查看: 2447|回复: 1
关于单片机温度传感器程序的一些问题,如何触发按键储存温度上下限
ID:615910 发表于 2019-9-28 18:07 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
现在可以把数码管检测示数但不懂如何触发报警和按键储存温度上下限,多天无解,还望解惑。
#include<reg52.h>
#include<intrins.h>
typedef  unsigned char uchar;
typedef  unsigned int uint;
#define MAIN_Fosc 11059200UL
sbit DS = P3^7;
sbit we1=P2^0;
sbit we2=P2^1;
sbit we3=P2^2;
sbit we4=P2^3;
sbit deep=P3^6;
sbit key=P3^5;
sbit key2=P3^4;
sbit key3=P3^3;
sbit key4=P3^2;
uchar temp;
uchar num;
uchar settemp=35;
uchar settemp2=10;
bit DS18B20;
uchar msec, sec;
unsigned char code leddata[]={
                0xC0,  //"0"
                0xF9,  //"1"
                0xA4,  //"2"
                0xB0,  //"3"
                0x99,  //"4"
                0x92,  //"5"
                0x82,  //"6"
                0xF8,  //"7"
                0x80,  //"8"
                0x90,  //"9"
                0x88,  //"A"
                0x83,  //"B"
                0xC6,  //"C"
                0xA1,  //"D"
                0x86,  //"E"
                0x8E,  //"F"
                0x89,  //"H"
                0xC7,  //"L"
                0xC8,  //"n"
                0xC1,  //"u"
                0x8C,  //"P"
                0xA3,  //"o"
                0xBF,  //"-"
                0xFF,  //???
                0xFF  //?????
void delay (uint z)
  uint x,y;
  for(x=z;x>0;x--)
  for(y=84;y>0;y--);
  void us(uchar us)//us???????
while(us--);
void display( uint value)
  we1=1;
  we1=0;
   P0=0xff;
  P0=leddata[value/1000];
delay(1);
  we1=1;
  we2=0;
  P0&=0x7f;
  P0=leddata[value%1000/100];
  delay(1);
  we2=1;
   we3=0;
  P0=0xff;
  P0=leddata[value%100/10];
  delay(1);
  we3=1;
  P0=0xff;
  P0=leddata[value%10];
  we4=0;
  delay(1);
  we4=1;
void display3( uint value)
  we1=1;
  we1=0;
   P0=0xff;
delay(1);
  we1=1;
  we2=0;
  P0&=0x7f;
  delay(1);
  we2=1;
   we3=0;
  P0=0xff;
  delay(1);
  we3=1;
  P0=0xff;
  we4=0;
  delay(1);
  we4=1;
void beep1()
temp=0xfe;
P1=temp;
delay(100);
  temp=_crol_(temp,1);
  P1=temp;
  deep=~deep;
  delay(100);
void display2()
if(key == 0)
     delay(5);
if(key == 0)
   while(!key);
   settemp++;
   delay(50);
   if(settemp==99)
   settemp=0;
   delay(50);
if(key2 == 0)
     delay(5);
if(key2 == 0)
   while(!key2);
   if(settemp!=0)
   settemp--;
   delay(50);
if(key3 == 0)
     delay(5);
if(key3 == 0)
   while(!key3);
   settemp2++;
   delay(50);
   if(settemp2==99)
   settemp2=0;
   delay(50);
if(key4 == 0)
     delay(5);
if(key4 == 0)
   while(!key4);
   if(settemp2!=0)
   settemp2--;
   delay(50);
void duan ()
  EA=1;
  ET0=1;
  TR0=1;
  TMOD=0x01;
  TH0=0x4b;
  TL0=0xfd;
void  timer0() interrupt 1
  TH0=0x4b;
  TL0=0xfd;
  msec++;
  if(msec==20)
   msec=0;
bit init()
   bit i;
DS = 1;//??????
_nop_();
DS = 0;
us(75); //????????75*6.5+11.95=499.45us ????????????18B20???????????
DS=1;
us(4);//???
i = DS;
us(20); //141.95us ???????
DS = 1;
_nop_();
return (i);
void write (uchar dat)//д ???
uchar i;
for(i=0;i<8;i++)
  DS = 0;
  _nop_();//????д???
  DS = dat & 0x01;//?????????
  us(10);//76.95us
  DS = 1; //???????????????????д??
  _nop_();
  dat >>= 1;//??????
uchar read_byte()
uchar i, j, dat;
for(i=0;i<8;i++)
  DS = 0;
  _nop_();//?????????
  DS = 1;
  _nop_();//???????
  j = DS;
  us(10);//76.95us
  DS = 1;
  _nop_();
  dat = (j<<7)|(dat>>1);//????
return (dat);
  uint i;
  uchar L, M;
  init();//?????DS18B20
  write(0xcc);//???????ROM???
  write(0x4e);//????д????????
  write(0x18);
  write(0x10);
  write(0x7f);
  init();
  write(0xcc);
  write(0x48);
  write(0x44);//?????????????
        init();     //?????DS18B20
  write(0xbe);//???DS18B20??????
  L = read_byte();
  M = read_byte();
  i = M;
  i <<= 8;
  i |= L;
  i = i * 0.0625 * 100 + 0.05;
      display(i);
   duan();
  if(key==0|key2==0|key3==0|key4==0)
  { if(key==0)
   settemp=settemp*100;
    while(!key);
    display3(settemp);}
     if(key2==0)
   { settemp=settemp*100;
    while(!key2);
    display3(settemp);}
     if(key3==0)
   { settemp2=settemp2*100;
    while(!key3);
    display3(settemp2);}
     if(key4==0)
    {settemp2=settemp2*100;
    while(!key4);
原理图QX-mini51.pdf
154.08 KB, 下载次数: 20
原理图
ID:278006 发表于 2020-2-23 18:57 | 只看该作者
发个源码试试!
DS18b20 温度检测液晶显示-温度可调上下限1602显示.zip
58.11 KB, 下载次数: 19
