查看: 3700|回复: 2
第八届蓝桥杯省赛电子钟程序
ID:539930 发表于 2019-8-30 16:49 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
纯干货,持续更新
  1. #include <STC15F2K60S2.H>
  2. #include "ds18b20.h"
  3. #include "ds1302.h"
  5. #define uint unsigned int
  6.
  7. uchar code tab[]={0xc0,0xf9,0xa4,0xb0,0x99,0x92,0x82,0xf8,0x80,0x90,0xbf,0xff,0xc6};
  8. uchar yi,er,san,si,wu,liu,qi,ba;
  9. extern uchar shijian[];
  10. uchar wendu;
  11. uchar change;
  12. char jia1=0,jia2=0,jia3=0;
  13. uchar mode;
  14. void allinit(void);
  15. void keyscan(void);
  16. void delay(uint tt);
  17. void display1(uchar yi,uchar er);
  18. void display2(uchar san,uchar si);
  19. void display3(uchar wu,uchar liu);
  20. void display4(uchar qi,uchar ba);
  21. void main()
  22. {
  23.         allinit();
  24.         DS_init();
  25.         while(1)
  26.         {
  27.                 if(change==0)
  28.                 {
  29.                   DS_get();
  30.                   yi=shijian[2]/10;er=shijian[2]%10;san=10;
  31.                   si=shijian[1]/10;wu=shijian[1]%10;liu=10;
  32.                   qi=shijian[0]/10;ba=shijian[0]%10;
  33.                 }
  34.                 else if(change==1)
  35.                 {
  36.                         DS_get();
  37.                         yi=shijian[2]/10;er=shijian[2]%10;san=10;
  38.                   si=shijian[1]/10;wu=shijian[1]%10;liu=10;
  39.                   qi=shijian[0]/10;ba=shijian[0]%10;
  40.                         if(shijian[0]%10%2==0)yi=11,er=11;
  41.                         else if(shijian[0]%2%10!=0)yi=shijian[2]/10,er=shijian[2]%10;
  42.                 }
  43.                 else if(change==2)
  44.                 {
  45.                         DS_get();
  46.                         yi=shijian[2]/10;er=shijian[2]%10;san=10;
  47.                   si=shijian[1]/10;wu=shijian[1]%10;liu=10;
  48.                   qi=shijian[0]/10;ba=shijian[0]%10;
  49.                         if(shijian[0]%10%2==0)si=11,wu=11;
  50.                         else if(shijian[0]%2%10!=0)si=shijian[1]/10,wu=shijian[1]%10;
  51.                 }
  52.                 else if(change==3)
  53.                 {
  54.                         DS_get();
  55.                         yi=shijian[2]/10;er=shijian[2]%10;san=10;
  56.                   si=shijian[1]/10;wu=shijian[1]%10;liu=10;
  57.                   qi=shijian[0]/10;ba=shijian[0]%10;
  58.                         if(shijian[0]%10%2==0)qi=11,ba=11;
  59.                         else if(shijian[0]%2%10!=0)qi=shijian[0]/10,ba=shijian[0]%10;
  60.                 }
  61.                 if(change==4)
  62.                 {
  63.                   wendu=Tempget();
  64.                         yi=11,er=11,san=11,si=11,wu=11;
  65.                   liu=wendu/10;qi=wendu%10;ba=12;
  66.                         if(P33==1)change=0;
  67.                 }
  68.                 keyscan();
  69.                 display1(yi,er);
  70.                 display2(san,si);
  71.                 display3(wu,liu);
  72.                 display4(qi,ba);
  73.         }
  74. }
  75. void allinit(void)
  76. {
  77.         P2=0xa0;P0=0x00;
  78.
  79.         P2=0x80;P0=0xff;
  80.
  81.         P2=0xc0;P0=0xff;
  82.         P2=0xff;P0=0xff;
  83. }
  84. void delay(uint tt)
  85. {
  86.         while(tt--);
  87. }
  88. void display1(uchar yi,uchar er)
  89. {
  90.         P2=0xc0;P0=0x01;P2=0xff;P0=tab[yi];delay(1000);
  91.
  92.         P2=0xc0;P0=0x02;P2=0xff;P0=tab[er];delay(1000);
  93. }
  94. void display2(uchar san,uchar si)
  95. {
  96.         P2=0xc0;P0=0x04;P2=0xff;P0=tab[san];delay(1000);
  97.
  98.         P2=0xc0;P0=0x08;P2=0xff;P0=tab[si];delay(1000);
  99. }
  100. void display3(uchar wu,uchar liu)
  101. {
  102.         P2=0xc0;P0=0x10;P2=0xff;P0=tab[wu];delay(1000);
  103.
  104.         P2=0xc0;P0=0x20;P2=0xff;P0=tab[liu];delay(1000);
  105. }
  106. void display4(uchar qi,uchar ba)
  107. {
  108.         P2=0xc0;P0=0x40;P2=0xff;P0=tab[qi];delay(1000);
  109.
  110.         P2=0xc0;P0=0x80;P2=0xff;P0=tab[ba];delay(1000);
  111.
  112.         P2=0xc0;P0=0xff;P2=0xff;P0=0xff;
  113. }
  114. void keyscan(void)
  115. {
  116.         if(P30==0)
  117.         {
  118.                 delay(10);
  119.                 if(P30==0)
  120.                 {
  121.                         mode++;
  122.                         change++;
  123.                         if(change==4)change=0;
  124.                         if(change==0)mode=0;
  125.                 }
  126.                 while(!P30);
  127.         }
  128.         else if(P31==0)
  129.         {
  130.                 delay(10);
  131.                 if(P31==0)
  132.                 {
  133.
  134.                 }
  135.                 while(!P31);
  136.         }
  137.         else if(P32==0)
  138.         {
  139.                 delay(10);
  140.                 if(P32==0)
  141.                 {
  142.                         if(change==1)
  143.                         {
  144.                                 shijian[2]++;DS_init();
  145.                         }
  146.                         else if(change==2)
  147.                         {
  148.                                 shijian[1]++;DS_init();
  149.                         }
  150.                         else if(change==3)
  151.                         {
  152.                                 shijian[0]++;DS_init();
  153.                         }
  154.                 }
  155.                 while(!P32);
  156.         }
  157.         else if(P33==0)
  158.         {
  159.                 delay(10);
  160.                 if(P33==0)
  161.                 {
  162.                         if(mode==0)change=4;
  163.                         if(mode!=0)
  164.                         {
  165.                         if(change==1)shijian[2]--,DS_init();
  166.                         else if(change==2)shijian[2]--,DS_init();
  167.                         else if(change==3)shijian[2]--,DS_init();
  168.                         }
  169.
  170.                 }
  171.                 if((change==1)||(change==2)||(change==3))while(!P33);
  172.
  173.         }
  174. }
所有资料51hei提供下载,本人初学,如有错误,请大家多多指教:
第八届初赛_电子钟.zip (49.84 KB, 下载次数: 50)
第八届初赛试题-电子钟.pdf (143.82 KB, 下载次数: 22)
收藏收藏 分享淘帖 顶顶1 踩踩
ID:752659 发表于 2020-10-16 21:50 | 只看该作者
大佬的资料很有用呀
ID:338810 发表于 2021-6-26 23:48 | 只看该作者
无语了,下载扣两次分
