查看: 2162|回复: 0
89c52单片机超声波红外避障程序 两轮加万向轮小车
ID:612798 发表于 2019-10-30 10:33 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
两轮加万向轮小车 超声波避障,红外寻迹
  1. #include <reg52.h>
  2. #include<intrins.h>
  3. sbit INFRARED_RAY_RIGHT = P1^2;
  4. sbit INFRARED_RAY_LEFT = P1^3;
  5. sbit TRIG = P1^0;
  6. sbit ECHO = P1^1;
  7. unsigned char HighRH = 0;
  8. unsigned char HighRL = 0;
  9. unsigned char LowRH = 0;
  10. unsigned char LowRL = 0;
  11. void SupersonicWave();
  12. void main(){
  13.         unsigned int Time;
  14.         double Distance;
  15.         TRIG = 0;
  16.         ECHO = 0;
  17.         EA = 1;
  18.         TMOD = 0x11;
  19.         P0=0x05;
  20.         while( 1 ){
  21. //                SupersonicWave();
  22. //                Time = TH1 * 256 + TL1;
  23. //                Distance = Time * 0.017;                //????,???CM
  24. //                if( Distance < 20 ){
  25. //                        P0 = 0x00;
  26. //                }else{
  27.                         if( INFRARED_RAY_LEFT ==0&& INFRARED_RAY_RIGHT==1 ){                        //???????,??????,????
  28.                                 P0 = 0x01;
  29.                         }else if( INFRARED_RAY_LEFT==1 && INFRARED_RAY_RIGHT==0 ){        //???????,??????,????
  30.                                 P0 = 0x04;
  31.                         }else{        //??????????????,?????
  32.                                 P0 = 0x05;
  33.                         }
  34.
  35. //                }
  36.         }
  37. }
  38. void SupersonicWave(){
  39.
  40.         TH1 = 0x00;
  41.         TL1 = 0x00;
  42.         ET1 = 0;        //?????1??
  43.     TRIG = 1;
  44.     _nop_();_nop_();_nop_();_nop_();_nop_();                  //??10us
  45.         _nop_();_nop_();_nop_();_nop_();_nop_();
  46.         TRIG = 0;
  47.         while ( ECHO == 0 );                                                           //??EHCO?????
  48.         TR1 = 1;        //??T1
  49.         while ( ECHO == 1 );
  50.         TR1 = 0;                                                        //??T1
  51. }
红外超声波.zip (100 KB, 下载次数: 18)
