查看: 1298|回复: 1
MCU轮巡检测程序
ID:660852 发表于 2019-12-10 18:20 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
.globl _start
_start:
//设置开机键按下后运行程序
        ldr r0, =0x1002330c
        ldr r1,[r0]
        orr r1,r1,#0x300
        str r1,[r0]
        // 关闭看门狗
        ldr        r0, =0x10060000
        mov        r1, #0
        str        r1, [r0]
        // 设置栈,以便调用c函数
        ldr        sp, =0x02060000
        // 调用c函数
        bl        main
halt:
        b halt
key.c
#define     GPM1CON     (*(volatile unsigned long *) 0x11000280)
#define     GPM1DAT     (*(volatile unsigned long *) 0x11000284)
#define     GPX1CON     (*(volatile unsigned long *) 0x11000C20)
#define     GPX1DAT     (*(volatile unsigned long *) 0x11000C24)
#define     GPX2CON     (*(volatile unsigned long *) 0x11000C40)
#define     GPX2DAT     (*(volatile unsigned long *) 0x11000C44)
static void GPIO_Init(void)
        /*LED_INIT*/
        GPM1CON &= ( ~(0xF << 16));
        GPM1CON |= (0x1 << 16);
        GPM1DAT &= 0x0;
        GPX1CON &= ( ~(0xF << 12));
        GPX1CON |= (0x1 << 12);
        GPX1DAT &= 0x0;
        //GPX2CON &= ( ~(0xF << 8));
        //GPX2CON |= (0x1 << 8);
        //GPX2DAT |= (0x1 << 2);
        /*KEY_INIT*/
        GPX2CON &= ~0xFF;
        GPX2CON |= 0x00;
        GPX2CON &= ( ~(0xFF <<16));
        GPX2CON |= (0x00 << 16);
        GPX2DAT &= 0x0;
void delay(int time)
        while (time--)
int main(void)
        unsigned char keyValue1 ;
        unsigned char keyValue2 ;
        GPIO_Init();
                keyValue1 = GPX2DAT;
                keyValue1 &= (~(0xFF << 2));
                keyValue2 = GPX2DAT >> 4;
                keyValue2 &= (~(0xFF << 2));
                switch(keyValue1){
                        case 0x01:
                                GPM1DAT |= (0x1 << 4);
                                GPX1DAT |= (0x1 << 3);
                                break;
                        case 0x02:
                                break;
                        default :
                                GPM1DAT &= ~(0x1 << 4);
                                GPX1DAT &= ~(0x1 << 3);
                                break;
                switch(keyValue2){
                        case 0x01:
                                delay(0x10000);
                                delay(0x10000);
                                break;
                        case 0x02:
                                break;
                        default :
                                break;
        return 0;
ID:1 发表于 2019-12-10 23:01 | 只看该作者
本帖需要重新编辑补全电路原理图,源码,详细说明与图片即可获得100+黑币(帖子下方有编辑按钮)
