查看: 6607|回复: 7
51单片机简易密码锁PCB电路图源程序(1602显示)
  1. //包含头文件
  2. #include <REG51.h>
  3. #include<intrins.h>
  4. //宏定义
  5. #define LCM_Data  P0                  //将P0口定义为LCM_Data
  6. #define uchar unsigned char
  7. #define uint  unsigned int
  8. //1602的控制脚
  9. sbit lcd1602_rs=P2^5;
  10. sbit lcd1602_rw=P2^6;
  11. sbit lcd1602_en=P2^7;
  12. sbit rs=  P2^5;
  13. sbit en = P2^7;
  14. sbit rw = P2^6;
  15. sbit busy=P0^7;//LCD1602显示汉字的管脚
  16. sbit Scl=P3^4;                        //24C02串行时钟
  17. sbit Sda=P3^5;                        //24C02串行数据
  18. sbit ALAM = P2^1;                //报警
  19. sbit KEY = P3^6;                //开锁
  20. bit  pass=0;                        //密码正确标志
  21. bit  ReInputEn=0;                //重置输入允许标志
  22. bit  s3_keydown=0;                //3秒按键标志位
  23. bit  key_disable=0;                //锁定键盘标志
  24. unsigned char countt0,second;        //t0中断计数器,秒计数器
  25. void Delay5Ms(void);                //声明延时函数
  26. unsigned char code a[]={0xFE,0xFD,0xFB,0xF7};                                 //控盘扫描控制表
  27. //液晶显示数据数组
  28. unsigned char dui[] = {0x0,0x0,0x1A,0xA,0x1A,0x12,0x12,0x15}; //队的字符表
  29. unsigned char dian[]={0x4,0x1F,0x15,0x1F,0x15,0x1F,0x4,0x7}; //大的字符表                                     //月的字符表
  30. unsigned char lan[] ={0xA,0x1B,0xA,0xC,0x1F,0x1A,0xE,0x1F}; //蓝的字符表
  31. unsigned char da[] ={0x0,0x4,0x4,0x1F,0x4,0xA,0x11,0x0};//大的字符表
  32. unsigned char code start_line[]        = {"password:       "};
  33. unsigned char code name[]                  = {"==             =="};        //显示名称
  34. unsigned char code Correct[]         = {"     correct    "};                //输入正确
  35. unsigned char code Error[]           = {"      error     "};          //输入错误
  36. unsigned char code codepass[]        = {"      pass      "};
  37. unsigned char code LockOpen[]        = {"      open      "};                //OPEN
  38. unsigned char code SetNew[]         = {"SetNewWordEnable"};
  39. unsigned char code Input[]           = {"input:          "};                //INPUT
  40. unsigned char code ResetOK[]         = {"ResetPasswordOK "};
  41. unsigned char code initword[]        = {"Init password..."};
  42. unsigned char code Er_try[]                = {"error,try again!"};
  43. unsigned char code again[]                = {"input again     "};
  44. unsigned char InputData[6];        //输入密码暂存区
  45. unsigned char CurrentPassword[6]={0,0,0,0,0,0};                         //读取EEPROM密码暂存数组
  46. unsigned char TempPassword[6];
  47. unsigned char N=0;                                //密码输入位数记数
  48. unsigned char ErrorCont;                        //错误次数计数
  49. unsigned char CorrectCont;                        //正确输入计数
  50. unsigned char ReInputCont;                         //重新输入计数
  51. unsigned char code initpassword[6]={0,0,0,0,0,0};                        //输入管理员密码后将密码初始为000000
  52. unsigned char code adminpassword[6]={2,0,1,9,0,1};                //输入管理员密码后将密码初始为000000
  53. //*****************************************************************************
  54. //函数功能:LCD延时子程序
  55. //入口参数:ms
  56. //出口参数:
  57. //*****************************************************************************/
  58. void DelayUs2x(unsigned char t)
  59. {
  60. while(--t);
  61. }
  62. void DelayMs(unsigned char t)
  63. {
  64.
  65. while(t--)
  66. {
  67.      //大致延时1mS
  68.      DelayUs2x(245);
  69.          DelayUs2x(245);
  70. }
  71. }
  72. /*****************************************************************************
  73. 函数功能:测试LCD忙碌状态
  74. 入口参数:
  75. 出口参数:busy_flag
  76. *****************************************************************************/
  77. bit lcd_check_busy()
  78. {
  79. P0=0Xff;
  80. rs = 0;
  81. rw = 1;
  82. en = 0;
  83. _nop_();
  84. en=1;
  85. return busy;
  86. }
  87. /*****************************************************************************
  88. 函数功能:写指令数据到LCD子程序
  89. 入口参数:cmd
  90. 出口参数:
  91. *****************************************************************************/
  92. void lcd_wcmd(unsigned char cmd)
  93. {
  94. while(lcd_check_busy());    //判断LCD是否忙碌
  95. rs = 0;
  96. rw = 0;
  97. en = 1;
  98. P0 = cmd;
  99. _nop_();
  100. en = 0;
  101. }
  102. /*****************************************************************************
  103. 函数功能:设定显示位置子程序
  104. 入口参数:pos
  105. 出口参数:
  106. *****************************************************************************/
  107. void lcd_pos(unsigned char pos)
  108. {
  109. lcd_wcmd(pos | 0x80);
  110. }
  111. /*****************************************************************************
  112. 函数功能:写入显示数据到LCD子程序
  113. 入口参数:dat
  114. 出口参数:
  115. *****************************************************************************/
  116. void lcd_wdat(unsigned char dat)
  117. {
  118. while(lcd_check_busy()); //判断LCD是否忙碌
  119. rs = 1;
  120. rw = 0;
  121. en = 1;
  122. P0 = dat;
  123. _nop_();
  124. en = 0;
  125. }
  126. /*****************************************************************************
  127. 函数功能:LCD初始化子程序
  128. 入口参数:
  129. 出口参数:
  130. *****************************************************************************/
  131. void lcd_init1()
  132. {
  133. lcd_wcmd(0x38);
  134. DelayMs(5);
  135. lcd_wcmd(0x38);
  136. DelayMs(5);
  137. lcd_wcmd(0x38);
  138. DelayMs(5);
  139. lcd_wcmd(0x38);    //8位数据,双行显示,5*7点阵
  140. lcd_wcmd(0x08);    //显示关闭,无光标,光标不显示
  141. lcd_wcmd(0x01);    //清显示
  142. lcd_wcmd(0x06);    //光标右移
  143. DelayMs(5);
  144. lcd_wcmd(0x0c);    //开显示,有光标,光标闪烁
  145. }
  146. /****************************************************************************
  147. 函数功能:建立蓝电大队字符
  148. 入口参数:
  149. 出口参数:
  150. *****************************************************************************/
  151. void lcd_setups()
  152. {unsigned int i;
  153. lcd_wcmd(0x40);
  154. for(i=0;i<8;i++)
  155. {
  156.         lcd_wdat(lan[i]);
  157. }
  158. lcd_wcmd(0x48);
  159. for(i=0;i<8;i++)
  160. {lcd_wdat(dian[i]);
  161. }
  162. lcd_wcmd(0x50);
  163. for(i=0;i<8;i++)
  164. {lcd_wdat(da[i]);
  165. }
  166. lcd_wcmd(0x58);
  167. for(i=0;i<8;i++)
  168. {lcd_wdat(dui[i]);
  169. }
  170. }
  171. //LCD1602显示汉字子程序
  172. //=====================5ms延时==============================
  173. void Delay5Ms(void)
  174. {
  175.         unsigned int TempCyc = 5552;
  176.         while(TempCyc--);
  177. }
  178. //===================400ms延时==============================
  179. void Delay400Ms(void)
  180. {
  181. unsigned char TempCycA = 5;
  182. unsigned int TempCycB;
  183. while(TempCycA--)
  184. {
  185.   TempCycB=7269;
  186.   while(TempCycB--);
  187. }
  188. }
  189. //=============================================================================================
  190. //================================24C02========================================================
  191. //=============================================================================================
  192. void mDelay(uint t) //延时
  193. {
  194.         uchar i;
  195.            while(t--)
  196.            {
  197.                    for(i=0;i<125;i++)
  198.                    {;}
  199.            }
  200. }
  201.
  202. void Nop(void)                  //空操作
  203. {
  204.         _nop_();                  //仅作延时用一条语句大约1us
  205.         _nop_();
  206.         _nop_();
  207.         _nop_();
  208. }
  209. /*****24c02程序参照24c02时序图*****/
  210. /*起始条件*/
  211. void Start(void)
  212. {
  213.         Sda=1;
  214.         Scl=1;
  215.         Nop();
  216.         Sda=0;
  217.         Nop();
  218. }
  219. /*停止条件*/
  220. void Stop(void)
  221. {
  222.         Sda=0;
  223.         Scl=1;
  224.         Nop();
  225.         Sda=1;
  226.         Nop();
  227. }
  228. /*应答位*/
  229. void Ack(void)
  230. {
  231.         Sda=0;
  232.         Nop();
  233.         Scl=1;
  234.         Nop();
  235.         Scl=0;
  236. }
  237. /*反向应答位*/
  238. void NoAck(void)
  239. {
  240.         Sda=1;
  241.         Nop();
  242.         Scl=1;
  243.         Nop();
  244.         Scl=0;
  245. }
  246. /*发送数据子程序,Data为要求发送的数据*/
  247. void Send(uchar Data)
  248. {
  249.            uchar BitCounter=8;
  250.            uchar temp;
  251.            do
  252.            {
  253.                    temp=Data;                                           //将待发送数据暂存temp
  254.                    Scl=0;
  255.                    Nop();
  256.                    if((temp&0x80)==0x80)                   //将读到的数据&0x80
  257.                    Sda=1;
  258.                    else
  259.                    Sda=0;
  260.                    Scl=1;
  261.                    temp=Data<<1;                                   //数据左移
  262.                    Data=temp;                                           //数据左移后重新赋值Data
  263.                    BitCounter--;                                   //该变量减到0时,数据也就传送完成了
  264.            }
  265.            while(BitCounter);                                   //判断是否传送完成
  266.            Scl=0;
  267. }
  268. /*读一字节的数据,并返回该字节值*/
  269. uchar Read(void)
  270. {
  271.     uchar temp=0;
  272.         uchar temp1=0;
  273.         uchar BitCounter=8;
  274.         Sda=1;
  275.         do
  276.         {
  277.                 Scl=0;
  278.                 Nop();
  279.                 Scl=1;
  280.                 Nop();
  281.                 if(Sda)                                   //数据位是否为1
  282.                         temp=temp|0x01;           //为1 temp的最低位为1(|0x01,就是将最低位变为1)
  283.                 else                                   //如果为0
  284.                         temp=temp&0xfe;           //temp最低位为0(&0xfe(11111110)最低位就是0)
  285.                 if(BitCounter-1)           //BitCounter减1后是否为真
  286.                 {
  287.                         temp1=temp<<1;           //temp左移
  288.                         temp=temp1;
  289.                 }
  290.                 BitCounter--;                   //BitCounter减到0时,数据就接收完了
  291.         }
  292.         while(BitCounter);                   //判断是否接收完成
  293.         return(temp);
  294. }
  295. void WrToROM(uchar Data[],uchar Address,uchar Num)
  296. {
  297.   uchar i;
  298.   uchar *PData;
  299.   PData=Data;
  300.   for(i=0;i<Num;i++)
  301.   {
  302.   Start();
  303.   Send(0xa0);
  304.   Ack();
  305.   Send(Address+i);
  306.   Ack();
  307.   Send(*(PData+i));
  308.   Ack();
  309.   Stop();
  310.   mDelay(20);
  311.   }
  312. }
  313. void RdFromROM(uchar Data[],uchar Address,uchar Num)
  314. {
  315.   uchar i;
  316.   uchar *PData;
  317.   PData=Data;
  318.   for(i=0;i<Num;i++)
  319.   {
  320.   Start();
  321.   Send(0xa0);
  322.   Ack();
  323.   Send(Address+i);
  324.   Ack();
  325.   Start();
  326.   Send(0xa1);
  327.   Ack();
  328.   *(PData+i)=Read();
  329.   Scl=0;
  330.   NoAck();
  331.   Stop();
  332.   }
  333. }
  334. //==================================================================================================
  335. //=======================================LCD1602====================================================
  336. //==================================================================================================
  337. #define yi 0x80 //LCD第一行的初始位置,因为LCD1602字符地址首位D7恒定为1(100000000=80)
  338. #define er 0x80+0x40 //LCD第二行初始位置(因为第二行第一个字符位置地址是0x40)
  339. //----------------延时函数,后面经常调用----------------------
  340. void delay(uint xms)//延时函数,有参函数
  341. {
  342.         uint x,y;
  343.         for(x=xms;x>0;x--)
  344.          for(y=110;y>0;y--);
  345. }
  346. //--------------------------写指令---------------------------
  347. void write_1602com(uchar com)//****液晶写入指令函数****
  348. {
  349.         lcd1602_rs=0;//数据/指令选择置为指令
  350.         lcd1602_rw=0; //读写选择置为写
  351.         P0=com;//送入数据
  352.         delay(1);
  353.         lcd1602_en=1;//拉高使能端,为制造有效的下降沿做准备
  354.         delay(1);
  355.         lcd1602_en=0;//en由高变低,产生下降沿,液晶执行命令
  356. }
  357. //-------------------------写数据-----------------------------
  358. void write_1602dat(uchar dat)//***液晶写入数据函数****
  359. {
  360.         lcd1602_rs=1;//数据/指令选择置为数据
  361.         lcd1602_rw=0; //读写选择置为写
  362.         P0=dat;//送入数据
  363.         delay(1);
  364.         lcd1602_en=1; //en置高电平,为制造下降沿做准备
  365.         delay(1);
  366.         lcd1602_en=0; //en由高变低,产生下降沿,液晶执行命令
  367. }
  368. //-------------------------初始化-------------------------
  369. void lcd_init(void)
  370. {
  371.         write_1602com(0x38);//设置液晶工作模式,意思:16*2行显示,5*7点阵,8位数据
  372.         write_1602com(0x0c);//开显示不显示光标
  373.         write_1602com(0x06);//整屏不移动,光标自动右移
  374.         write_1602com(0x01);//清显示
  375. }
  376. //========================================================================================
  377. //=========================================================================================
  378. //==============将按键值编码为数值=========================
  379. unsigned char coding(unsigned char m)
  380. {
  381.         unsigned char k;
  382.         switch(m)
  383.         {
  384.                 case (0x11): k=1;break;
  385.                 case (0x21): k=2;break;
  386.                 case (0x41): k=3;break;
  387.                 case (0x81): k='A';break;
  388.                 case (0x12): k=4;break;
  389.                 case (0x22): k=5;break;
  390.                 case (0x42): k=6;break;
  391.                 case (0x82): k='B';break;
  392.                 case (0x14): k=7;break;
  393.                 case (0x24): k=8;break;
  394.                 case (0x44): k=9;break;
  395.                 case (0x84): k='C';break;
  396.                 case (0x18): k='*';break;
  397.                 case (0x28): k=0;break;
  398.                 case (0x48): k='#';break;
  399.                 case (0x88): k='D';break;
  400.         }
  401.         return(k);
  402. }
  403. //=====================按键检测并返回按键值===============================
  404. unsigned char keynum(void)
  405. {
  406.         unsigned char row,col,i;
  407.         P1=0xf0;
  408.         if((P1&0xf0)!=0xf0)
  409.         {
  410.                    Delay5Ms();
  411.         Delay5Ms();
  412.                    if((P1&0xf0)!=0xf0)
  413.                 {
  414.                     row=P1^0xf0;          //确定行线
  415.                         i=0;
  416.                         P1=a[i];                  //精确定位
  417.                         while(i<4)
  418.                         {
  419.                                  if((P1&0xf0)!=0xf0)
  420.                                   {
  421.                                            col=~(P1&0xff);          //确定列线
  422.                                            break;            //已定位后提前退出
  423.                                   }
  424.                                 else
  425.                                   {
  426.                                            i++;
  427.                                            P1=a[i];
  428.                                   }
  429.                         }
  430.                 }
  431.                 else
  432.                 {
  433.                         return 0;
  434.                 }
  435.                 while((P1&0xf0)!=0xf0);
  436.                 return (row|col);                         //行线与列线组合后返回
  437.         }
  438.         else return 0;                                 //无键按下时返回0
  439. }
  440. //=======================一声提示音,表示有效输入========================
  441. void OneAlam(void)
  442. {
  443.         ALAM=0;
  444.         Delay5Ms();
  445.     ALAM=1;
  446. }
  447. //========================二声提示音,表示操作成功========================
  448. void TwoAlam(void)
  449. {
  450.         ALAM=0;
  451.         Delay5Ms();
  452.     ALAM=1;
  453.     Delay5Ms();
  454.         ALAM=0;
  455.         Delay5Ms();
  456.     ALAM=1;
  457. }
  458. //========================三声提示音,表示错误========================
  459. void ThreeAlam(void)
  460. {
  461.         ALAM=0;
  462.         Delay5Ms();
  463.     ALAM=1;
  464.     Delay5Ms();
  465.         ALAM=0;
  466.         Delay5Ms();
  467.     ALAM=1;
  468.     Delay5Ms();
  469.         ALAM=0;
  470.         Delay5Ms();
  471.     ALAM=1;
  472. }
  473. //=======================显示提示输入=========================
  474. void DisplayChar(void)
  475. {
  476.         unsigned char i;
  477.         if(pass==1)
  478.         {
  479.                 //DisplayListChar(0,1,LockOpen);
  480.                 write_1602com(er);                                   //在二行开始显示
  481.                 for(i=0;i<16;i++)
  482.                 {
  483.                         write_1602dat(LockOpen[i]);           //显示open 开锁成功
  484.                 }
  485.         }
  486.         else
  487.         {
  488.                 if(N==0)
  489.                 {
  490.                         //DisplayListChar(0,1,Error);
  491.                         write_1602com(er);
  492.                         for(i=0;i<16;i++)
  493.                         {
  494.                                 write_1602dat(Error[i]);        //显示错误
  495.                         }
  496.                 }
  497.                 else
  498.                 {
  499.                         //DisplayListChar(0,1,start_line);
  500.                         write_1602com(er);
  501.                         for(i=0;i<16;i++)
  502.                         {
  503.                                 write_1602dat(start_line[i]);//显示开始输入
  504.                         }
  505.                 }
  506.         }
  507. }
  508. //========================重置密码==================================================
  509. //==================================================================================
  510. void ResetPassword(void)
  511. {
  512.         unsigned char i;
  513.         unsigned char j;
  514.         if(pass==0)
  515.         {
  516.                 pass=0;
  517.                 DisplayChar();           //显示错误
  518.                 ThreeAlam();           //没开锁时按下重置密码报警3声
  519.         }
  520.         else                                   //开锁状态下才能进行密码重置程序
  521.         {
  522.             if(ReInputEn==1)   //开锁状态下,ReInputEn置1,重置密码允许
  523.                 {
  524.                         if(N==6)           //输入6位密码
  525.                         {
  526.                                 ReInputCont++;                        //密码次数计数
  527.                                 if(ReInputCont==2)                //输入两次密码
  528.                                 {
  529.                                         for(i=0;i<6;)
  530.                                         {
  531.                                                 if(TempPassword[i]==InputData[i])        //将两次输入的新密码作对比
  532.                                                         i++;
  533.                                                 else        //如果两次的密码不同
  534.                                                 {
  535.                                                         //DisplayListChar(0,1,Error);
  536.                                                         write_1602com(er);
  537.                                                         for(j=0;j<16;j++)
  538.                                                         {
  539.        write_1602dat(Error[j]);        //显示错误Error
  540.                                                         }
  541.                                                         ThreeAlam();                        //错误提示
  542.                                                         pass=0;                                        //关锁
  543.                                                         ReInputEn=0;                        //关闭重置功能,
  544.                                                         ReInputCont=0;
  545.                                                         DisplayChar();
  546.                                                         break;
  547.                                                 }
  548.                                         }
  549.                                         if(i==6)
  550.                                         {
  551.                                                 //DisplayListChar(0,1,ResetOK);
  552.                                                 write_1602com(er);
  553.                                                 for(j=0;j<16;j++)
  554.                                                 {
  555.                                                         write_1602dat(ResetOK[j]);          //密码修改成功,显示
  556.                                                 }
  557.                                                 TwoAlam();                                //操作成功提示
  558.                                                  WrToROM(TempPassword,0,6);                //将新密码写入24C02存储
  559.                                                 ReInputEn=0;
  560.                                         }
  561.                                         ReInputCont=0;
  562.                                         CorrectCont=0;
  563.                                 }
  564.                                 else                                          //输入一次密码时
  565.                                 {
  566.                                         OneAlam();
  567.                                         //DisplayListChar(0, 1, again);                 //显示再次输入一次
  568.                                         write_1602com(er);
  569.                                         for(j=0;j<16;j++)
  570.                                         {
  571.                                                 write_1602dat(again[j]);                        //显示再输入一次
  572.                                         }
  573.                                         for(i=0;i<6;i++)
  574.                                         {
  575.                                                 TempPassword[i]=InputData[i];                //将第一次输入的数据暂存起来
  576.                                         }
  577.                                 }
  578.                         N=0;                                                //输入数据位数计数器清零
  579.                    }
  580.             }
  581.         }
  582. }
  583. //=======================输入密码错误超过三过,报警并锁死键盘======================
  584. void Alam_KeyUnable(void)
  585. {
  586.         P1=0x00;
  587.         {
  588.                 ALAM=~ALAM;                                 //蜂鸣器一直闪烁鸣响
  589.                 Delay5Ms();
  590.         }
  591. }
  592. //=======================取消所有操作============================================
  593. void Cancel(void)
  594. {
  595.         unsigned char i;
  596.         unsigned char j;
  597.         //DisplayListChar(0, 1, start_line);
  598.         write_1602com(er);
  599.         for(j=0;j<16;j++)
  600.         {
  601.                 write_1602dat(start_line[j]);          //显示开机输入密码界面
  602.         }
  603.         TwoAlam();                                //提示音
  604.         for(i=0;i<6;i++)
  605.         {
  606.                 InputData[i]=0;                //将输入密码清零
  607.         }
  608.         KEY=1;                                        //关闭锁
  609.         ALAM=1;                                        //报警关
  610.         pass=0;                                        //密码正确标志清零
  611.         ReInputEn=0;                        //重置输入充许标志清零
  612.         ErrorCont=0;                        //密码错误输入次数清零
  613.         CorrectCont=0;                        //密码正确输入次数清零
  614.         ReInputCont=0;                        //重置密码输入次数清零
  615.         s3_keydown=0;
  616.         key_disable=0;                        //锁定键盘标志清零
  617.         N=0;                                        //输入位数计数器清零
  618. }
  619. //==========================确认键,并通过相应标志位执行相应功能===============================
  620. void Ensure(void)
  621. {
  622.         unsigned char i,j;
  623.         RdFromROM(CurrentPassword,0,6);                                         //从24C02里读出存储密码
  624.     if(N==6)
  625.         {
  626.             if(ReInputEn==0)                                                        //重置密码功能未开启
  627.                 {
  628.                         for(i=0;i<6;)
  629.                            {
  630.                                 if(CurrentPassword[i]==InputData[i])        //判断输入密码和24c02中的密码是否相同
  631.                                 {
  632.                                         i++;        //相同一位 i就+1
  633.                                 }
  634.                                 else        //如果有密码不同
  635.                                 {
  636.                                         ErrorCont++;                                                //错误次数++
  637.                                         if(ErrorCont==3)                        //错误输入计数达三次时,报警并锁定键盘
  638.                                         {
  639.                                                 write_1602com(er);
  640.                                                 for(i=0;i<16;i++)
  641.                                                 {
  642.                                                         write_1602dat(Error[i]);
  643.                                                 }
  644.                                                 do
  645.                                                 Alam_KeyUnable();
  646.                                                 while(1);
  647.                                         }
  648.                                         else                                         //错误次数小于3次时,锁死键盘3秒,然后重新可以输入
  649.                                         {
  650.                                                 TR0=1;                                //开启定时
  651.                                                 key_disable=1;                        //锁定键盘
  652.                                                 pass=0;                                        //pass位清零
  653.                                                 break;                                        //跳出
  654.                                         }
  655.                                 }
  656.                         }
  657.                         if(i==6)                                         //密码输入对时
  658.                         {
  659.                                 if((InputData[0]==adminpassword[0])&&(InputData[1]==adminpassword[1])&&(InputData[2]==adminpassword[2])&&(InputData[3]==adminpassword[3])&&(InputData[4]==adminpassword[4])&&(InputData[5]==adminpassword[5]))
  660.                                    {
  661.                                         WrToROM(initpassword,0,6);                                 //强制将初始密码写入24C02存储
  662.                                         write_1602com(er);
  663.                                         for(j=0;j<16;j++)
  664.                                         {
  665.                                                 write_1602dat(initword[j]);                                //显示初始化密码
  666.                                         }
  667.                                         TwoAlam();        //成功提示音
  668.                                         Delay400Ms();        //延时400ms
  669.                                         TwoAlam();        //成功提示音
  670.                                         N=0;        //输入位数计数器清零
  671.                                 }
  672.                                 else
  673.                                 {
  674.                                         CorrectCont++;                                        //输入正确变量++
  675.                                         if(CorrectCont==1)                                //正确输入计数,当只有一次正确输入时,开锁
  676.                                         {
  677.                                                 //DisplayListChar(0,1,LockOpen);
  678.                                                 write_1602com(er);
  679.                                                 for(j=0;j<16;j++)
  680.                                                 {
  681.                                                         write_1602dat(LockOpen[j]);                  //显示open开锁画面
  682.                                                 }
  683.                                                 TwoAlam();                        //操作成功提示音
  684.                                                 KEY=0;        //开锁
  685.                                                 pass=1;        //置正确标志位
  686.                                                 TR0=1;        //开启定时
  687.                                                 for(j=0;j<6;j++)        //将输入清除
  688.                                                 {
  689.                                                         InputData[i]=0;        //开锁后将输入位清零
  690.                                                 }
  691.                                         }
  692.                                         else        //当两次正确输入时,开启重置密码功能
  693.                                         {
  694.                                                 write_1602com(er);
  695.                                                 for(j=0;j<16;j++)
  696.                                                 {
  697.                                                         write_1602dat(SetNew[j]);                                        //显示重置密码界面
  698.                                                 }
  699.                                                 TwoAlam();        //操作成功提示
  700.                                                 ReInputEn=1;        //允许重置密码输入
  701.                                                 CorrectCont=0;        //正确计数器清零
  702.                                         }
  703.                                 }
  704.                           }
  705.
  706.                         else                        //=========================当第一次使用或忘记密码时可以用131420对其密码初始化============
  707.                         {
  708.                                 if((InputData[0]==adminpassword[0])&&(InputData[1]==adminpassword[1])&&(InputData[2]==adminpassword[2])&&(InputData[3]==adminpassword[3])&&(InputData[4]==adminpassword[4])&&(InputData[5]==adminpassword[5]))
  709.                                    {
  710.                                         WrToROM(initpassword,0,6);                                 //强制将初始密码写入24C02存储
  711.                                         write_1602com(er);
  712.                                         for(j=0;j<16;j++)
  713.                                         {
  714.                                                 write_1602dat(initword[j]);                                //显示初始化密码
  715.                                         }
  716.                                         TwoAlam();        //成功提示音
  717.                                         Delay400Ms();        //延时400ms
  718.                                         TwoAlam();        //成功提示音
  719.                                         N=0;        //输入位数计数器清零
  720.                                 }
  721.                                 else        //密码输入错误
  722.                                 {
  723.                                         write_1602com(er);
  724.                                         for(j=0;j<16;j++)
  725.                                         {
  726.                                                 write_1602dat(Error[j]);                                 //显示错误信息
  727.                                         }
  728.                                         ThreeAlam();        //错误提示音
  729.                                         pass=0;
  730.                                 }
  731.                         }
  732.                 }
  733.                 else        //当已经开启重置密码功能时,而按下开锁键,
  734.                 {
  735.                         //DisplayListChar(0,1,Er_try);
  736.                         write_1602com(er);
  737.                         for(j=0;j<16;j++)
  738.                         {
  739.                                 write_1602dat(Er_try[j]);                          //错误,请重新输入
  740.                         }
  741.                         ThreeAlam();                                                          //错误提示音
  742.                 }
  743.         }
  744.         else                                   //密码没有输入到6位时,按下确认键时
  745.         {
  746.                 //DisplayListChar(0,1,Error);
  747.                 write_1602com(er);
  748.                 for(j=0;j<16;j++)
  749.                 {
  750.                         write_1602dat(Error[j]);                 //显示错误
  751.                 }
  752.                 ThreeAlam();        //错误提示音
  753.                 pass=0;
  754.         }
  755.
  756.         N=0;        //将输入数据计数器清零,为下一次输入作准备
  757. }
  758. //==============================主函数===============================
  759. void main(void)
  760. {
  761.         unsigned char KEY,NUM;
  762.         unsigned char i,j;
  763.         P1=0xFF;                                    //P1口复位
  764.         TMOD=0x11;                                   //定义工作方式
  765.         TL0=0xB0;
  766.         TH0=0x3C;                                   //定时器赋初值
  767.         EA=1;                                           //打开中断总开关
  768.         ET0=1;                                           //打开中断允许开关
  769.         TR0=0;                                           //打开定时器开关
  770.         Delay400Ms();         //启动等待,等LCM讲入工作状态
  771.         lcd_init();         //LCD初始化
  772.
  773.         write_1602com(yi);//日历显示固定符号从第一行第0个位置之后开始显示
  774.
  775.                 lcd_setups();              //建立字符
  776.                 for(i=0;i<16;i++)
  777.         {
  778.                 write_1602dat(name[i]);//向液晶屏写开机画面
  779.         }
  780.         write_1602com(er);
  781.         for(i=0;i<16;i++)
  782.         {
  783.                 write_1602dat(start_line[i]);//写输入密码等待界面
  784.         }
  785.         write_1602com(er+9);        //设置光标位置
  786.         write_1602com(0x0f);        //设置光标为闪烁
  787.         Delay5Ms(); //延时片刻(可不要)
  788.         N=0;                        //初始化数据输入位数
  789.
  790.                 lcd_pos(0x04);   //起始列位置          //显示蓝
  791. lcd_wdat(0x00);
  792. lcd_pos(0x06);//终止列位置
  793. lcd_pos(0x06);             //显示电
  794. lcd_wdat(0x01);
  795. lcd_pos(0x08);
  796. lcd_pos(0x08);            //显示大
  797. lcd_wdat(0x02);
  798. lcd_pos(0x010);
  799.
  800. lcd_pos(0x0a);            //显示队
  801. lcd_wdat(0x03);
  802. lcd_pos(0x0b);
  803.         while(1)                 //进入循环
  804.         {
  805.                 if(key_disable==1)                                                //锁定键盘标志为1时
  806.                         Alam_KeyUnable();                                        //报警键盘锁
  807.                 else
  808.                         ALAM=1;        //关报警
  809.                 KEY=keynum();                                                        //读按键的位置码
  810.                 if(KEY!=0)        //当有按键按下时
  811.                 {
  812.                         if(key_disable==1)                                        //锁定键盘标志为1时
  813.                         {
  814.                                 second=0;                                                //秒清零
  815.                         }
  816.                         else        //没有锁定键盘时
  817.                         {
  818.                                 NUM=coding(KEY);                                //根据按键的位置将其编码,编码值赋值给NUM
  819.                                 {
  820.                                         switch(NUM)                                        //判断按键值
  821.                                         {
  822.                                                 case ('A'):         ;                                         break;
  823.                                                 case ('B'):                ;                                     break;
  824.                                                 case ('C'):
  825.        write_1602com(yi);//日历显示固定符号从第一行第0个位置之后开始显示
  826.        for(i=0;i<16;i++)
  827.        {
  828.        write_1602dat(name[i]);//向液晶屏写开机画面
  829.        }
  830.        if(N>=1) N--;        OneAlam();        //按键提示音
  831.        //DisplayOneChar(6+N,1,'*');
  832.        for(j=N;j<16;j++)
  833.        {
  834.        write_1602com(er+6+j);
  835.        write_1602dat(' ');
  836.        }
  837.        for(j=0;j<N;j++)
  838.        {
  839.        write_1602com(er+6+j);                                //显示位数随输入增加而增加
  840.        write_1602dat('*');                                        //但不显示实际数字,用*代替
  841.        }
  842.        InputData[N]=N+4;
  843.        break;                //ABC是无定义按键
  844.                                                 case ('D'): ResetPassword();                break;      //重新设置密码
  845.                                                 case ('*'): Cancel();                                break;      //取消当前输入
  846.                                                 case ('#'): Ensure();                                 break;           //确认键,
  847.                                                 default:        //如果不是功能键按下时,就是数字键按下
  848.                                                 {
  849.                                                         //DisplayListChar(0,1,Input);
  850.                                                         if(N<6)                                                           //当输入的密码少于6位时,接受输入并保存,大于6位时则无效。
  851.                                                         {
  852.        write_1602com(er);
  853.        for(i=0;i<16;i++)
  854.        {
  855.        write_1602dat(Input[i]);                                //显示输入画面
  856.        }
  857.        OneAlam();        //按键提示音
  858.        for(j=0;j<=N;j++)
  859.        {
  860.        write_1602com(er+6+j);                                //显示位数随输入增加而增加
  861.        write_1602dat('*');                                        //但不显示实际数字,用*代替
  862.        }
  863.        InputData[N]=NUM;                                                //将数字键的码赋值给InputData[]数组暂存
  864.        N++;        //密码位数加
  865.                                                         }
  866.                                                         else        //输入数据位数大于6后,忽略输入
  867.                                                         {
  868.        N=6;        //密码输入大于6位时,不接受输入
  869.        break;
  870.                                                         }
  871.                                                 }
  872.                                         }
  873.                                 }
  874.                         }
  875.                  }
  876.         }
  877. }
  878. //*********************************中断服务函数**************************************
  879. void  time0_int(void) interrupt 1                    //定时器T0
  880. {
  881.         TL0=0xB0;
  882.         TH0=0x3C;                  //定时器重新赋初值
  883.         //TR0=1;
  884.         countt0++;                           //计时变量加,加1次时50ms
  885.           if(countt0==20)                   //加到20次就是1s
  886.            {
  887.                 countt0=0;                   //变量清零
  888.                 second++;                   //秒加
  889.                 if(pass==1)                   //开锁状态时
  890.                 {
  891.                         if(second==1)                        //秒加到1s时
  892.                         {
  893.                                 TR0=0;                                //关定时器
  894.                                 TL0=0xB0;
  895.                                 TH0=0x3C;                        //再次赋初值
  896.                                 second=0;                        //秒清零
  897.                         }
  898.                 }
  899.                 else                                                //不在开锁状态时
  900.                 {
  901.                         if(second==3)                        //秒加到3时
  902.                         {
  903.                                 TR0=0;                                //关闭定时器
  904.                                 second=0;                        //秒清零
  905.                                 key_disable=0;                //锁定键盘清零
  906.                                 s3_keydown=0;
  907.                                 TL0=0xB0;
  908.                                 TH0=0x3C;                        //重新赋初值
  909.                         }
  910.                         else
  911.                             TR0=1;                                //打开定时器
  912.                 }
  913.
  914.            }
  915. }
11-视频讲解.rar (9.03 MB, 下载次数: 71)
密码锁2.rar (66.48 KB, 下载次数: 104)
密码锁硬件图.7z (2.07 MB, 下载次数: 100)
收藏收藏10 分享淘帖 顶顶2 踩踩
ID:599674 发表于 2019-10-25 21:09 | 只看该作者
感谢分享
ID:628333 发表于 2019-10-28 15:00 | 只看该作者
为什么我下来用不了
ID:393768 发表于 2019-10-31 23:54 | 只看该作者
请问LCD1602 只能显示d第一行的白方快是咋回事
ID:253767 发表于 2019-11-1 07:53 | 只看该作者
谢谢分享!!!
ID:634141 发表于 2019-11-1 23:08 | 只看该作者
不错,学习中
ID:679122 发表于 2020-1-3 23:50 | 只看该作者
收藏一波
ID:795477 发表于 2020-7-2 11:18 | 只看该作者
有人知道这是几位密码吗
