查看: 3679|回复: 2
51单片机自动凉衣服源程序电路图与实物图
电路原理图如下:
制作出来的实物图如下:
#include <REGX51.H>
#include <intrins.h>
#include <math.h>
#include <stdio.h>
sbit DATA=P1^0;
sbit MOTOR_A_1=P2^5;   //电机控制脚
sbit MOTOR_A_2=P2^6;    //电机控制脚
sbit EN_MOTOR_A =P2^7;  //电机控制脚
sbit k1=P3^2;                               //按键
sbit k2=P3^3;                               //按键
sbit k3=P3^4;                               //按键
sbit k4=P3^5;                               //按键
sbit k5=P3^6;
sbit CS   = P1^2;
sbit Clk = P1^3;
sbit DATI = P1^4;
sbit DATO = P1^4;
unsigned char dat = 0x00;
unsigned char count = 0x00;
unsigned char CH;
uchar mode=0;
sbit LED0=P2^3;
sbit LED1=P2^4;
uchar temp,humi;
uchar error;                                //用于检验是否出现错误
uchar checksum,nn;                          //CRC
uchar nn;                                  //蜂鸣器
uchar TEMP_data[6];                         //用于记录实测的温度
uchar CO2_data[6];                         //用于记录实测的温度
uchar  U8FLAG,k;
uchar  U8count,U8temp;
uchar  U8T_data_H,U8T_data_L,U8RH_data_H,U8RH_data_L,U8checkdata;
uchar  U8T_data_H_temp,U8T_data_L_temp,U8RH_data_H_temp,U8RH_data_L_temp,U8checkdata_temp;
uchar  U8comdata;
uchar  count, count_r=0;
void Delay1(uint );
void  Delay_10us(void);
void  COM(void);
uchar RH(void);
unsigned char adc0832(unsigned char CH)
     unsigned char i,test,adval;
     adval = 0x00;
     test = 0x00;
     Clk = 0;
     DATI = 1;
     _nop_();
     CS = 0;
     _nop_();
     Clk = 1;
     _nop_();
    if ( CH == 0x00 )
       Clk = 0;
       DATI = 1;
       _nop_();
       Clk = 1;
       _nop_();
       Clk = 0;
       DATI = 0;
       _nop_();
       Clk = 1;
       _nop_();
       Clk = 0;
       DATI = 1;
       _nop_();
       Clk = 1;
       _nop_();
       Clk = 0;
       DATI = 1;
       _nop_();
       Clk = 1;
       _nop_();
      Clk = 0;
      DATI = 1;
     for( i = 0;i < 8;i++ )
       _nop_();
       adval <<= 1;
       Clk = 1;
       _nop_();
       Clk = 0;
       if (DATO)
          adval |= 0x01;
          adval |= 0x00;
      for (i = 0; i < 8; i++)
           test >>= 1;
           if (DATO)
              test |= 0x80;
              test |= 0x00;
          _nop_();
          Clk = 1;
          _nop_();
          Clk = 0;
      if (adval == test)
           dat = test;
      _nop_();
       CS = 1;
       DATO = 1;
       Clk = 1;
      return dat;
void Delay1(uint j)
    uchar i;
    for(;j>0;j--)
  for(i=0;i<27;i++);
    uchar i;
    i--;
    i--;
    i--;
    i--;
    i--;
    i--;
void  COM(void)
    uchar i;
    for(i=0;i<8;i++)
       U8FLAG=2;
     while((!DATA)&&U8FLAG++);
  Delay_10us();
  Delay_10us();
  Delay_10us();
    U8temp=0;
        if(DATA)U8temp=1;
  U8FLAG=2;
  while((DATA)&&U8FLAG++);
     if(U8FLAG==1)break;
//-----温湿度读取子程序 ------------
//----以下变量均为全局变量--------
//----温度高8位== U8T_data_H------
//----温度低8位== U8T_data_L------
//----湿度高8位== U8RH_data_H-----
//----湿度低8位== U8RH_data_L-----
//----校验 8位 == U8checkdata-----
//----调用相关子程序如下----------
//---- Delay();, Delay_10us();,COM();
uchar RH(void)
    DATA=0;        //主机拉低18ms
Delay1(180);      //原来为5
DATA=1;      //总线由上拉电阻拉高 主机延时20us
Delay_10us();
Delay_10us();
Delay_10us();
Delay_10us();
DATA=1;         //主机设为输入 判断从机响应信号
if(!DATA)      //判断从机是否有低电平响应信号 如不响应则跳出,响应则向下运行
     U8FLAG=2;
     while((!DATA)&&U8FLAG++); //判断从机是否发出 80us 的低电平响应信号是否结束
     U8FLAG=2;
    while((DATA)&&U8FLAG++);    //判断从机是否发出 80us 的高电平,如发出则进入数据接收状态
     COM();      //数据接收状态
     U8RH_data_H_temp=U8comdata;
     COM();
     U8RH_data_L_temp=U8comdata;
     COM();
     U8T_data_H_temp=U8comdata;
     COM();
     U8T_data_L_temp=U8comdata;
     COM();
     U8checkdata_temp=U8comdata;
     DATA=1;
     U8temp=(U8T_data_H_temp+U8T_data_L_temp+U8RH_data_H_temp+U8RH_data_L_temp); //数据校验
     if(U8temp==U8checkdata_temp)
        U8RH_data_H=U8RH_data_H_temp;
        U8RH_data_L=U8RH_data_L_temp;
        U8T_data_H=U8T_data_H_temp;
        U8T_data_L=U8T_data_L_temp;
        U8checkdata=U8checkdata_temp;
  return 1;
else            //传感器不响应
    return 0;
void delay(uint z)                          //延时函数z为毫秒数
   int a,b;
   for(a=z;a>0;a--)
   for(b=120;b>0;b--);
void key()
   if (k1==0)                               //调整按键检测
      delay(10);
      if (k1==0)
         mode=!mode;
    EN_MOTOR_A=0;  //电机启动,等于0停止
         while(k1==0);
   if (k2==0)                               //调整按键检测
      delay(10);
      if (k2==0)
      if(mode==0)
    EN_MOTOR_A=1;  //电机启动,等于0停止
    MOTOR_A_2 =0;  //正转
    MOTOR_A_1 =1;  //反转停止
         while(k2==0);
    if (k3==0)                               //调整按键检测
      delay(10);
      if (k3==0)
      if(mode==0)
    EN_MOTOR_A=1;  //电机停止
    MOTOR_A_1 =0;  //反转
    MOTOR_A_2 =1;  //正转停止
         while(k3==0);
   if(k4==0)
      delay(10);
      if(k4==0)
      if(MOTOR_A_2==0)
   EN_MOTOR_A=0;  //电机停止
    if(k5==0)
      delay(10);
      if(k5==0)
   if(MOTOR_A_1==0)
void main()                                                  //主函数
   int ch0_temp;
   ch0_temp=adc0832(0)*49/25;
   RH();                                               //测量温湿度
      temp=U8T_data_H;
      humi=U8RH_data_H;
    key();
   // LED1=0;
   //LED0=0;
     if(mode==0)
    LED1=0;
    LED0=1;
    if(mode==1)
    LED1=1;
    LED0=0;
    if(k4==0)
     if(MOTOR_A_2==0)
    else if(k5==0)
     if(MOTOR_A_1==0)
     if((ch0_temp>250)&&(humi<75))
        MOTOR_A_2 =0;  //正转
     else if((ch0_temp<250)||(humi>75))//光照不足,湿度大于50
         MOTOR_A_1 =0;  //反转
收藏收藏1 分享淘帖 顶 踩
ID:619604 发表于 2019-10-17 23:24 | 只看该作者
参考参考,感谢分享
ID:253767 发表于 2019-10-18 07:15 | 只看该作者
谢谢分享!!!
