查看: 1583|回复: 0
普中51 按键 正反 60秒计时
ID:701320 发表于 2020-3-2 18:45 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
#include"reg52.h"
sbit a=P2^2;
sbit b=P2^3;
sbit c=P2^4;
sbit k1=P3^1;
sbit k2=P3^0;
sbit k3=P3^2;
uchar temp,aa,shi,ge,zan;
uchar flag1=0,flag2=0,flag3=0;
uchar num=60;
uchar code table[]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,
0x07,0x7f,0x6f,0x77,0x7c,0x39,0x5e,0x79,0x71};
void delay(uint t);
void display(uchar shi,uchar ge);
void init();
void key_scan();
init();//初始化子程序
  key_scan();
   if(flag1)
    if(aa==20)
    shi=temp/10;
    ge=temp%10;
     aa=0;
     temp++;
     if(temp==60)
      temp=0;
    key_scan();
    if(flag2||flag3){flag1=0;break;}
   if(flag2)
    if(aa==20)
    shi=num/10;
    ge=num%10;
     aa=0;
     num--;
     if(num==0)
      num=60;
    key_scan();
    if(flag1||flag3){flag2=0;break;}
  display(shi,ge);
void delay(uint t)
uint j,k;
for(j=t;j>0;j--)
  for(k=110;k>0;k--);
  a=1,b=1,c=1;
  P0=table[shi];
  delay(1);
  a=0,b=1,c=1;
  P0=table[ge];
  delay(1);
void init()
num=60;
temp=0;
zanting=0;
TMOD=0x01;
TH0=(65536-50000)/256;
TL0=(65536-50000)%256;
EA=1;
ET0=1;
TR0=1;
void timer0() interrupt 1
aa++;
zanting=1;
void key_scan()//键盘扫描
if(!k1)
  delay(10);
  if(!k1)
  flag1=1;
  if(!k2)
  delay(10);
  if(!k2)
  flag2=1;
  if(!k3)
  delay(10);
  if(!k3)
  flag3=1;
