查看: 1483|回复: 0
51单片机按键控制舵机程序有问题 求帮助
ID:623569 发表于 2019-10-15 00:53 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
我这也有个程序不好用 有大神帮忙看看问题出在哪了
#include <reg52.h>
#define Stop 0    //宏定义,停止
#define Left 1      //宏定义,左转
#define Right 2      //宏定义,右转
sbit ControlPort = P1^0;  //舵机信号端口
sbit KeyLeft = P1^1;      //左转按键端口
sbit KeyRight = P1^2;      //右转按键端口
sbit KeyStop = P1^3;      //归位按键端口
unsigned char TimeOutCounter = 0,LeftOrRight = 0;  //TimeOutCounter:定时器溢出计数      LeftOrRight:舵机左右旋转标志
void InitialTimer ( void )
    TMOD=0x10;   //定时/计数器1工作于方式1
    TH1 = ( 65535 - 500 ) / 256;      //0.25ms
    TL1 = ( 65535 - 500 ) % 256;
    EA=1;        //开总中断
    ET1=1;       //允许定时/计数器1 中断
    TR1=1;       //启动定时/计数器1 中断
void ControlLeftOrRight ( void )   //控制舵机函数
    if( KeyStop == 0 )
        while ( !KeyStop );       //使标志等于Stop(0),在中断函数中将用到
        LeftOrRight = Stop;
    if( KeyLeft == 0 )
        while ( !KeyLeft );       //使标志等于Left(1),在中断函数中将用到
        LeftOrRight = Left;
    if( KeyRight == 0 )
        while ( !KeyRight );   //使标志等于Right(2),在中断函数中将用到
        LeftOrRight = Right;
void main ( void )     //主函数
    InitialTimer();
    for(;;)
        ControlLeftOrRight();
void Timer1 ( void ) interrupt 3  //定时器中断函数
    TimeOutCounter ++;
    switch ( LeftOrRight )
        case 0 :      //为0时,舵机归位,脉宽1.5ms
            if( TimeOutCounter <= 6 )
                ControlPort = 1;
                ControlPort = 0;
            break;
        case 1 :     //为1时,舵机左转,脉宽1ms(理论值),实际可以调试得出
            if( TimeOutCounter <= 2 )
                ControlPort = 1;
                ControlPort = 0;
            break;
        case 2 :   //为2时,舵机右转,脉宽2ms(理论值),实际可以调试得出
            if( TimeOutCounter <= 10 )
                ControlPort = 1;
                ControlPort = 0;
            break;
        default : break;
    if( TimeOutCounter == 80 )     //周期20ms(理论值),比较可靠,最好不要修改
        TimeOutCounter = 0;
收藏收藏1 分享淘帖 顶 踩
