查看: 4010|回复: 0
基于51单片机音乐播放仿真 乐谱制作软件 音乐资料
#include <REG52.H>
#include "MusicBox.h"
/*********************代码说明**************************
献给师妹黄银盛-------希望你快乐幸福每一天
音乐驱动参考部分网上代码,感谢原作者
T0,T1用于翁鸣器频率计时和控制
使用P1.0口控制翁鸣器,高电平导通
使用外部中断0,实现曲目控制。设置中断0为最高优先级
在开发板上调试使用STC89C51芯片,4K flash
在手工焊板上使用STC89C52芯片,8K flash,能放置更多歌曲文件
#define  MSC_NUM  5                             //总曲目数
unsigned char play_num = 0;                     //当前播放曲目号
unsigned char play_state = 1;
unsigned char code Music_SummerNut[];        //盛夏的果实
unsigned char code Music_leftTrouble[];      //忘忧草
unsigned char code Music_moonHeart[];        //月亮代表我的心
unsigned char code Music_JiXiang[];          //吉祥三宝
unsigned char code Music_twoButterFly[];     //两只蝴蝶
//定义歌曲播放指针数组
unsigned char* pMusic[] = {Music_SummerNut, Music_leftTrouble, Music_twoButterFly, Music_moonHeart, Music_JiXiang};
void main(void)
   unsigned char degree = 3;          //设定播放音调,升八度
   unsigned int play_speed = 300;     //设定播放速度,默认为300
        InitialSound();
           //调用歌曲播放函数
                Play(pMusic[play_num], 0, degree, play_speed);
                //单曲完毕后,延时1S
                Delay1ms(1000);
                //重设播放状态为1
      play_state = 1;
void Delay1ms(unsigned int count)  //延时,ms级
        unsigned int i,j;
        for(i=0; i<count; i++)
        for(j=0; j<120; j++);
void Int_1(void) interrupt 2  //中断1,累加全局变量,暂停当前歌曲播放,曲目跳转
   EA = 0;
        //设置为不播放状态
        play_state = 0;
        P0 = 0x80;
        //曲目号累加
   play_num++;
        if(play_num >= MSC_NUM){  //若当前播放曲目为最后一条,则回零播放
          play_num = 0;
   EA = 1;
//***********************************Music files**************************************************
//吉祥三宝,一遍,后段转换不成功,未加入
unsigned char code Music_JiXiang[] = { 0x17,0x03, 0x19,0x17, 0x19,0x16, 0x19,0x02, 0x19,0x0D,
                                       0x19,0x03, 0x19,0x0D, 0x19,0x03, 0x17,0x03, 0x16,0x03,
                                       0x17,0x03, 0x19,0x17, 0x19,0x02, 0x19,0x0D, 0x19,0x03,
                                       0x19,0x0D, 0x19,0x03, 0x17,0x03, 0x16,0x03, 0x17,0x03,
                                       0x16,0x17, 0x15,0x02, 0x15,0x0D, 0x15,0x03, 0x15,0x0D,
                                       0x15,0x03, 0x10,0x03, 0x0F,0x03, 0x17,0x03, 0x16,0x17,
                                       0x16,0x03, 0x16,0x03, 0x16,0x03, 0x17,0x03, 0x16,0x0D,
                                       0x15,0x03, 0x10,0x0D, 0x0F,0x03, 0x19,0x01, 0x18,0x01,
                                       0x17,0x01, 0x17,0x01, 0x00,0x00 };
//盛夏的果实
unsigned char code Music_SummerNut[] = { 0x17,0x02, 0x17,0x03, 0x16,0x03, 0x16,0x16, 0x10,0x03,
                                  0x15,0x02, 0x15,0x03, 0x16,0x03, 0x16,0x02, 0x15,0x03,
                                  0x11,0x03, 0x10,0x02, 0x15,0x02, 0x16,0x03, 0x16,0x03,
                                  0x15,0x03, 0x16,0x03, 0x17,0x02, 0x17,0x03, 0x16,0x03,
                                  0x16,0x01, 0x17,0x03, 0x17,0x03, 0x17,0x03, 0x19,0x03,
                                  0x19,0x16, 0x19,0x03, 0x1A,0x03, 0x17,0x03, 0x17,0x03,
                                  0x16,0x03, 0x17,0x01, 0x17,0x03, 0x17,0x03, 0x17,0x03,
                                  0x19,0x03, 0x19,0x03, 0x19,0x03, 0x19,0x03, 0x1A,0x03,
                                  0x17,0x03, 0x17,0x03, 0x17,0x16, 0x17,0x03, 0x16,0x03,
                                  0x15,0x03, 0x10,0x03, 0x15,0x03, 0x17,0x04, 0x16,0x04,
                                  0x16,0x02, 0x15,0x03, 0x16,0x03, 0x17,0x02, 0x19,0x67,
                                  0x1A,0x04, 0x1A,0x02, 0x17,0x03, 0x16,0x03, 0x15,0x02,
                                  0x15,0x03, 0x17,0x03, 0x16,0x02, 0x15,0x03, 0x10,0x03,
                                  0x10,0x14, 0x16,0x66, 0x16,0x03, 0x15,0x66, 0x17,0x03,
                                  0x19,0x03, 0x17,0x03, 0x17,0x15, 0x16,0x15, 0x15,0x03,
                                  0x11,0x03, 0x10,0x03, 0x10,0x14, 0x16,0x66, 0x16,0x03,
                                  0x15,0x02, 0x16,0x02, 0x17,0x02, 0x19,0x67, 0x1A,0x04,
                                  0x1A,0x16, 0x1F,0x03, 0x1F,0x66, 0x1B,0x03, 0x1B,0x66,
                                  0x1F,0x03, 0x1B,0x03, 0x1A,0x03, 0x1A,0x02, 0x17,0x02,
                                  0x17,0x03, 0x16,0x03, 0x16,0x16, 0x10,0x03, 0x15,0x02,
                                  0x15,0x03, 0x16,0x03, 0x16,0x02, 0x15,0x03, 0x11,0x03,
                                  0x10,0x02, 0x15,0x02, 0x16,0x03, 0x16,0x03, 0x15,0x03,
                                  0x16,0x03, 0x17,0x02, 0x17,0x03, 0x16,0x03, 0x16,0x01,
                                  0x17,0x03, 0x17,0x03, 0x17,0x03, 0x19,0x03, 0x19,0x16,
                                  0x19,0x03, 0x1A,0x03, 0x17,0x03, 0x17,0x03, 0x16,0x03,
                                  0x17,0x01, 0x17,0x03, 0x17,0x03, 0x17,0x03, 0x19,0x03,
                                  0x19,0x03, 0x19,0x03, 0x19,0x03, 0x1A,0x03, 0x17,0x03,
                                  0x17,0x03, 0x17,0x16, 0x17,0x03, 0x16,0x03, 0x15,0x03,
                                  0x10,0x03, 0x15,0x03, 0x17,0x04, 0x16,0x04, 0x16,0x02,
                                  0x15,0x03, 0x16,0x03, 0x17,0x02, 0x19,0x67, 0x1A,0x04,
                                  0x1A,0x02, 0x17,0x03, 0x16,0x03, 0x15,0x02, 0x15,0x03,
                                  0x17,0x03, 0x16,0x02, 0x15,0x03, 0x11,0x03, 0x10,0x14,
                                  0x16,0x66, 0x15,0x66, 0x17,0x03, 0x19,0x03, 0x17,0x03,
                                  0x17,0x15, 0x16,0x15, 0x15,0x03, 0x11,0x03, 0x10,0x03,
                                  0x10,0x14, 0x16,0x66, 0x16,0x03, 0x15,0x02, 0x16,0x02,
                                  0x17,0x02, 0x19,0x03, 0x1A,0x03, 0x1A,0x16, 0x1A,0x03,
                                  0x1F,0x01, 0x1B,0x66, 0x1F,0x03, 0x1A,0x03, 0x1A,0x03,
                                  0x1A,0x00, 0x00,0x00 };
//忘忧草
unsigned char code Music_leftTrouble[] = { 0x15,0x66, 0x16,0x03, 0x17,0x03, 0x16,0x03, 0x15,0x02,
                                  0x17,0x03, 0x19,0x02, 0x1A,0x03, 0x19,0x16, 0x1A,0x66,
                                  0x1F,0x03, 0x1A,0x03, 0x19,0x03, 0x17,0x03, 0x1A,0x03,
                                  0x19,0x03, 0x19,0x02, 0x17,0x03, 0x16,0x16, 0x17,0x66,
                                  0x19,0x03, 0x1A,0x0D, 0x19,0x03, 0x17,0x03, 0x16,0x03,
                                  0x16,0x03, 0x16,0x02, 0x15,0x03, 0x15,0x16, 0x10,0x66,
                                  0x15,0x03, 0x16,0x03, 0x17,0x02, 0x16,0x04, 0x15,0x0E,
                                  0x15,0x04, 0x15,0x71, 0x15,0x01, 0x15,0x03, 0x16,0x03,
                                  0x17,0x66, 0x19,0x03, 0x1A,0x03, 0x19,0x03, 0x17,0x02,
                                  0x1A,0x03, 0x19,0x03, 0x17,0x03, 0x1A,0x03, 0x19,0x16,
                                  0x1A,0x66, 0x1F,0x03, 0x1A,0x03, 0x19,0x03, 0x17,0x03,
                                  0x1A,0x0D, 0x19,0x03, 0x19,0x0D, 0x19,0x16, 0x17,0x66,
                                  0x16,0x03, 0x17,0x03, 0x16,0x03, 0x15,0x03, 0x15,0x02,
                                  0x10,0x03, 0x0F,0x03, 0x15,0x02, 0x16,0x03, 0x17,0x03,
                                  0x16,0x03, 0x15,0x0D, 0x15,0x17, 0x10,0x04, 0x15,0x03,
                                  0x15,0x0D, 0x15,0x16, 0x17,0x03, 0x19,0x03, 0x19,0x66,
                                  0x17,0x03, 0x19,0x16, 0x19,0x03, 0x1A,0x66, 0x1F,0x03,
                                  0x1F,0x0D, 0x1A,0x0D, 0x1A,0x02, 0x1A,0x66, 0x1F,0x03,
                                  0x20,0x03, 0x1F,0x03, 0x1A,0x03, 0x19,0x03, 0x19,0x66,
                                  0x1A,0x04, 0x19,0x04, 0x17,0x0D, 0x16,0x03, 0x16,0x02,
                                  0x17,0x66, 0x19,0x03, 0x19,0x02, 0x17,0x03, 0x16,0x03,
                                  0x16,0x02, 0x16,0x03, 0x15,0x03, 0x15,0x02, 0x10,0x03,
                                  0x0F,0x03, 0x15,0x02, 0x16,0x03, 0x17,0x03, 0x16,0x03,
                                  0x15,0x03, 0x10,0x03, 0x15,0x03, 0x15,0x01, 0x17,0x02,
                                  0x19,0x02, 0x1A,0x15, 0x1A,0x03, 0x1F,0x66, 0x1A,0x03,
                                  0x19,0x16, 0x1A,0x66, 0x1F,0x03, 0x20,0x66, 0x21,0x0D,
                                  0x20,0x03, 0x20,0x0D, 0x20,0x16, 0x1F,0x03, 0x20,0x03,
                                  0x21,0x66, 0x23,0x03, 0x21,0x66, 0x21,0x03, 0x20,0x66,
                                  0x1F,0x03, 0x1F,0x16, 0x1A,0x66, 0x1F,0x03, 0x20,0x03,
                                  0x1F,0x03, 0x1A,0x03, 0x19,0x03, 0x19,0x66, 0x1A,0x04,
                                  0x19,0x04, 0x17,0x0D, 0x16,0x03, 0x16,0x02, 0x15,0x66,
                                  0x16,0x03, 0x17,0x02, 0x1F,0x0D, 0x1A,0x03, 0x1A,0x15,
                                  0x19,0x03, 0x1A,0x16, 0x1F,0x03, 0x20,0x02, 0x20,0x03,
                                  0x1F,0x0D, 0x1F,0x17, 0x1F,0x16, 0x00,0x00 };
//两只蝴蝶
unsigned char code Music_twoButterFly[] = { 0x17,0x03, 0x16,0x03, 0x17,0x0C, 0x17,0x03, 0x16,0x03,
                                  0x17,0x03, 0x16,0x03, 0x15,0x01, 0x10,0x03, 0x15,0x03,
                                  0x16,0x02, 0x16,0x0D, 0x17,0x03, 0x16,0x03, 0x15,0x03,
                                  0x10,0x03, 0x15,0x03, 0x0F,0x01, 0x17,0x03, 0x16,0x03,
                                  0x17,0x0B, 0x17,0x03, 0x16,0x03, 0x17,0x03, 0x16,0x03,
                                  0x15,0x01, 0x10,0x03, 0x15,0x03, 0x16,0x02, 0x16,0x0D,
                                  0x17,0x03, 0x16,0x03, 0x15,0x03, 0x10,0x03, 0x15,0x03,
                                  0x16,0x01, 0x17,0x03, 0x16,0x03, 0x17,0x0B, 0x17,0x03,
                                  0x16,0x03, 0x17,0x03, 0x16,0x03, 0x15,0x01, 0x10,0x03,
                                  0x15,0x03, 0x16,0x02, 0x16,0x0D, 0x17,0x03, 0x16,0x03,
                                  0x15,0x03, 0x10,0x03, 0x15,0x03, 0x19,0x01, 0x17,0x03,
                                  0x19,0x03, 0x19,0x0B, 0x19,0x03, 0x19,0x03, 0x1A,0x03,
                                  0x19,0x03, 0x17,0x01, 0x16,0x03, 0x17,0x03, 0x16,0x02,
                                  0x16,0x0D, 0x17,0x03, 0x16,0x03, 0x15,0x03, 0x10,0x03,
                                  0x10,0x0E, 0x15,0x0E, 0x15,0x03, 0x15,0x0D, 0x15,0x79,
                                  0x19,0x03, 0x19,0x03, 0x1A,0x03, 0x1F,0x03, 0x1B,0x03,
                                  0x1B,0x03, 0x1A,0x03, 0x17,0x03, 0x16,0x0D, 0x16,0x03,
                                  0x17,0x0D, 0x17,0x15, 0x17,0x03, 0x17,0x03, 0x19,0x03,
                                  0x1A,0x02, 0x1A,0x66, 0x10,0x03, 0x17,0x0D, 0x16,0x03,
                                  0x16,0x01, 0x17,0x03, 0x19,0x03, 0x19,0x03, 0x17,0x03,
                                  0x19,0x16, 0x1F,0x02, 0x1B,0x03, 0x1A,0x03, 0x1B,0x03,
                                  0x17,0x16, 0x1A,0x03, 0x1A,0x03, 0x1B,0x03, 0x1A,0x03,
                                  0x19,0x03, 0x17,0x03, 0x16,0x02, 0x17,0x0D, 0x16,0x03,
                                  0x17,0x03, 0x19,0x02, 0x00,0x00 };
//月亮代表我的心
unsigned char code Music_moonHeart[] ={ 0x0F,0x03, 0x15,0x66, 0x17,0x03, 0x19,0x66, 0x15,0x03,
                                  0x11,0x66, 0x17,0x03, 0x19,0x16, 0x19,0x03, 0x1A,0x03,
                                  0x1B,0x02, 0x1F,0x66, 0x1A,0x03, 0x1A,0x03, 0x19,0x0D,
                                  0x19,0x02, 0x17,0x03, 0x16,0x03, 0x15,0x66, 0x15,0x03,
                                  0x15,0x02, 0x17,0x03, 0x16,0x03, 0x15,0x66, 0x15,0x03,
                                  0x15,0x02, 0x16,0x03, 0x17,0x03, 0x16,0x02, 0x15,0x03,
                                  0x10,0x02, 0x16,0x0D, 0x17,0x03, 0x16,0x15, 0x0F,0x03,
                                  0x17,0x0D, 0x19,0x03, 0x17,0x66, 0x16,0x03, 0x15,0x02,
                                  0x19,0x02, 0x11,0x01, 0x10,0x03, 0x11,0x03, 0x10,0x02,
                                  0x11,0x03, 0x10,0x02, 0x0F,0x02, 0x17,0x01, 0x19,0x02,
                                  0x17,0x66, 0x16,0x03, 0x15,0x02, 0x19,0x02, 0x11,0x01,
                                  0x10,0x03, 0x11,0x03, 0x15,0x66, 0x15,0x03, 0x15,0x02,
                                  0x16,0x0D, 0x17,0x03, 0x16,0x15, 0x0F,0x03, 0x15,0x66,
                                  0x17,0x03, 0x19,0x66, 0x15,0x03, 0x11,0x66, 0x17,0x03,
                                  0x19,0x66, 0x19,0x03, 0x1A,0x66, 0x1B,0x03, 0x1F,0x66,
                                  0x1A,0x03, 0x1A,0x03, 0x19,0x0D, 0x19,0x02, 0x17,0x03,
                                  0x16,0x03, 0x15,0x66, 0x15,0x03, 0x15,0x02, 0x17,0x03,
                                  0x16,0x03, 0x15,0x66, 0x15,0x03, 0x15,0x02, 0x16,0x03,
                                  0x17,0x03, 0x16,0x66, 0x10,0x03, 0x11,0x02, 0x15,0x0D,
                                  0x16,0x03, 0x15,0x15, 0x00,0x00 };
全部资料51hei下载地址:
基于51单片机音乐播放仿真 乐谱制作软件 音乐资料.rar (668.85 KB, 下载次数: 90)
收藏收藏3 分享淘帖 顶顶 踩踩
