查看: 3254|回复: 0
MAX30100模块介绍
希望可以对大家有用!!!
General Description
The MAX30100 is an integrated pulse oximetry and heart-rate monitor sensor solution. It combines two LEDs, a
photodetector, optimized optics, and low-noise analog signal processing to detect pulse oximetry and heart-rate signals.
The MAX30100 operates from 1.8V and 3.3V power sup-
plies and can be powered down through software with negligible standby current, permitting the power supply to remain connected at all times.
MAX30100.pdf
874.83 KB, 下载次数: 7, 下载积分: 黑币 -5
英文完整版
