查看: 4278|回复: 0
精确到0.1秒的三位秒表单片机程序Proteus仿真(共阴极)
采用80c52单片机,精确到0.1秒的三位秒表(共阴极)。
  1. #include<reg52.h>          //头函数
  2. #define led P0
  3. typedef unsigned char u8;
  4. typedef unsigned int u16;
  5. sbit P20=P2^0;                 //位定义
  6. sbit P21=P2^1;
  7. sbit P22=P2^2;
  8. sbit P23=P2^3;
  9. sbit P27=P0^7;
  10. sbit k1 = P3^2;
  11. sbit k2 = P3^3;
  12. sbit beep=P1^5;
  13. static u8 min = 0;
  14. static u8 sec = 0;
  15. static u8 spot = 0;
  16. u8  smgz[] = {0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,
  17.                     0x7f,0x6f};
  18. void delay(u16 i)
  19. {
  20.     while(i--);
  21. }
  22. void display( )
  23. {
  24.         P23=0;
  25.         P0=smgz[spot%10];
  26.         delay(1000);
  27.         P23=1;
  28.         P22=0;
  29.         P0=smgz[sec%10]|0x80;
  30.         delay(1000);
  31.         P22=1;
  32.         P21=0;
  33.         P0=smgz[min%10];
  34.         delay(1000);
  35.         P21=1;
  36.         P20=0;
  37.         P0=smgz[min/10];
  38.         delay(1000);
  39.         P20=1;
  40. }
  41.
  42. void Timer0Init()
  43. {
  44.     TMOD |= 0X01;
  45.     TH0 = 0XFC;
  46.     TL0 = 0X18;
  47.     ET0 = 1;
  48.     IT0=1;//跳变沿出发方式(下降沿)
  49.     EX0=1;//打开INT0的中断允许。
  50.     IT1=1;
  51.     EX1=1;
  52.     EA = 1;
  53.     TR0 = 1;
  54. }
  55. void BEEP()
  56. {
  57.         while(1)
  58.         {
  59.                 beep=~beep;
  60.                 delay(10); //延时大约100us
  61.         }
  62. }
  63. void main()
  64. {
  65.     Timer0Init();
  66.     while(1)
  67.     {
  68.             display( );
  69.     }
  70. }
  71. void Timer0() interrupt 1
  72. {
  73.         static int Timer0_times = 0;
  74.         TH0 = 0XFC;
  75.         TL0 = 0X18;
  76.         Timer0_times++;
  77.         if(Timer0_times == 70)
  78.         {
  79.             if(spot < 9)
  80.                 spot++;
  81.             else if(sec < 9)
  82.             {
  83.                 sec++;
  84.                 spot = 0;
  85.             }
  86.             else
  87.             {
  88.                 min++;
  89.                 spot = sec = 0;
  90.                                 if(min>=12)
  91.                                 {
  92.                                         BEEP();
  93.                                 }
  94.
  95.             }
  96.             Timer0_times = 0;
  97.         }
  98. }
  99. void Int0()    interrupt 0        //外部中断0的中断函数
  100. {
  101.     delay(1000);     //延时消抖
  102.     if(k1==0)
  103.     {
  104.         TR0 = ~TR0;
  105.     }
  106. }
  107. void Int1()    interrupt 2        //外部中断1的中断函数
  108. {
  109.     delay(1000);     //延时消抖
  110.     if(k2==0)
  111.     {
  112.         TR0 = 0;
  113.           min = sec = spot = 0;
  114.     }
  115. }
精确到0.1秒的三位秒表(共阴极).rar (46.22 KB, 下载次数: 47)
收藏收藏3 分享淘帖 顶 踩
