查看: 4997|回复: 1
STC12单片机串口通信(跟串口助手调试程序)
ID:337280 发表于 2019-7-30 11:26 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
调了很长时间,才弄好。主要是串口通信,跟串口助手来进行调试的,程序里面有液晶显示的程序,可以跟串口助手进行对比。液晶是串行显示。
#include "stc12c5a60s2.h"
uchar tmp;
uint count;
sbit rs = P3^5;
sbit rw = P3^6;
sbit en = P3^4;
uchar str[]="000000";
uchar code tab[]={
0x80,0x81,0x82,0x83,0x84,0x85,0x86,0x87,
0x90,0x91,0x92,0x93,0x94,0x95,0x96,0x97,
0x88,0x89,0x8a,0x8b,0x8c,0x8d,0x8e,0x8f,
0x98,0x99,0x9a,0x9b,0x9c,0x9d,0x9e,0x9f,
void sendb(uchar byte)
  uchar i;
  for(i=0;i<8;i++)
   en=0;
   byte=byte<<1;
   rw = CY;
   en = 1;
   en = 0;
uchar reedbyte(void)
uchar i,temp1,temp2;
temp1 = 0;
temp2 = 0;
for(i=0;i<8;i++)
   temp1 = temp1<<1;
   en=0;
   en=1;
   en=0;
   if(rw)temp1++;
for(i=0;i<8;i++)
   temp2=temp2<<1;
   en=0;
   en=1;
   en=0;
   if(rw)temp2++;
  return((0xf0&temp1)+(0x0f&temp2));
void lcdbusy()
do sendb(0xfc);
while(0x80&reedbyte());
void writecmd(uchar byte)
   rs=1;
   lcdbusy();
   sendb(0xf8);
   sendb(0xf8&byte);
   sendb(0xf8&byte<<4);
   rs=0;
void writedata(uchar byte)
   rs=1;
   lcdbusy();
   sendb(0xfa);
   sendb(0xf8&byte);
   rs=0;
void delaylcd(uint ms)
  uchar us,usn;
  while(ms!=0)
     usn=2;
         while(usn!=0)
          us=0xf5;
          while(us!=0)
           us--;
           usn--;
           ms--;
void lcdlnit()
  writecmd(0x30);
  writecmd(0x03);
  writecmd(0x0c);
  writecmd(0x01);
  writecmd(0x06);
void lcdtxt()
uchar i;
writecmd(0x30);
writecmd(0x80);
for(i=0;i<64;i++)
writedata(0x20);
void write(uchar row,uchar col,uchar *puts)
   writecmd(0x30);
   writecmd(tab[8*row+col]);
   while(*puts!='\0')
    if(col==8)
        col='0';
        row++;
        if(row==4)row='0';
        writedata(*puts);
        puts++;
        writedata(*puts);
        puts++;
        col++;
}********完整在附件里
串口通信.rar
28.71 KB, 下载次数: 42, 下载积分: 黑币 -5
ID:503511 发表于 2022-4-21 08:56 | 只看该作者
好用,感谢楼主的分享。
