查看: 1961|回复: 3
这是一个单闭环(转速环)直流电机转速,一直出错,想问问大家是哪里错了
ID:498602 发表于 2019-12-11 20:36 | 显示全部楼层 |阅读模式
麻烦各位大佬谅解我的编译习惯之类的恶性错误,我菜鸡一个,程序实在是写不出来了。。。。。。。。。。。。
诚心向大家求助
#include "reg51.h"
#include "math.h"
#include "string.h"
sbit moto1=P1^0;
sbit moto2=P1^1;
sbit ENA=P1^2;
sbit plus=P1^3;
sbit minus=P1^4;  //加减速
sbit LSA=P0^0;
sbit LSB=P0^1;
sbit LSC=P0^2;   /数码管显示
int a=0,b=0,c=0,d=0;
float real_speed,final_speed=150,offset,offset_1; /从左到右为实际速度,期望速度,速度差值
float uk=0,uk1=0,uks=0;      //电压
float kp=5,ki=1.5,kd=0.9;    //比例积分微分常数(后两个应该是用不到的,但还是写了)
unsigned char code NUM[10]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f};  //数码管数值显示
unsigned short int z,duty,pulse=0;
void delay(unsigned short int z)    //程序运行前延时
        while(z--);
  ENA=1;
        moto1=1;
        moto2=0;
        void timerset()
        void change_speed()
        void display()
void timerset  //定时器计时器初值设置
        TH0=(65536-10000)/256;
        TL0=(65536-10000)%256;
        TH1=(65536-100)/256;
        TL1=(65536-100)%256;
        TMOD=0x11;
        EA=1;
        ET0=1;
        TR0=1;
        ET1=1;
        TR1=1;
        IT0=1;
        EX0=1;
void ASR()
offset=final_speed-real_speed;
uk=uk1+kp*(offset-offset_1)+ki*offset;
        if(uk>=250)
        {uk=250}
        if(uk<=0)
        uk=0;
        offset_1=offset;
        uk1=uk;
void Timer0()interrupt 1
        a++;
        if(a==10)
                TR0=0;
                EX0=0;
                real_speed = 600.0*pulse/260.0;
                ASR();
                pulse = 0;
                a=0;
                TR0=1;
                EX0=1;
void Timer1()interrupt 3
        if(b < duty)
          ENA=1;
                ENA=0;
        b++;
        if(b>=100)
         b=0;
void Outcome() interrupt 0
pulse++;
void change_speed()
        if(plus==0)
           delay(5000);
                if(plus==0)
                        while(plus==0);
                        final_speed=final_speed+10;
                        if(final_speed>=230)
                                final_speed = 230;
        if(minus==0)
                delay(5000);
                if(minus==0)
                        while(minus=0);
                        final_speed= final_speed-10;
                        if(final_speed<=0)
                                final_speed=0;
void display()
        unsigned char i;
        qian = (unsigned char)actual_value %10000/1000;
    bai = (unsigned char)actual_value %1000/100;
    shi = (unsigned char)actual_value %100/10;
    ge = (unsigned char)actual_value %10;
        for(i=0;i<4;i++)
                switch(i)
                case(0):
                        LSA=0;LSB=0;LSC=0;P2=NUM[qian];break;
                case(1):
            LSA=1;LSB=0;LSC=0;P2=NUM[bai];break;
                case(2):
                        LSA=0;LSB=1;LSC=0;P2=NUM[shi];break;
                case(3):
                  LSA=1;LSB=1;LSC=0;P2=NUM[ge];break;
                delay(100);
                P2=0x00;
ID:498602 发表于 2019-12-11 20:37 | 显示全部楼层
现在这个程序跑出来的问题提示是MAIN.C(33): error C141: syntax error near 'void'
ID:213173 发表于 2019-12-11 22:25 | 显示全部楼层
错误实在太多,逐一改正,但还是无法猜actual_value这个没有声明的变量。楼主自己定义后就能通过编译,但不能确定程序能够正常运行。
  1. #include "reg51.h"
  2. #include "math.h"
  3. #include "string.h"
  4. sbit moto1=P1^0;
  5. sbit moto2=P1^1;
  6. sbit ENA=P1^2;
  7. sbit plus=P1^3;
  8. sbit minus=P1^4;  //加减速
  9. sbit LSA=P0^0;
  10. sbit LSB=P0^1;
  11. sbit LSC=P0^2;   //数码管显示
  12. int a=0,b=0,c=0,d=0;
  13. float real_speed,final_speed=150,offset,offset_1; //从左到右为实际速度,期望速度,速度差值
  14. float uk=0,uk1=0,uks=0;      //电压
  15. float kp=5,ki=1.5,kd=0.9;    //比例积分微分常数(后两个应该是用不到的,但还是写了)
  16. unsigned char code NUM[10]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f};  //数码管数值显示
  17. unsigned short int z,duty,pulse=0;
  18. void delay(unsigned short int z)    //程序运行前延时
  19. {
  20.         while(z--);
  21. }
  22. void timerset()  //定时器计时器初值设置
  23. {
  24.         TH0=(65536-10000)/256;
  25.         TL0=(65536-10000)%256;
  26.         TH1=(65536-100)/256;
  27.         TL1=(65536-100)%256;
  28.         TMOD=0x11;
  29.         EA=1;
  30.         ET0=1;
  31.         TR0=1;
  32.         ET1=1;
  33.         TR1=1;
  34.         IT0=1;
  35.         EX0=1;
  36. }
  37. void ASR()
  38. {
  39.         offset=final_speed-real_speed;
  40.         uk=uk1+kp*(offset-offset_1)+ki*offset;
  41.         if(uk>=250)
  42.                 uk=250;
  43.         if(uk<=0)
  44.                 uk=0;
  45.         offset_1=offset;
  46.         uk1=uk;
  47. }
  48. void Timer0()interrupt 1
  49. {
  50.         TH0=(65536-10000)/256;
  51.         TL0=(65536-10000)%256;
  52.         a++;
  53.         if(a==10)
  54.         {
  55.                 TR0=0;
  56.                 EX0=0;
  57.                 real_speed = 600.0*pulse/260.0;
  58.                 ASR();
  59.                 pulse = 0;
  60.                 a=0;
  61.                 TR0=1;
  62.                 EX0=1;
  63.         }
  64. }
  65. void Timer1()interrupt 3
  66. {
  67.         TH1=(65536-100)/256;
  68.         TL1=(65536-100)%256;
  69.         if(b < duty)
  70.         {
  71.                 ENA=1;
  72.         }
  73.         else
  74.         {
  75.                 ENA=0;
  76.         }
  77.         b++;
  78.         if(b>=100)
  79.         {
  80.                 b=0;
  81.         }
  82. }
  83. void Outcome() interrupt 0
  84. {
  85.         pulse++;
  86. }
  87. void change_speed()
  88. {
  89.         if(plus==0)
  90.         {
  91.                 delay(5000);
  92.                 if(plus==0)
  93.                 {
  94.                         while(plus==0);
  95.                         final_speed=final_speed+10;
  96.                         if(final_speed>=230)
  97.                         {
  98.                                 final_speed = 230;
  99.                         }
  100.                 }
  101.         }
  102.         if(minus==0)
  103.         {
  104.                 delay(5000);
  105.                 if(minus==0)
  106.                 {
  107.                         while(minus==0);
  108.                         final_speed= final_speed-10;
  109.                         if(final_speed<=0)
  110.                         {
  111.                                 final_speed=0;
  112.                         }
  113.                 }
  114.         }
  115. }
  116. void display()
  117. {
  118.         unsigned char i,qian,bai,shi,ge;
  119.         qian = (unsigned char)actual_value %10000/1000;
  120.         bai = (unsigned char)actual_value %1000/100;
  121.         shi = (unsigned char)actual_value %100/10;
  122.         ge = (unsigned char)actual_value %10;
  123.         for(i=0;i<4;i++)
  124.         {
  125.                 switch(i)
  126.                 {
  127.                         case(0):
  128.                         LSA=0;LSB=0;LSC=0;P2=NUM[qian];break;
  129.                         case(1):
  130.                         LSA=1;LSB=0;LSC=0;P2=NUM[bai];break;
  131.                         case(2):
  132.                         LSA=0;LSB=1;LSC=0;P2=NUM[shi];break;
  133.                         case(3):
  134.                         LSA=1;LSB=1;LSC=0;P2=NUM[ge];break;
  135.                 }
  136.                 delay(100);
  137.                 P2=0x00;
  138.         }
  139. }
  140. void main()
  141. {
  142.         ENA=1;
  143.         moto1=1;
  144.         moto2=0;
  145.         timerset();
  146.         while(1)
  147.         {
  148.                 change_speed();
  149.                 display();
  150.         }
  151. }
ID:498602 发表于 2019-12-12 12:07 | 显示全部楼层
wulin 发表于 2019-12-11 22:25
错误实在太多,逐一改正,但还是无法猜actual_value这个没有声明的变量。楼主自己定义后就能通过编译,但 ...
谢谢您!!!感激不尽
