查看: 8354|回复: 6
c语言程序问题
ID:12970 发表于 2009-5-16 22:45 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
#include<reg52.h>
sbit lcden=P2^7;
sbit lcdrs=P2^6;
sbit lcdrw=P3^6;
uchar count,shi,fen ,miao;
uchar code table[]="   2009-5-16";
uchar code table1[]="   00:00:00";
void delay(uint z)
  uint x,y;
  for(x=z;x>0;x--)
    for(y=110;y>0;y--);
void write_sfm(uchar add,uchar date)
  uchar ge, shi ;
  shi=date/10;
  ge=date%10;
  write_com(0x80+0x40+add);
  write_data(0x30+shi);
  write_data(0x30+ge);
void write_com(uchar com)
  lcdrs=0;
  lcden=0;
  delay(5);
  P0=com;
  delay(5);
  lcden=1;
  delay(5);
  lcden=0;
void write_data(uchar date)
  lcdrs=1;
  lcden=0;
  delay(5);
  P0=date;
  delay(5);
  lcden=1;
  delay(5);
  lcden=0;
void init()
 lcdrw=0;
 write_com(0x38);
 write_com(0x0c);
 write_com(0x06);
 write_com(0x01);
 write_com (0x80);
 TMOD=0X01;
 TH0=(65535-50000)/256;
 TL0=(65535-50000)%256;
 EA=1;
 ET0=1;
 TR0=1;
main()
  uchar num;
  init();
  for(num=0;num<12;num++)
  write_data(table[num]);
  delay(5);
  write_com(0x80+0x40);
  for(num=0;num<11;num++)
  write_data(table1[num]);
  delay(5);
  if(count==20)
    miao++;
    if(miao==60)
      miao==0;
    fen++;
      if(fen==60)
     {fen=0;
    shi++;
    if(shi==24)
      shi=0;
  write_sfm(10,miao);
void time0() interrupt 1
 count++;
}keil调试后,出现 warning C206: 'write_com': missing function-prototype。
  write_com(0x80+0x40+add);这句有何错
ID:13475 发表于 2009-5-27 07:08 | 只看该作者
将write_com函数放在调用它的函数之前就行.或在调用该函数时先声明一下.C语言关于函数内容要补课了
ID:5810 发表于 2009-7-9 09:23 | 只看该作者
#include<reg52.h>
sbit lcden=P2^7;
sbit lcdrs=P2^6;
sbit lcdrw=P3^6;
void write_com(uchar com);
void write_data(uchar date);
void delay(uint z)
  uint x,y;
  for(x=z;x>0;x--)
    for(y=110;y>0;y--)
  uchar ge, shi ;
  shi=date/10;
  ge=date%10;
  lcdrs=0;
  lcden=0;
  delay(5);
  P0=com;
  delay(5);
  lcden=1;
  delay(5);
  lcden=0;
  lcdrs=1;
  lcden=0;
  delay(5);
  P0=date;
  delay(5);
  lcden=1;
  delay(5);
  lcden=0;
void init()
 lcdrw=0;
 write_com(0x38);
 write_com(0x0c);
 write_com(0x06);
 write_com(0x01);
 write_com (0x80);
 TMOD=0X01;
 EA=1;
 ET0=1;
 TR0=1;
main()
  uchar num;
  init();
  delay(5);
  delay(5);
  if(count==20)
    miao++;
    if(miao==60)
      miao==0;
    fen++;
      if(fen==60)
     {fen=0;
    shi++;
    if(shi==24)
      shi=0;
  write_sfm(10,miao);
 count++;
ID:23217 发表于 2010-4-25 10:17 | 只看该作者
 #include<reg52.h>
sbit lcden=P2^7;
sbit lcdrs=P2^6;
sbit lcdrw=P3^6;
void delay(uint z)
  uint x,y;
  for(x=z;x>0;x--)
    for(y=110;y>0;y--);
  lcdrs=1;
  lcden=0;
  delay(5);
  P0=date;
  delay(5);
  lcden=1;
  delay(5);
  lcden=0;
void write_com( uchar com)
  lcdrs=0;
  lcden=0;
  delay(5);
  P0=com;
  delay(5);
  lcden=1;
  delay(5);
  lcden=0;
  uchar ge, shi ;
  shi=date/10;
  ge=date%10;
void init()
 lcdrw=0;
 write_com(0x38);
 write_com(0x0c);
 write_com(0x06);
 write_com(0x01);
 write_com (0x80);
 TMOD=0X01;
 EA=1;
 ET0=1;
 TR0=1;
main()
  uchar num;
  init();
  delay(5);
  delay(5);
  if(count==20)
    miao++;
    if(miao==60)
      miao==0;
    fen++;
      if(fen==60)
     {fen=0;
    shi++;
    if(shi==24)
      shi=0;
  write_sfm(10,miao);
 count++;
ID:22103 发表于 2010-4-30 17:58 | 只看该作者
支持楼上了,写函数之前,在main之前声明一下啊。
ID:24670 发表于 2010-7-9 13:51 | 只看该作者
一楼正解,write_com()跟write_data()这两个函数要写在write_sfm()前面,在者在它前面需要有个函数说明,不然调用的时候找不到地址,系统不知道去哪里找这个函数
ID:24818 发表于 2010-7-14 10:12 | 只看该作者
楼上说得很详细哦,支持一个
