIO_setOutputLowOnPin(GPIO_PORT_P5, GPIO_PIN0|GPIO_PIN1|GPIO_PIN2|GPIO_PIN3|GPIO_PIN4|GPIO_PIN5|GPIO_PIN6|GPIO_PIN7);
  29.   GPIO_setOutputLowOnPin(GPIO_PORT_P6, GPIO_PIN0|GPIO_PIN1|GPIO_PIN2|GPIO_PIN3|GPIO_PIN4|GPIO_PIN5|GPIO_PIN6|GPIO_PIN7);
  30.   GPIO_setOutputLowOnPin(GPIO_PORT_P7, GPIO_PIN0|GPIO_PIN1|GPIO_PIN2|GPIO_PIN3|GPIO_PIN4|GPIO_PIN5|GPIO_PIN6|GPIO_PIN7);
  31.   GPIO_setOutputLowOnPin(GPIO_PORT_P8, GPIO_PIN0|GPIO_PIN1|GPIO_PIN2|GPIO_PIN3|GPIO_PIN4|GPIO_PIN5|GPIO_PIN6|GPIO_PIN7);
  32.   GPIO_setOutputLowOnPin(GPIO_PORT_P9, GPIO_PIN0|GPIO_PIN1|GPIO_PIN2|GPIO_PIN3|GPIO_PIN4|GPIO_PIN5|GPIO_PIN6|GPIO_PIN7);
  33.
  34.   GPIO_setAsOutputPin(GPIO_PORT_P1, GPIO_PIN0|GPIO_PIN1|GPIO_PIN2|GPIO_PIN3|GPIO_PIN4|GPIO_PIN5|GPIO_PIN6|GPIO_PIN7);
  35.   GPIO_setAsOutputPin(GPIO_PORT_P2, GPIO_PIN0|GPIO_PIN1|GPIO_PIN2|GPIO_PIN3|GPIO_PIN4|GPIO_PIN5|GPIO_PIN6|GPIO_PIN7);
  36.   GPIO_setAsOutputPin(GPIO_PORT_P3, GPIO_PIN0|GPIO_PIN1|GPIO_PIN2|GPIO_PIN3|GPIO_PIN4|GPIO_PIN5|GPIO_PIN6|GPIO_PIN7);
  37.   GPIO_setAsOutputPin(GPIO_PORT_P4, GPIO_PIN0|GPIO_PIN1|GPIO_PIN2|GPIO_PIN3|GPIO_PIN4|GPIO_PIN5|GPIO_PIN6|GPIO_PIN7);
  38.   GPIO_setAsOutputPin(GPIO_PORT_P5, GPIO_PIN0|GPIO_PIN1|GPIO_PIN2|GPIO_PIN3|GPIO_PIN4|GPIO_PIN5|GPIO_PIN6|GPIO_PIN7);
  39.   GPIO_setAsOutputPin(GPIO_PORT_P6, GPIO_PIN0|GPIO_PIN1|GPIO_PIN2|GPIO_PIN3|GPIO_PIN4|GPIO_PIN5|GPIO_PIN6|GPIO_PIN7);
  40.   GPIO_setAsOutputPin(GPIO_PORT_P7, GPIO_PIN0|GPIO_PIN1|GPIO_PIN2|GPIO_PIN3|GPIO_PIN4|GPIO_PIN5|GPIO_PIN6|GPIO_PIN7);
  41.   GPIO_setAsOutputPin(GPIO_PORT_P8, GPIO_PIN0|GPIO_PIN1|GPIO_PIN2|GPIO_PIN3|GPIO_PIN4|GPIO_PIN5|GPIO_PIN6|GPIO_PIN7);
  42.   GPIO_setAsOutputPin(GPIO_PORT_P9, GPIO_PIN0|GPIO_PIN1|GPIO_PIN2|GPIO_PIN3|GPIO_PIN4|GPIO_PIN5|GPIO_PIN6|GPIO_PIN7);
  43.
  44.   GPIO_setAsInputPin(GPIO_PORT_P3, GPIO_PIN5);
  45.
  46.   // Configure button S1 (P1.1) interrupt
  47.   GPIO_selectInterruptEdge(GPIO_PORT_P1, GPIO_PIN1, GPIO_HIGH_TO_LOW_TRANSITION);
  48.   GPIO_setAsInputPinWithPullUpResistor(GPIO_PORT_P1, GPIO_PIN1);
  49.   GPIO_clearInterrupt(GPIO_PORT_P1, GPIO_PIN1);
  50.   GPIO_enableInterrupt(GPIO_PORT_P1, GPIO_PIN1);
  51.
  52.   // Configure button S2 (P1.2) interrupt
  53.   GPIO_selectInterruptEdge(GPIO_PORT_P1, GPIO_PIN2, GPIO_HIGH_TO_LOW_TRANSITION);
  54.   GPIO_setAsInputPinWithPullUpResistor(GPIO_PORT_P1, GPIO_PIN2);
  55.   GPIO_clearInterrupt(GPIO_PORT_P1, GPIO_PIN2);
  56.   GPIO_enableInterrupt(GPIO_PORT_P1, GPIO_PIN2);
  57.
  58.   // Set P4.1 and P4.2 as Secondary Module Function Input, LFXT.
  59.   GPIO_setAsPeripheralModuleFunctionInputPin(
  60.                                              GPIO_PORT_PJ,
  61.                                              GPIO_PIN4 + GPIO_PIN5,
  62.                                              GPIO_PRIMARY_MODULE_FUNCTION
  63.                                                );
  64.
  65.   // Disable the GPIO power-on default high-impedance mode
  66.   // to activate previously configured port settings
  67.   PMM_unlockLPM5();</p><p>}</p></font><p>
  68. </p>
下面有开箱的源代码。【禁止商业用途】
OutOfBox_MSP430FR6989.7z
1.49 MB, 下载次数: 38, 下载积分: 黑币 -5
ID:628019 发表于 2019-10-23 12:44 | 只看该作者
不行,你这下载的东西是官方的样例,,初学者,你贴的图也不过。。
ID:64765 发表于 2020-6-25 16:15 | 只看该作者
好资料,学习了,谢谢分享。
ID:64765 发表于 2020-6-29 14:32 | 只看该作者
给力,太好了,谢谢楼主分享。
ID:497627 发表于 2020-7-29 11:01 | 只看该作者
可以提一个题外话的问题吗?FR6989的中断需要开全局吗,我写了个定时器中断的实验,但是中断跳不进去
