查看: 2781|回复: 0
用按键实现流水灯左移,右移,99数码管倒计时,和全灭
ID:563424 发表于 2019-11-26 18:11 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
#include<reg52.h>
sbit ADDR0 = P2^2;
sbit ADDR1 = P2^3;
sbit ADDR2 = P2^4;
sbit KEY1 = P1^0;
sbit KEY2 = P1^1;
sbit KEY3 = P1^2;
sbit KEY4 = P1^3;
unsigned char code LedChar[] = {0xc0, 0xf9, 0xa4, 0xB0, 0x99, 0x92, 0x82, 0xf8, 0x80, 0x90,0x88, 0x83,0xc6,0xa1, 0x86, 0x8e};
unsigned char  LedBuff[] = {0xff,0xff};
unsigned char i = 0;
unsigned char cnt = 0;
unsigned char left = 0;
unsigned char right = 0;
unsigned long sec = 0;         /*算流水灯的*/
unsigned char cd = 0;/*倒计时*/
unsigned int mov = 0;
unsigned char flag1s = 0;
bit KeySta = 1;
void cutdown()
        bit backup = 1;
        unsigned int time = 99;
        EA = 1;
        TMOD = 0X01;
        TH0 = 0XF8;        /*2ms*/
        TL0 = 0XCD;
        ET0 = 1;
        TR0 = 1;
        P1 = 0X7f;
                        if(KeySta != backup)
                                if(backup ==
                                        cnt++;
                                }0)
                        backup = KeySta;
                        if(cnt == 1) /*流水灯左移*/
                                        left = 1;        /*左移标志位*/
                        if(cnt == 2)/*流水灯右移*/
                                        right = 1;/*右移标志位*/
                        if(cnt == 3)/*99秒倒计时*/
                                        cd = 1;
                                          if(flag1s == 1)
                                                flag1s = 0;
                                                time--;
                                                LedBuff[0] = LedChar[time%10];/*数码管显示*/
                                                LedBuff[1] = LedChar[time/10];
                        if(cnt == 4)/*全灭*/
                                        P0 = 0X00;
                                        P2 = 0Xff;
                                        left = 0;
                                        right = 0;
                                         cd = 0;
                                        cnt = 0;
void interruptTimer() interrupt 1
{        static unsigned char mov1 = 0;
        static unsigned char keybuf = 0xFF;
        TH0 = 0XF8;
        TL0 = 0XCD;
        keybuf = (keybuf<<1) | KEY4;
        if(keybuf == 0x00)
                KeySta = 0;
        else if(keybuf == 0xff)
                KeySta = 1;
        sec++;
        if(sec >= 500)
                sec = 0;
                flag1s = 1;
                if(left)
                {        P2 = 0XFF;
                        P2 = ~(0x01<<mov);
                        mov++;
                       left = 0;
                if(right)
                        P2 = 0XFF;
                        P2 = ~(0x80>>mov1);
                        mov1++;
                        right = 0;
        P0 = 0X00;
        if(cd)
        {        P0 = 0x00;/*刷新*/
                P2 = 0XFF;
                switch(i)
                        case 0 : ADDR2 = 0 ; ADDR1 = 0 ; ADDR0 = 0; i++; P0 = ~LedBuff[0]; break;
                        case 1 : ADDR2 = 0 ; ADDR1 = 0 ; ADDR0 = 1; i=0; P0 = ~LedBuff[1]; break;
        else P0 = 0X00;
