查看: 2313|回复: 1
Proteus仿真ADC0808,基于MSP430F249
源码如下:
#include<msp430f249.h>
#include"KU.h"
#defineADCST0          P5OUT &= ~BIT4
#define ADCST1                P5OUT |= BIT4
#defineADCALE0         P5OUT &= ~BIT5
#define ADCALE1              P5OUT |= BIT5
#defineADCEOC0         P5OUT &= ~BIT6
#defineADCEOC1         P5OUT |= BIT6
#defineADCOE0          P5OUT &= ~BIT7
#define ADCOE1               P5OUT |= BIT7
uchar  ADC1;
ulong   ADC2;
uint   MC_wan;
uint   MC_qian;
uint   MC_bai;
uint   MC_shi;
uint   MC_ge;
voidADC_START(void)
  ADCALE1;
  ADCST1;
  delay_ms(5);
  ADCALE0;
  ADCST0;
  delay_ms(5);
char ADC_READ()
  uchar data;
  data=0x00;
  delay_ms(5);
  ADCOE1;
  ADC_START();
  delay_ms(5);
  data=P4IN;
  ADCOE0;
  return data;
int main( void )
  WDTCTL = WDTPW + WDTHOLD;
   P1SEL = 0x00;
   P1DIR = 0xFF;                  //P1液晶数据
   P3SEL = 0x00;
   P3DIR|= BIT0+BIT1+BIT2;       //P3液晶控制
   LCD_init();
   LCD_clear();
   delay_ms(50);
   P4SEL = 0x00;
   P4DIR = 0x00;
   P5SEL = 0x00;
   P5DIR |= BIT4+BIT5+BIT6;
     ADC1=ADC_READ();
     ADC2=(ADC1*100)/51;
     MC_wan=(ADC2/10000);
     MC_qian=(ADC2-(MC_wan*10000))/1000;
    MC_bai=((ADC2-(MC_wan*10000)-(MC_qian*1000))/100);
    MC_shi=((ADC2-(MC_wan*10000)-(MC_qian*1000)-(MC_bai*100))/10);
    MC_ge=(ADC2-(MC_wan*10000)-(MC_qian*1000)-(MC_bai*100)-(MC_shi*10));
      LCD_clear();
      LCD_write_str(0,0,"Voltage:");
      LCD_write_char(0x07,1,MC_bai+48);
      LCD_write_char(0x08,1,46);
      LCD_write_char(0x09,1,MC_shi+48);
      LCD_write_char(0x0A,1,MC_ge+48);
      LCD_write_char(0x0D,1,86);
      delay_ms(500);
下面为库函数
//延时设置~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~//
#define CPU_F((double)4000000)  ////主时钟的频率4MHz
#definedelay_us(x) __delay_cycles((long)(CPU_F*(double)x/1000000.0))
#definedelay_ms(x) __delay_cycles((long)(CPU_F*(double)x/1000.0))
#define RS0         P3OUT &= ~BIT0
#define RS1         P3OUT |= BIT0
#define RW0              P3OUT &= ~BIT1
#define RW1              P3OUT |= BIT1
#define EN0        P3OUT &= ~BIT2
#define EN1        P3OUT |= BIT2
#define uchar           unsigned char
#define uint            unsigned int
#define ulong           unsigned long
//驱动1602**************************
voidLCD_write_com(unsigned char com)
       RS0;
       RW0;
       EN0;
       P1OUT = com;
        delay_ms(1);
        EN1;
       delay_ms(1);
        EN0;
voidLCD_write_data(unsigned char data)
       RS1;
       RW0;
       EN0;
       P1OUT = data;
        delay_ms(1);
        EN1;
       delay_ms(1);
       EN0;
voidLCD_clear(void)
       LCD_write_com(0x01);
       delay_ms(1);
voidLCD_write_str(unsigned char x,unsigned char y,unsigned char *s)
    if (y == 0)
          LCD_write_com(0x80+ x);
          LCD_write_com(0xC0+ x);
    while (*s)
          LCD_write_data(*s);
          s++;
voidLCD_write_char(unsigned char x,unsigned char y,unsigned char data)
    if (y == 0)
    LCD_write_data( data);
voidLCD_init(void)
    EN0;
    delay_ms(1);
    LCD_write_com(0x38);
    delay_ms(1);
    LCD_write_com(0x0C);
    delay_ms(1);
    LCD_write_com(0x06);
    delay_ms(1);
    delay_ms(1);
ID:1 发表于 2019-11-25 17:26 | 只看该作者
本帖需要重新编辑补全电路原理图,源码,详细说明与图片即可获得100+黑币(帖子下方有编辑按钮)
