查看: 3037|回复: 0
stm32f103ADC三通道测量电路电流值
ID:630052 发表于 2019-10-25 15:00 | 只看该作者 回帖奖励 |正序浏览 |阅读模式
#include "adc.h"
void Delay(u32 count)
   u32 i=0;
   for(;i<count;i++);
void  Adc_Init(void)
        ADC_InitTypeDef ADC_InitStructure;
        GPIO_InitTypeDef GPIO_InitStructure;
        RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOC |RCC_APB2Periph_ADC1        , ENABLE );          //使能ADC1通道时钟
        RCC_ADCCLKConfig(RCC_PCLK2_Div8);   //设置ADC分频因子6 72M/6=12,ADC最大时间不能超过14M
        //PA1 作为模拟通道输入引脚
        GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0 | GPIO_Pin_1 | GPIO_Pin_2;
        GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AIN;                //模拟输入引脚
        GPIO_Init(GPIOC, &GPIO_InitStructure);
        ADC_DeInit(ADC1);  //复位ADC1
        ADC_InitStructure.ADC_Mode = ADC_Mode_Independent;        //ADC工作模式:ADC1和ADC2工作在独立模式
        ADC_InitStructure.ADC_ScanConvMode = ENABLE;        //扫描模式
        ADC_InitStructure.ADC_ContinuousConvMode = ENABLE;        //连续转换模式
        ADC_InitStructure.ADC_ExternalTrigConv = ADC_ExternalTrigConv_None;        //转换由软件而不是外部触发启动
        ADC_InitStructure.ADC_DataAlign = ADC_DataAlign_Right;        //ADC数据右对齐
        ADC_InitStructure.ADC_NbrOfChannel = 3;        //顺序进行规则转换的ADC通道的数目
        ADC_Init(ADC1, &ADC_InitStructure);        //根据ADC_InitStruct中指定的参数初始化外设ADCx的寄存器
        ADC_Cmd(ADC1, ENABLE);        //使能指定的ADC1
        ADC_ResetCalibration(ADC1);        //使能复位校准
        while(ADC_GetResetCalibrationStatus(ADC1));        //等待复位校准结束
        ADC_StartCalibration(ADC1);         //开启AD校准
        while(ADC_GetCalibrationStatus(ADC1));         //等待校准结束
//        ADC_SoftwareStartConvCmd(ADC1, ENABLE);                //使能指定的ADC1的软件转换启动功能
//获得ADC值
//ch:通道值 0~3
u16 Get_Adc(u8 ch)
          //设置指定ADC的规则组通道,一个序列,采样时间
        ADC_RegularChannelConfig(ADC1, ch, 1, ADC_SampleTime_239Cycles5 );        //ADC1,ADC通道,采样时间为239.5周期
  ADC_RegularChannelConfig(ADC1, ch, 2, ADC_SampleTime_239Cycles5 );        //ADC1,ADC通道,采样时间为239.5周期
        ADC_RegularChannelConfig(ADC1, ch, 3, ADC_SampleTime_239Cycles5 );        //ADC1,ADC通道,采样时间为239.5周期
        while(!ADC_GetFlagStatus(ADC1, ADC_FLAG_EOC ));//等待转换结束
        return ADC_GetConversionValue(ADC1);        //返回最近一次ADC1规则组的转换结果
u16 Get_Adc_Average(u8 ch,u8 times)
        u32 temp_val=0;
        u8 t;
        for(t=0;t<times;t++)
                temp_val+=Get_Adc(ch);
                Delay(500);
        return temp_val/times;
收藏收藏2 分享淘帖 顶 踩
