查看: 3644|回复: 0
STM8L151实现AD测量程序_寄存器版调试成功
ID:600674 发表于 2019-8-16 11:18 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
#include "ADC.h"
#include "iostm8l151f2.h"
#include "stdbool.h"
#include "stdint.h"
uint16_t Vbat1=0;
uint16_t Vbat0=0;
uint16_t Vusbin=0;
uint16_t Vbutton0=0;
uint16_t Vbat=0;
static uint16_t temp=0;
void delay_500ms(void)    //粗略延时程序
  uint16_t i,j;
  for(i=0;i<1000;i++)//2*1000个指令周期
    for(j=0;j<500;j++);//2*500个指令周期
  //1000*2*500+2*500=1.001M,延迟1/16s=62.5ms
  //16M 一个指令周期为1/16us
void ADC1_Init()
   CLK_PCKENR2_PCKEN20=1; //开启ADC1外设时钟
   ADC1_CR1_ADON=1;  //wakes up the ADC from Power down mode
   ADC1_CR1_CONT=0; //单次转换模式
   ADC1_CR2_PRESC=1;//Select a sample time of 1μs  //   0: f(ADC_CLK) = CK
                     //   1: f(ADC_CLK) = CK/2  //系统时钟此时为默认的16M/8=2M,这里分频后,fadc=2M/2=1M
   ADC1_SQR1_DMAOFF=1;    //关闭DMA通道
   //ADC1_CR3_SMTP2=0x06;  //设置内部参考电压通道的采样时间
   ADC1_CR2_SMTP1=0x03;//外部0-23通道的采样时间为24 ADC clock cycles,也就是24*1us=24us
//  ADC1_CR1_EOCIE=1; //中断
//#pragma vector=COMP_EF2_vector
//__interrupt void ADC1_ISR(void
//测量VDD
uint16_t get_VDD()
   Vbat=0;
   ADC1_SQR1_CHSEL_S28=1;  //选择ADC通道28,内部参考电压通道
   ADC1_TRIGR1_VREFINTON=1;//打开内部参考电压源1.225v
   for(char j=0;j<10;j++)
        ADC1_CR1_START=1 ;//开始转换
        while(!(ADC1_SR_EOC==1));//等待转换结束,清除标志位
        temp = ADC1_DRH;
        temp = (temp<<8)+ADC1_DRL;
        temp=(uint32_t)2400*4096/temp;   //由于VREF与VDD接在同一引脚上,内部参考电压输出通道实际电压不知,
                                        //因此无法采用内部参考电压测量VDD,用电压表多点测量的方法测得实际VDD=1.790V
        Vbat+=temp;
   Vbat = Vbat/10;
   asm("nop");
   ADC1_SQR1_CHSEL_S28=0; //关闭通道
   return Vbat;
uint16_t get_Vbat1()
   Vbat1=0;
   static uint16_t temp1=0;
   ADC1_SQR3_CHSEL_S11=1;  //选择ADC通道11
   ADC1_TRIGR3_TRIG11=1;  //关闭通道11的施密特触发器
        temp1 = ADC1_DRH;
        temp1 = (temp1<<8)+ADC1_DRL;
        temp1=(uint32_t)1800*temp1/4096;
        Vbat1+=temp1;
    Vbat1 = Vbat1/10;
    Vbat1=3*Vbat1;//实际电压值为3倍的AD电压值
    ADC1_SQR3_CHSEL_S11=0;
   asm("nop");
     return Vbat1;
uint16_t get_Vbat0()
   Vbat0=0;
   static uint16_t temp0=0;
   ADC1_SQR3_CHSEL_S12=1;  //打开ADC通道12
   ADC1_TRIGR3_TRIG12=1;  //关闭通道12的施密特触发器
  for(char k=0;k<10;k++)
        temp0 = ADC1_DRH;
        temp0 = (temp0<<8)+ADC1_DRL;
        temp0=(uint32_t)1800*temp0/4096;
        Vbat0+=temp0;
    Vbat0 = Vbat0/10;
    Vbat0=3*Vbat0;
     asm("nop");
      ADC1_SQR3_CHSEL_S12=0;
     return Vbat0;
uint16_t get_Vusbin()
   Vusbin=0;
   static uint16_t temp2=0;
   ADC1_SQR4_CHSEL_S4=1;  //打开ADC通道4
   ADC1_TRIGR4_TRIG4=1;  //关闭通道4的施密特触发器
        while(!(ADC1_SR_EOC==1));//等待转换完成
        temp2 = ADC1_DRH;   //先存MSB
        temp2 = (temp2<<8)+ADC1_DRL; //(MSB)*256+LSB
        temp2=(uint32_t)1800*temp2/4096;  //   VDD/4096=Vx/AD值
        Vusbin+=temp2;
      Vusbin = Vusbin/10;
      Vusbin =3*Vusbin;//USB输入电压
      asm("nop");
     ADC1_SQR4_CHSEL_S4=0;
     return Vusbin;
uint16_t get_Vbutton0()
     Vbutton0=0;
   static uint16_t temp3=0;
   ADC1_SQR3_CHSEL_S13=1;  //打开ADC通道13
   ADC1_TRIGR3_TRIG13=1;  //关闭通道13的施密特触发器
        temp3= ADC1_DRH;
        temp3 = (temp3<<8)+ADC1_DRL;
        temp3=(uint32_t)1800*temp3/4096;
        Vbutton0+=temp3;
        Vbutton0 =Vbutton0/10;  //button0对应的电压值
        asm("nop");
        ADC1_SQR3_CHSEL_S13=0; //关闭通道
        return Vbutton0;
  // CLK_Init();
  ADC1_Init();
  delay_500ms();
  delay_500ms();
  delay_500ms();//延时等待ADC稳定之后再进行转换,能够准确读取对应通道的电压
  get_Vusbin();
  delay_500ms();
  delay_500ms();
  get_Vbat0();
  delay_500ms();
  get_Vbutton0();
  delay_500ms();
  get_Vbat1();
