查看: 2715|回复: 1
#5: cannot open source input file
ID:608013 发表于 2019-9-5 16:19 | 显示全部楼层 |阅读模式
*** Using Compiler 'V5.06 update 1 (build 61)', folder: 'E:\keil5\ARM\ARMCC\Bin'
Rebuild target 'Target 1'
assembling startup_stm32f10x_hd.s...
compiling core_cm3.c...
"no source": Error:  #5: cannot open source input file "C:\Users\小金\AppData\Local\Temp\p414-: Permission denied
..\system\core_cm3.c: 0 warnings, 1 error
compiling system_stm32f10x.c...
compiling main.c...
..\user\stc\main.c(6): warning:  #1-D: last line of file ends without a newline
..\user\stc\main.c: 1 warning, 0 errors
".\Objects\111.axf" - 1 Error(s), 1 Warning(s).
Target not created.
Build Time Elapsed:  00:00:00
ID:235200 发表于 2019-9-5 19:40 | 显示全部楼层
提示找不到文件core_cm3.c,检查文件路径对不对,是不是已加入到项目中
