查看: 2540|回复: 4
单片机串口通讯相关疑惑
ID:678632 发表于 2019-12-31 20:13 | 显示全部楼层 |阅读模式
以下是我超声波无线传输测距从机部分,现在我加了一些串口通讯功能将距离数据,可是电脑串口收到结果却是乱码?
请大家帮忙看下串口部分有无问题
  1. #include <reg52.h>
  2. #include "eepom52.h"
  4. #define uint  unsigned int
  5. #include "nrf24l01.H"
  6. #include "lcd1602.h"
  7. #include<stdio.h>
  8. sbit K3 = P3^0;                         //按键定义
  9. sbit K2 = P3^1;
  10. sbit K1 = P3^2;
  11. sbit beep = P1^6;   //蜂鸣器IO口定义
  12. sbit led = P1^7;        //无线模块型号指示灯
  13. uchar a_a =0;
  14. unsigned long S=0; //距离
  15. unsigned char code mcustudio[] ={"   CeJu-System  "};
  16. unsigned char code email[] =    {"       ^_^      "};
  17. unsigned char code Cls[] =      {"                "};
  18. unsigned char code ASCII[15] =  {'0','1','2','3','4','5','6','7','8','9','.','-','M'};
  19. unsigned int Set_d = 144;
  20. unsigned char disbuff[4]           ={ 0,0,0,0};          //显示数据数组
  21. bit bSetFlag = 0,bTime_600ms,flag_300ms,bClrFlag;
  22. bit flag =0;
  23. /******************把数据保存到单片机内部eepom中******************/
  24. void write_eepom()
  25. {
  26.         SectorErase(0x2000);
  27.         byte_write(0x2000, Set_d % 256);
  28.         byte_write(0x2001, Set_d / 256);
  29.         byte_write(0x2058, a_a);
  30. }
  31. /******************把数据从单片机内部eepom中读出来*****************/
  32. void read_eepom()
  33. {
  34.         Set_d  = byte_read(0x2001);
  35.         Set_d <<= 8;
  36.         Set_d  |= byte_read(0x2000);
  37.         a_a      = byte_read(0x2058);
  38. }
  39. /**************开机自检eepom初始化*****************/
  40. void init_eepom()
  41. {
  42.         read_eepom();                //先读
  43.         if(a_a != 1)                //新的单片机初始单片机内问EEPOM
  44.         {
  45.                 Set_d = 100;
  46.                 a_a = 1;
  47.                 write_eepom();  //写
  48.         }
  49. }
  50. /*************定时器0初始化程序***************/
  51. void time_init()
  52. {
  53.         EA   = 1;                   //开总中断
  54.         TMOD = 0X01;          //定时器0、定时器1工作方式1
  55.         ET0  = 1;                  //开定时器0中断
  56.         TR0  = 1;                  //允许定时器0定时
  57. }
  58. void KeyScanf(void)    //按键处理函数
  59. {
  60.         static bit K1_on_off;
  61.         static char add = 1;   ///按键一次增加的变量
  62.         if(K1 == 0)                           //设置距离按键按下
  63.         {
  64.                 if(K1_on_off)
  65.                 {
  66.                         K1_on_off = 0;
  67.                         bSetFlag = ~bSetFlag;  //按下标置位取反
  68.                         bClrFlag = 1;
  69.                 }
  70.         }
  71.         else {K1_on_off = 1;}
  72.         if(bSetFlag)                //设置键按下
  73.         {
  74.                 if(K2 == 0  && bTime_600ms)        //设置键加按下
  75.                 {
  76.                         bTime_600ms = 0;
  77.                         Set_d += add;                   //设置值加
  78.                         if(Set_d >= 350)Set_d = 350;  //设置值最大为3.5m
  79.                         write_eepom();                                   //写保存
  80.                 }
  81.                 if(K3 == 0  && bTime_600ms)                  //设置键减键按下
  82.                 {
  83.                         bTime_600ms = 0;
  84.                         Set_d -= add;                                 //设置值减
  85.                         if(Set_d <= 10)Set_d = 10;         //设置值最大为0.1m
  86.                         write_eepom();                                 //写保存
  87.                 }
  88.
  89.                 if ((K3 == 0 || K2 == 0) && bTime_600ms)//有设置加减键按下
  90.                 {
  91.                         bTime_600ms = 0;
  92.                         if(++add >= 10)add = 10;
  93.                 }
  94.                 else if(K3 != 0 && K2 != 0)add = 1;          //没有设置加减键按下
  95.         }
  96. }
  97. /****************报警函数***************/
  98. void clock_h_l()
  99. {
  100.         static unsigned char value;
  101.         if(S <= Set_d)
  102.         {
  103.                 value ++;  //消除实际距离在设定距离左右变化时的干扰
  104.                 if(value >= 2)
  105.                 {
  106.                         beep = ~beep;           //蜂鸣器报警
  107.                 }
  108.         }
  109.         else
  110.         {
  111.                 value = 0;
  112.                 beep = 1;                //取消报警
  113.         }
  114. }
  115. void SetDisplay(void)
  116. {
  117.         DisplayListChar(0,0,"   Set_DIST:    ");
  118.         disbuff[0]=Set_d%1000/100;
  119.           disbuff[1]=Set_d%1000%100/10;
  120.           disbuff[2]=Set_d%1000%10 %10;
  121.           DisplayOneChar(5, 1, ASCII[disbuff[0]]);
  122.           DisplayOneChar(6, 1, ASCII[10]);        //显示点
  123.           DisplayOneChar(7, 1, ASCII[disbuff[1]]);
  124.           DisplayOneChar(8, 1, ASCII[disbuff[2]]);
  125.           DisplayOneChar(9, 1, ASCII[12]);        //显示M
  126. }
  127. void DISPLAY(void)
  128. {
  129.     if(bSetFlag == 0)                //按键设置标志位
  130.         {
  131.      disbuff[0]=Set_d%1000/100;
  132.          disbuff[1]=Set_d%1000%100/10;
  133.          disbuff[2]=Set_d%1000%10 %10;
  134.      DisplayOneChar(0, 1, 'A');
  135.          DisplayOneChar(1, 1, ':');
  136.          DisplayOneChar(2, 1, ASCII[disbuff[0]]);
  137.          DisplayOneChar(3, 1, ASCII[10]);        //显示点
  138.          DisplayOneChar(4, 1, ASCII[disbuff[1]]);
  139.          DisplayOneChar(5, 1, ASCII[disbuff[2]]);
  140.          DisplayOneChar(6, 1, ASCII[12]);        //显示M
  141.
  142.          if((S>=700)||flag==1) //超出测量范围显示“-”
  143.          {
  144.              flag=0;
  145.              //dd(" A3.45m   2.15m ")
  146.              DisplayOneChar(10, 1, ASCII[11]);
  147.              DisplayOneChar(11, 1, ASCII[10]);        //显示点
  148.              DisplayOneChar(12, 1, ASCII[11]);
  149.              DisplayOneChar(13, 1, ASCII[11]);
  150.              DisplayOneChar(14, 1, ASCII[12]);        //显示M
  151.           }
  152.            else
  153.           {
  154.              disbuff[0]=S%1000/100;
  155.              disbuff[1]=S%1000%100/10;
  156.              disbuff[2]=S%1000%10 %10;
  157.              DisplayOneChar(10, 1, ASCII[disbuff[0]]);
  158.              DisplayOneChar(11, 1, ASCII[10]);        //显示点
  159.              DisplayOneChar(12, 1, ASCII[disbuff[1]]);
  160.              DisplayOneChar(13, 1, ASCII[disbuff[2]]);
  161.              DisplayOneChar(14, 1, ASCII[12]);        //显示M
  162.            }
  163.         }
  164. }
  165. /*******************************************************************************
  166. * 函数名         :UsartInit()
  167. * 函数功能                   :设置串口
  168. * 输入           : 无
  169. * 输出                  : 无
  170. *******************************************************************************/
  171. void UsartInit()
  172. {
  173.         SCON=0X50;                             //设置为工作方式1
  174.         TMOD=0X20;                            //设置定时器器工作方式2
  175.         PCON=0X80;                            //波特率加倍
  176.         TH1=0XFD;                                //定时器初始值设置,波特率是9600的
  177.         TL1=0XFD;
  178.         TR1=1;                                        //打开定时器
  179.         TI=1;
  180. }
  181. /********主函数**********/
  182. void main()
  183. {
  184.         LCMInit(); //LCM初始化
  185.         time_init();                    //初始化定时器
  186.     UsartInit();                    //串口初始化
  187.         DisplayListChar(0, 0, mcustudio);
  188.         DisplayListChar(0, 1, email);           //显示^_^
  189.
  190.         CE=0;
  191.         SCK=0;                                                   //无线模块初始化
  192.         CSN=1;
  193.         RX_Mode();
  194.         delay_ms(2000);
  195.         DisplayListChar(0, 1, Cls);           //清屏
  196.         init_eepom();                                   //开机自检eepom
  197.
  198.         while(1)
  199.         {
  200.                 if(flag_300ms == 1)                //300ms 处理一次测量程序
  201.                 {
  202.                         flag_300ms = 0;
  203.                         led = 1;                                           //无线模块的信号指示灯
  204.                         if(nRF24L01_RxPacket(Rx_Buf))  //无线模块的数据接收
  205.                         {
  206.                                 led =0 ;
  207.                                 if(Rx_Buf[0] == 0xa1)
  208.                                 S = 256 * Rx_Buf[2] + Rx_Buf[1];                //取出距离值
  209.                                 clock_h_l();        //报警函数
  210.                         }
  211.                         DISPLAY();                          //显示距离
  212.                     printf("%d\n",S);            //串口显示距离
  213.                         if(beep == 1)DisplayListChar(0, 0, mcustudio);
  214.                         else DisplayListChar(0,0,"     Alarm      ");
  215.                 }
  216.                 else
  217.                 if(bSetFlag)                //按键设置标志位
  218.                 {
  219.                          SetDisplay();        //按键设置显示函数
  220.                 }
  221.
  222.                   if(bClrFlag)   //清除第二行显示标志位
  223.                   {
  224.                           bClrFlag = 0;
  225.                           DisplayListChar(0, 1, Cls);  //对第一行清屏
  226.                   }
  227.         }
  228. }
  229. /*************定时器0中断服务程序***************/
  230. void time0_int() interrupt 1
  231. {
  232.         static uchar value;
  233.         TH0 = 0x3c;
  234.         TL0 = 0xb0;     // 50ms
  235.         value ++;
  236.         KeyScanf();           //按键处理函数
  237.         if(value % 6 == 0)
  238.         {
  239.                 flag_300ms = 1;           //300ms
  240.         }
  241.    if(value == 12)
  242.         {
  243.                 value = 0;
  244.                 bTime_600ms = 1;  //600ms
  245.         }
  246. }
ID:678961 发表于 2020-1-1 16:36 | 显示全部楼层
在线调试,找找问题
ID:679076 发表于 2020-1-1 19:30 | 显示全部楼层
换一个IO 测试,有的时候每个IO数据不稳定
ID:130230 发表于 2020-1-3 16:48 | 显示全部楼层
看看波特率有没有问题
ID:381937 发表于 2020-1-4 21:43 | 显示全部楼层
是不是串口调试助手设置不正确
