查看: 1646|回复: 0
I2C控制xx+5档调速直流电机 单片机源程序
ID:636102 发表于 2019-11-5 16:21 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
直流电机控制
  1. /*
  2.                程序功能
  3.
  4.                 6档调速直流电机,oled(IIC接口)显示占空比
  5. */
  6. #include "reg52.h"
  7. #include "i2c.h"
  8. #include "SEEKFREE_OLED.h"
  9.
  10. sbit PwmOut=P1^0;
  11. sbit k1=P0^0;
  12. sbit k2=P0^1;
  13. unsigned int period=50000;    //设置周期为50000us
  14. unsigned int duty=0;          //设置起始占空比值为0
  15. void T0T1_Init(void)                //定时器/计数器T0,T1初始化函数
  16. {
  17.         EA=1;
  18.         ET0=1;
  19.         ET1=1;
  20.         TMOD|=0x11;
  21.         TR0=1;
  22.         TH0=(65536-period)>>8;
  23.         TL0=65536-period;
  24.         TH1=(65536-duty)>>8;
  25.         TL1=65536-duty;
  26. }
  27. void Delay10ms(void)   //误差 0us
  28. {
  29.     unsigned char a,b,c;
  30.     for(c=1;c>0;c--)
  31.         for(b=38;b>0;b--)
  32.             for(a=130;a>0;a--);
  33. }
  34. void keypros()         //按键处理函数,按K1加档位,按K2减档位,共6档(0,1,2,3,4,5)
  35. {
  36.         void numpro();
  37.         if(duty!=50000)                //封边,达到最5档位不可再加
  38.         {
  39.                 if(k1==0)
  40.                 {
  41.                         Delay10ms();
  42.                         if(k1==0)
  43.                         {
  44.                                 duty+=10000;
  45.                         }
  46.                         while(!k1);
  47.                         numpro();
  48.                 }
  49.         }
  50.         if(duty)           //封边,为0档时不可再减
  51.         {
  52.                 if(k2==0)
  53.                 {
  54.                         Delay10ms();
  55.                         if(k2==0)
  56.                         {
  57.                                 duty-=10000;
  58.                         }
  59.                         while(!k2);
  60.                         numpro();
  61.                 }
  62.         }
  63. }
  64. void numpro()        //oled显示处理函数,显示占空比
  65. {
  66.         switch(duty)
  67.         {
  68.                 case 0:OLED_P8x16Str(90,3,"0%  ");
  69.                        OLED_P6x8Str(90,5,"min");      break;
  70.                 case 10000:OLED_P8x16Str(90,3,"20% ");
  71.                            OLED_P6x8Str(90,5,"   ");  break;
  72.                 case 20000:OLED_P8x16Str(90,3,"40% ");
  73.                            OLED_P6x8Str(90,5,"   ");  break;
  74.                 case 30000:OLED_P8x16Str(90,3,"60% ");
  75.                            OLED_P6x8Str(90,5,"   ");  break;
  76.                 case 40000:OLED_P8x16Str(90,3,"80% ");
  77.                            OLED_P6x8Str(90,5,"   ");  break;
  78.                 case 50000:OLED_P8x16Str(90,3,"100%");
  79.                            OLED_P6x8Str(90,5,"max");  break;
  80.         }
  81. }
  82. void main()
  83. {
  84.         PwmOut=0;
  85.         T0T1_Init();
  86.         Delay10ms(); //等待oled上电完成
  87.         Initial_M096128x64_ssd1306();//oled初始化
  88.         OLED_P6x8Str(25,0,"hello world");//oled显示"hello world"
  89.         OLED_P6x8Str(25,7,"---made by msonah");//oled显示"made by msonah"
  90.         OLED_P8x16Str(0,3,"duty cycle:");
  91.         OLED_P8x16Str(90,3,"0%  ");
  92.         OLED_P6x8Str(90,5,"min");      //刚通电时显示“duty cycle:0%”
  93.         while(1)
  94.   {
  95.                 keypros();
  96.         }
  97. }
  98. void T0_ISR(void) interrupt 1
  99. {
  100.         TH0=(65536-period)>>8;
  101.         TL0=65536-period;
  102.         if(duty<period&&(duty))
  103.         {
  104.                 PwmOut=1;
  105.                 TR1=1;
  106.         }
  107.         else
  108.         {
  109.                 if(duty==0)
  110.                 {
  111.                         PwmOut=0;
  112.                 }
  113.                 else
  114.                 {
  115.                         PwmOut=1;
  116.                 }
  117.         }
  118. }
  119. void T1_ISR(void) interrupt 3
  120. {
  121.         TH1=(65536-duty)>>8;
  122.         TL1=65536-duty;
  123.         PwmOut=0;
  124.         TR1=0;
  125. }
实验14:I2C控制xx+5档调速电机3.0.zip (87.15 KB, 下载次数: 8)
