查看: 20341|回复: 3
基于51单片机蜂鸣器的两只老虎音乐代码
ID:598181 发表于 2019-8-10 01:01 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
#include <reg52.h>
sbit BUZZ = P1^6;  //蜂鸣器控制引脚
unsigned int code NoteFrequ[] = {  //中音1-7和高音1-7对应频率列表
    523,  587,  659,  698,  784,  880,  988,  //中音1-7
    1047, 1175, 1319, 1397, 1568, 1760, 1976  //高音1-7
unsigned int code NoteReload[] = { //中音1-7和高音1-7对应的定时器重载值
    65536 - (11059200/12) / (523*2),  //中音1
    65536 - (11059200/12) / (587*2),  //2
    65536 - (11059200/12) / (659*2),  //3
    65536 - (11059200/12) / (698*2),  //4
    65536 - (11059200/12) / (784*2),  //5
    65536 - (11059200/12) / (880*2),  //6
    65536 - (11059200/12) / (988*2),  //7
    65536 - (11059200/12) / (1047*2), //高音1
    65536 - (11059200/12) / (1175*2), //2
    65536 - (11059200/12) / (1319*2), //3
    65536 - (11059200/12) / (1397*2), //4
    65536 - (11059200/12) / (1568*2), //5
    65536 - (11059200/12) / (1760*2), //6
    65536 - (11059200/12) / (1976*2), //7
bit enable = 1;   //蜂鸣器发声使能标志
bit tmrflag = 0;  //定时器中断完成标志
unsigned char T0RH = 0xFF;  //T0重载值的高字节
unsigned char T0RL = 0x00;  //T0重载值的低字节
void PlayTwoTiger();
    unsigned int i;
    EA = 1;       //使能全局中断
    TMOD = 0x01;  //配置T0工作在模式1
    TH0 = T0RH;
    TL0 = T0RL;
    ET0 = 1;      //使能T0中断
    TR0 = 1;      //启动T0
    while (1)
        PlayTwoTiger();  //播放乐曲--两支老虎
        for (i=0; i<40000; i++);  //停止一段时间
/* 两只老虎乐曲播放函数 */
void PlayTwoTiger()
    unsigned char beat;   //当前节拍索引
    unsigned char note;   //当前节拍对应的音符
    unsigned int time = 0;      //当前节拍计时
    unsigned int beatTime = 0;  //当前节拍总时间
    unsigned int soundTime = 0; //当前节拍需发声时间
    //两只老虎音符表
    unsigned char code TwoTigerNote[] = {
        1,   2,   3, 1,    1,   2,   3, 1,   3, 4, 5,   3, 4, 5,
        5,6, 5,4, 3, 1,    5,6, 5,4, 3, 1,   1, 5, 1,   1, 5, 1,
    //两只老虎节拍表,4表示一拍,1就是1/4拍,8就是2拍
    unsigned char code TwoTigerBeat[] = {
        4,   4,   4, 4,    4,   4,   4, 4,   4, 4, 8,   4, 4, 8,
        3,1, 3,1, 4, 4,    3,1, 3,1, 4, 4,   4, 4, 8,   4, 4, 8,
    for (beat=0; beat<sizeof(TwoTigerNote); )  //用节拍索引作为循环变量
        while (!tmrflag);  //每次定时器中断完成后,检测并处理节拍
        tmrflag = 0;
        if (time == 0)  //当前节拍播完则启动一个新节拍
            note = TwoTigerNote[beat] - 1;
            T0RH = NoteReload[note] >> 8;
            T0RL = NoteReload[note];
            //计算节拍总时间,右移2位相当于除4,移位代替除法可以加快执行速度
            beatTime = (TwoTigerBeat[beat] * NoteFrequ[note]) >> 2;
            //计算发声时间,为总时间的0.75,移位原理同上
            soundTime = beatTime - (beatTime >> 2);
            enable = 1;  //指示蜂鸣器开始发声
            time++;
        else  //当前节拍未播完则处理当前节拍
            if (time >= beatTime)  //当前持续时间到达节拍总时间时归零,
            {                      //并递增节拍索引,以准备启动新节拍
                time = 0;
                beat++;
            else  //当前持续时间未达到总时间时,
                time++;   //累加时间计数
                if (time == soundTime)  //到达发声时间后,指示关闭蜂鸣器,
                {                       //插入0.25*总时间的静音间隔,
                    enable = 0;         //用以区分连续的两个节拍
/* T0中断服务函数,用于控制蜂鸣器发声 */
void InterruptTimer0() interrupt 1
    TH0 = T0RH;   //重新加载重载值
    TL0 = T0RL;
    tmrflag = 1;
    if (enable)   //使能时反转蜂鸣器控制电平
        BUZZ = ~BUZZ;
    else          //未使能时关闭蜂鸣器
        BUZZ = 1;
收藏收藏4 分享淘帖 顶顶1 踩踩
ID:886364 发表于 2021-3-1 12:38 | 只看该作者
可以的, 写得不错
ID:284226 发表于 2023-3-4 15:43 | 只看该作者
请问为什么是除以4.上面两个
ID:1086387 发表于 2023-8-2 14:12 | 只看该作者
怎么让他停下来
