查看: 2825|回复: 1
EXYNOS4412音乐盒程序设计
ID:608389 发表于 2019-9-9 21:51 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
  1. #include "exynos_4412.h"
  2. void mydelay_ms(int ms);
  3. #define S_CLK 125000
  4. //125KHz
  5. unsigned int sound[15] = {
  6. 0x00,
  7. 478,426,379,358,319,284,253,
  8. 235,213,190,179,159,142,127
  9. };
  10. //音符0~14
  11. //半音符15~29 -> 0~14音频不变,音长变为二分之一
  12. //连音符30
  13. unsigned char dis[] = {
  14.   5,
  15.   1+7,30,15+1+7,1+7,3+7,
  16.   2+7,30,15+1+7,2+7,3+7,
  17.   1+7,30,15+1+7,3+7,5+7,
  18.   6+7,30,30,6+7,
  19.   5+7,30,15+3+7,3+7,1+7,
  20.   2+7,30,15+1+7,2+7,3+7,
  21.   1+7,30,15+6,6,5,
  22.   1+7,30,30,
  23.   0xff
  24. };
  25. unsigned char dis3[] = {
  26.   7+1,7+1,
  27.   7+5,7+5,
  28.   7+6,7+6,
  29.   7+5,30,
  30.   7+4,7+4,
  31.   7+3,7+3,
  32.   7+2,7+2,
  33.   7+1,30,
  34.   7+5,7+5,
  35.   7+4,7+4,
  36.   7+3,7+3,
  37.   7+2,30,
  38.   7+5,7+5,
  39.   7+4,7+4,
  40.   7+3,7+3,
  41.   7+2,30,
  42.   7+1,7+1,
  43.   7+5,7+5,
  44.   7+6,7+6,
  45.   7+5,30,
  46.   7+4,7+4,
  47.   7+3,7+3,
  48.   7+2,7+2,
  49.   7+1,30,
  50.   0xff
  51. };
  52. void yin1()
  53. {
  54. unsigned int i;
  55. for(i=0;dis[i] != 0xff;i++)
  56.    {
  57.     if(dis[i] != 30)
  58.     {
  59.      if(dis[i] < 15)
  60.      {
  61.       PWM.TCON = 0;
  62.       mydelay_ms(50);
  63.       PWM.TCNTB0 = sound[dis[i]];
  64.       PWM.TCMPB0 = sound[dis[i]] / 2;
  65.       //手动装载TCNTB0和TCMPB0
  66.       PWM.TCON = 2; //0010
  67.       //自动装载模式,启动定时器0
  68.       PWM.TCON = 9; //1001
  69.       mydelay_ms(450);
  70.      }
  71.      else
  72.      {
  73.       PWM.TCON = 0;
  74.       mydelay_ms(50);
  75.       PWM.TCNTB0 = sound[dis[i] - 15];
  76.       PWM.TCMPB0 = sound[dis[i] - 15] / 2;
  77.       //手动装载TCNTB0和TCMPB0
  78.       PWM.TCON = 2; //0010
  79.       //自动装载模式,启动定时器0
  80.       PWM.TCON = 9; //1001
  81.       mydelay_ms(200);
  82.      }
  83.     }
  84.     else
  85.     {
  86.      mydelay_ms(500);
  87.     }
  88.    }
  89. }
  90. void yin2()
  91. {
  92. unsigned int i;
  93. for(i=0;dis3[i] != 0xff;i++)
  94.     {
  95.      if(dis3[i] != 30)
  96.      {
  97.       if(dis3[i] < 15)
  98.       {
  99.        PWM.TCON = 0;
  100.        mydelay_ms(100);
  101.        PWM.TCNTB0 = sound[dis3[i]];
  102.        PWM.TCMPB0 = sound[dis3[i]] / 2;
  103.        //手动装载TCNTB0和TCMPB0
  104.        PWM.TCON = 2; //0010
  105.        //自动装载模式,启动定时器0
  106.        PWM.TCON = 9; //1001
  107.        mydelay_ms(900);
  108.       }
  109.       else
  110.       {
  111.        PWM.TCON = 0;
  112.        mydelay_ms(100);
  113.        PWM.TCNTB0 = sound[dis3[i] - 15];
  114.        PWM.TCMPB0 = sound[dis3[i] - 15] / 2;
  115.        //手动装载TCNTB0和TCMPB0
  116.        PWM.TCON = 2; //0010
  117.        //自动装载模式,启动定时器0
  118.        PWM.TCON = 9; //1001
  119.        mydelay_ms(400);
  120.       }
  121.      }
  122.      else
  123.      {
  124.       mydelay_ms(1000);
  125.      }
  126.     }
  127. }
  128. void do_irq()
  129. {
  130. // 获取中断号
  131. unsigned int irq_num = CPU0.ICCIAR & 0x3ff;
  132. switch(irq_num)
  133. {
  134. case 57:
  135.   GPX2.DAT = GPX2.DAT | (1 << 7);
  136.   printf("This interrupt id is %d\n", irq_num);
  137.   yin1();
  138.   PWM.TCON = 0x8;  // 自动重装
  139.   GPX2.DAT = GPX2.DAT & ~(1 << 7);
  140.   //  PWM.TCON ^= 0x1;
  141. //  WDT.WTCON=WDT.WTCON|0x1<<0;
  142. //  WDT.WTCON=WDT.WTCON|0x1<<5;
  143.   //PWM.TCON = 0x2;  // 手动装载
  144.   //PWM.TCON = 0x8;  // 自动重装
  145.   EXT_INT41_PEND = 0x1 << 1;  // 清pend(置1清0)
  146.   ICDICPR.ICDICPR1 = 0x1 << 25; // 清gic
  147.   break;
  148. case 58:
  149.   GPF3.DAT = GPF3.DAT | (1 << 4);
  150.    printf("This interrupt id is %d\n", irq_num);
  151. //   GPX2.DAT = GPX2.DAT ^ (0x1 << 7);
  152.    yin2();
  153.    PWM.TCON = 0x8;  // 自动重装
  154.    GPF3.DAT = GPF3.DAT & ~(1 << 4);
  155.    EXT_INT41_PEND = 0x1 << 2;  // 清pend(置1清0)
  156.    ICDICPR.ICDICPR1 = 0x1 << 26; // 清gic
  157.    break;
  158. default:
  159.   printf("error!\n");
  160.   break;
  161. }
  162. // 把处理器中处理完的中断号返回给gic
  163. // 告诉gic该中断处理结束,可以送入下一个pending进入
  164. CPU0.ICCEOIR = (CPU0.ICCEOIR & ~(0x3ff)) | irq_num;
  165. }
  166. void peripheral_init()
  167. {
  168. GPX1.CON = 0xff << 4;  // 配置GPIO为外部中断
  169. EXT_INT41_CON = 0x22 << 4; // 下降沿触发中断
  170. EXT_INT41_MASK = 0x0;  // 使能相应外设
  171. }
  172. void gic_init()
  173. {
  174. ICDISER.ICDISER1 = 0x3 << 25;  // 使能按键中断号
  175. ICDIPTR.ICDIPTR14 = 0x0101 << 8;  // 选择cpu接口
  176. ICDDCR = 0x1;      // 使能中断到分配器
  177. CPU0.ICCICR = 0x1;     // 把中断从cpu接口送入处理器
  178. // 屏蔽中断优先级,255表示所有中断都允许通过
  179. CPU0.ICCPMR = 0xff;
  180. }
  181. void mydelay_ms(int ms)
  182. {
  183. int i, j;
  184. while(ms--)
  185. {
  186.   for (i = 0; i < 5; i++)
  187.    for (j = 0; j < 500; j++);
  188. }
  189. }
  190. void wdt_init(){
  191. WDT.WTCON=WDT.WTCON&(~(0xff<<8))|(249<<8);
  192. WDT.WTCON=WDT.WTCON&(~(0x3<<3))|(3<<3);
  193. WDT.WTDAT=10000;
  194. WDT.WTCNT=10000;
  195. }
  196. void pwm_init()
  197. {
  198. GPD0.CON = 0x2; // GPIO配置为TOUT_0
  199. PWM.TCNTB0 = 1000;
  200. PWM.TCMPB0 = 500;
  201. PWM.TCFG0 = 0x63; // 预分频值为99 -> 100
  202. PWM.TCFG1 = 0x3; // 二级分频为1/8
  203. PWM.TCON = 0x2;  // 手动装载
  204. PWM.TCON = 0x8;  // 自动重装
  205. }
  206. void led_init()
  207. {
  208. GPX2.CON = GPX2.CON & ~(0xf << 28) | (0x1 << 28);
  209. GPF3.CON = GPF3.CON & ~(0xf << 16) | (0x1 << 16);
  210. GPX2.DAT = GPX2.DAT & ~(1 << 7);
  211. GPF3.DAT = GPF3.DAT & ~(1 << 4);
  212. }
  213. int main()
  214. {
  215. peripheral_init();
  216. gic_init();
  217. pwm_init();
  218. led_init();
  219. int i = 0;
  220. while(1)
  221. {
  222.   mydelay_ms(800);
  223.   //WDT.WTCNT=30000;
  224. }
  225. return 0;
  226. }
ID:1 发表于 2019-9-10 01:56 | 只看该作者
本帖需要重新编辑补全电路原理图,源码,详细说明与图片即可获得100+黑币(帖子下方有编辑按钮)
