查看: 4318|回复: 1
ARDUINO定时器中断实验
ID:594307 发表于 2019-8-2 19:41 | 显示全部楼层 |阅读模式
#include <MsTimer2.h>               //定时器库的 头文件
int LED1=13;
int LED2=9;
void setup() {
  // put your setup code here, to run once:
pinMode(LED1,OUTPUT);
pinMode(LED2,OUTPUT);
MsTimer2::set(500, dongzuo);        // 中断设置函数,每 500ms 进入一次中断
  MsTimer2::start();                //开始计时
void loop() {
  // put your main code here, to run repeatedly:
digitalWrite(LED1,HIGH);
delay(1000);
digitalWrite(LED1,LOW);
delay(1000);
void dongzuo()
static boolean out=HIGH;
digitalWrite(LED2,out);
out=!out;
digitalWrite(LED2,HIGH);
delay(100);
digitalWrite(LED2,LOW);
delay(100);
ID:275826 发表于 2019-9-1 21:02 | 显示全部楼层
用TIMERONE库更简单哟
