查看: 2827|回复: 4
单片机电子琴为什么按了没有声音?
#include <AT89X51.H>
unsigned char code table[]={0x3f,0x06,0x5b,0x4f,
                           0x66,0x6d,0x7d,0x07,
                            0x7f,0x6f,0x77,0x7c,
                           0x39,0x5e,0x79,0x71};
unsigned char temp;
unsigned char key;
unsigned char i,j;
unsigned char STH0;
unsigned char STL0;
unsigned int codetab[]={64021,64103,64260,64400,
                         64524,64580,64684,64777,
                         64820,64898,64968,65030,
                          65058,65110,65157,65178};
void main(void)
TMOD=0x01;
ET0=1;
EA=1;
     P3=0xff;
     P3_4=0;
     temp=P3;
     temp=temp & 0x0f;
     if (temp!=0x0f)
         for(i=50;i>0;i--)
         for(j=200;j>0;j--);
         temp=P3;
         temp=temp & 0x0f;
         if (temp!=0x0f)
              temp=P3;
              temp=temp & 0x0f;
              switch(temp)
                  case 0x0e:
                    key=3;
                    break;
                  case 0x0d:
                    key=2;
                    break;
                  case 0x0b:
                    key=1;
                    break;
                  case 0x07:
                    key=0;
                    break;
              temp=P3;
              //P1_0=~P1_0;
              P0=table[key];
              STH0=tab[key]/256;
              STL0=tab[key]%256;
              TR0=1;
             temp=temp & 0x0f;
              while(temp!=0x0f)
                  temp=P3;
                  temp=temp & 0x0f;
              TR0=0;
     P3=0xff;
      P3_5=0;
     temp=P3;
     temp=temp & 0x0f;
     if (temp!=0x0f)
         for(i=50;i>0;i--)
         for(j=200;j>0;j--);
         temp=P3;
         temp=temp & 0x0f;
         if (temp!=0x0f)
              temp=P3;
              temp=temp & 0x0f;
              switch(temp)
                  case 0x0e:
                    key=7;
                    break;
                  case 0x0d:
                    key=6;
                   break;
                  case 0x0b:
                    key=5;
                    break;
                  case 0x07:
                    key=4;
                    break;
              temp=P3;
             //P1_0=~P1_0;
              P0=table[key];
              STH0=tab[key]/256;
              STL0=tab[key]%256;
              TR0=1;
              temp=temp & 0x0f;
              while(temp!=0x0f)
                  temp=P3;
                  temp=temp & 0x0f;
              TR0=0;
     P3=0xff;
     P3_6=0;
     temp=P3;
     temp=temp & 0x0f;
     if (temp!=0x0f)
         for(i=50;i>0;i--)
         for(j=200;j>0;j--);
         temp=P3;
         temp=temp & 0x0f;
         if (temp!=0x0f)
              temp=P3;
              temp=temp & 0x0f;
              switch(temp)
                  case 0x0e:
                    key=11;
                    break;
                  case 0x0d:
                    key=10;
                    break;
                  case 0x0b:
                    key=9;
                    break;
                 case 0x07:
                    key=8;
                    break;
              temp=P3;
              //P1_0=~P1_0;
              P0=table[key];
              STH0=tab[key]/256;
              STL0=tab[key]%256;
              TR0=1;
              temp=temp & 0x0f;
              while(temp!=0x0f)
                  temp=P3;
                  temp=temp & 0x0f;
              TR0=0;
     P3=0xff;
     P3_7=0;
     temp=P3;
     temp=temp & 0x0f;
     if (temp!=0x0f)
         for(i=50;i>0;i--)
         for(j=200;j>0;j--);
         temp=P3;
         temp=temp & 0x0f;
         if (temp!=0x0f)
              temp=P3;
              temp=temp & 0x0f;
              switch(temp)
                 case 0x0e:
                    key=15;
                    break;
                  case 0x0d:
                    key=14;
                    break;
                  case 0x0b:
                    key=13;
                    break;
                 case 0x07:
                    key=12;
                    break;
              temp=P3;
//多P1_0=~P1_0;
              P0=table[key];
              STH0=tab[key]/256;
              STL0=tab[key]%256;
              TR0=1;
              temp=temp & 0x0f;
              while(temp!=0x0f)
                  temp=P3;
                  temp=temp & 0x0f;
              TR0=0;
void t0(void) interrupt 1 using 0
TH0=STH0;
TL0=STL0;
P1_0=~P1_0;
ID:470332 发表于 2019-12-9 09:01 | 只看该作者
直接用IO驱LS1能驱得动吗
ID:416239 发表于 2019-12-9 09:59 | 只看该作者
key=1,=2,=3,那是什么东西
ID:399467 发表于 2019-12-27 10:43 | 只看该作者
可能是单片机cpu内存问题
ID:558309 发表于 2019-12-27 11:46 | 只看该作者
LS1的另一个管脚你为什么不直接接地,电路其他部分帮你看来没什么问题,你再捋一遍程序吧
