查看: 3037|回复: 2
SUKON触摸屏学习单片机modbus通讯程序
ID:280979 发表于 2019-11-5 22:26 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
#include "main.h"
modbus RTU 的C51程序
单片机89S52
通信波特率 9600 8位数据 1位停止位 偶校验 485通位接口
单片机控制板地址 localAddr(变量)
通信可设置数据的地址:
字地址 0 - 255 (只取16位的低8位)
位地址 0 - 255 (只取16位的低8位)
uint32        dwTickCount,dwIntTick;        //时钟
uint8        idata sendBuf[16],receBuf[16]; //发送接收缓冲区
uint8        idata checkoutError;        // ==2 偶校验错
uint8        idata receTimeOut;                //接收超时
uint8        idata c10ms;                        //10ms 计时
bit                b1ms,bt1ms,b10ms,bt10ms,b100ms,bt100ms;        //定时标志位
// 串行中断程序
void commIntProc() interrupt 4
        if(TI)
                TI = 0;
                if(sendPosi < sendCount)
                        sendPosi++;
                        ACC = sendBuf[sendPosi];
                        TB8 = P;        //加上校验位
                        SBUF = sendBuf[sendPosi];
                        b485Send = 0;    //发送完后将485置于接收状态
                        receCount = 0;   //清接收地址偏移寄存器
                        checkoutError = 0;
        else if(RI)
                RI = 0;
                receTimeOut = 10;    //通讯超时值
                receBuf[receCount] = SBUF;
                ACC = receBuf[receCount];
                if(P != RB8)
                        checkoutError = 2;        //偶校验出错
                receCount++;          //接收地址偏移寄存器加1
                receCount &= 0x0f;    //最多一次只能接收16个字节
}   // void CommIntProc()
//定时器0 1ms 中断
void timer0IntProc() interrupt 1
        TL0 = TIMER_LOW;
    TH0 = TIMER_HIGHT;
    dwIntTick++;
        bt1ms = 1;
    c10ms++;
    if(c10ms >= 10)
        c10ms = 0;      //10ms计时器清零
        bt10ms = 1;
}   // void Timer0IntProc()
//外部中断0
void intEx0Proc(void) interrupt 0
//计数器1中断
void counter1IntProc(void) interrupt 3 using 1
//定时处理
void timeProc(void)
        static uint8 c200ms;
    bWatchDog = ~ bWatchDog;    //看门狗取反
        b1ms = 0;
        b10ms = 0;
        b100ms = 0;
        ET0 = 0;
        dwTickCount = dwIntTick;
        ET0 = 1;
        if(bt1ms)
                bt1ms = 0;
                b1ms = 1;
        if(receTimeOut>0)
            receTimeOut--;
            if(receTimeOut==0 && receCount>0)   //判断通讯接收是否超时
                b485Send = 0;       //将485置为接收状态
                receCount = 0;      //将接收地址偏移寄存器清零
                                checkoutError = 0;
        if(bt100ms)
                bt100ms = 0;
                b100ms = 1;
    if(bt10ms)      //判断中断10ms标志位是否1
        bt10ms = 0;     //清中断10ms标志位
                b10ms = 1;
        c200ms++;                   //200ms计时器加1
        if(c200ms >= 20)            //判断是否计时到200ms
            c200ms = 0;             //清200ms计时器
            bRunLED = ~bRunLED;     //取反运行指示灯
}   // void TimerProc(void)
//初始化串口
void initUart(void)
        T2CON = 0x30;   //T2 用于波特率 9600
        RCAP2H = 0xff;
        RCAP2L = 0xdc;
        TR2 = 1;
        //偶校验
        SCON = 0xd0;
    PCON = 0;
    ES = 1;
}//void initUart(void)
//初始化中断
void initInt(void)
        TMOD = 0x51;
        TH0 = TIMER_HIGHT;
        TL0 = TIMER_LOW;
        TR0 = 1;
    ET0 = 1;
        TH1 = 0;                        //9600
    TL1 = 0;
        TR1 = 0;                        //定时器1用于计数定时器2用于波特
        ET1 = 1;
        //PT1 = 1;
        IT0 = 1;
    IT1 = 1;
        EX0 = 0;
        PX0 = 1;
    EX1 = 0;
        initUart();
        EA = 1;
}   // void initInt(void)
//初始化
void initProg(void)
        initInt();
        b485Send = 0;
void main(void)
        initProg();
                timeProc();
                checkComm0Modbus();
                display();
单片机modbus通讯.rar
2.48 MB, 下载次数: 34, 下载积分: 黑币 -5
单片机自定义协议通讯.rar
4.44 MB, 下载次数: 27, 下载积分: 黑币 -5
收藏收藏5 分享淘帖 顶顶 踩踩
ID:320751 发表于 2020-6-26 17:25 | 只看该作者
谢谢分享  感恩付出
ID:495287 发表于 2020-6-26 23:25 | 只看该作者
谢谢楼主分享,这个可以用在维纶触摸屏和单片机的通讯吧。按说协议一样应该可以。
